Greenboard - Partial Vs Full Bath
Old 07-23-2017, 09:38 AM   #21
hdavis's Avatar
Rewards Points: 3,591
Re: Greenboard - Partial Vs Full Bath
Originally Posted by artinall View Post
plastic vapor barrier? (Kraft paper okay?)
I don't use Kraft paper, since the first thing it does is mildew. Just unfaced batts. If you have to use faced, install it and put a bunch of vertical cuts in the paper.
hdavis is online now
artinall (07-23-2017)
Old 07-23-2017, 09:49 AM   #22
artinall's Avatar
Trade: Repairs & Finishing
Rewards Points: 942
What a great idea.
Some else already did part of the bath in it. And I'm picking up on it.
(these are open walls on other side, so they started with kraft to hold it.)
artinall is offline
The Following User Says Thank You to artinall For This Useful Post:
hdavis (07-23-2017)
Old 07-30-2017, 06:00 AM   #23
Big Shoe's Avatar
Rewards Points: 1,716
Really, we've been hanging regular drywall on ceilings in bathrooms for ever. Prime it, paint it.
If you into the whole mold resistant thing go for it. Waste of money.
Green board is not spec'd for ceilings. Check with your local drywall supplier.
Good luck.
Sent from my iPad using Tapatalk
Expect the Unexpected
Big Shoe is offline
The Following 4 Users Say Thank You to Big Shoe For This Useful Post:
avenge (07-30-2017), blacktop (08-07-2017), hdavis (07-30-2017), rrk (07-30-2017)
Old 08-03-2017, 07:29 PM   #24
artinall's Avatar
Rewards Points: 942
Did the ceiling in regular sheetrock, and doing around the shower in green.
With an extra sheet of green, and lacking(1) in standard 1/2" -- anyone have an idea if the weight of greenboard is a factor on the slimmer pocket door frame? (wood frame was sealed).
artinall is offline
Old 08-04-2017, 09:11 PM   #25
MOC's Avatar
Trade: General Contractor (Historic Preservation)
I always use regular board on all ceilings. I now use the purple on all kitchen and bath walls, less than a $1 more per 12' sheet. I did like the green more but can't get it around here now. Maybe at the big box stores Idk. The purple is supposed to be mold and moisture resistant, and the green was just moisture resistant. That's what my USG supplier claims. And I do find the purple a tad harder to work with, paper seems barely attached and the rock seems softer and doesn't hold screws as well.
Somewhat unrelated vent, "sander crews around here sand a house for $1 a sheet. Pay my helper $17 an hour takes him two days to sand a 60 sheeter. I'm not happy, and the one thing I know he is great at is sanding drywall, shoulda took him 4-5hours." That's what I get for letting go!!
MOC is offline
The Following 2 Users Say Thank You to MOC For This Useful Post:
hdavis (08-04-2017), Tom M (08-11-2017)
Old 08-07-2017, 01:10 AM   #26
Pro or somethin'...
Anthill's Avatar
Trade: Tinwoodman
Rewards Points: 1,164
Last I checked here, MR was about double the money. But what really finished me was the stamp on it that said " do not use under tile". What's the point of MR in a bathroom if you can't tile over it?
Anthill is offline
Old 08-07-2017, 11:31 AM   #27
Peter_C's Avatar
Trade: Home Beautification
Rewards Points: 5,434
I tile over regular drywall, right after installing Kerdi. Schluter Systems is awesome, and allows the walls to be installed and start the tiling process immediately. Plus it is a superior water proofing system. Some folks like the Laticrete system. Schluter is sold by my suppliers locally.
The Panasonic Whisper fans on a timer get pushed by me every time. Most hate the noise of the fan and since they are quit, it takes that argument away, but since they are so quit a fan timer is required or they will get left on.
Peter_C is online now
The Following User Says Thank You to Peter_C For This Useful Post:
SmallTownGuy (08-07-2017)
Old 08-08-2017, 12:51 AM   #28
Pro or somethin'...
Anthill's Avatar
Trade: Tinwoodman
Do you Kerdi under backsplash and shower trim tile? I always membrane tub surrounds/ shower wall and the like but not sink backsplashes and other decorative stuff. I also use a tile backer rather than reg drywall under membranes.
Anthill is offline
Old 08-08-2017, 12:00 PM   #29
artinall's Avatar
Rewards Points: 942
Okay -- I've done a cutout around the shower flange.
Going to fill with 20 minute and fibafuse tape.
Should it be prefilled to help level?
artinall is offline
Old 08-08-2017, 01:40 PM   #30
hdavis's Avatar
prefill.
Old 08-08-2017, 07:31 PM   #31
Peter_C's Avatar
Sometimes. For instance I did a tile layup behind an in wall toilet and used Kerdi, just in case, plus it makes for a better, stronger layup.
Old 08-09-2017, 10:08 AM   #32
artinall's Avatar
Rewards Points: 942
prefill.
I stay away from fiberglass mesh because of concern for cracking...maybe that same fibafuse tape?
artinall is offline
Old 08-11-2017, 04:35 PM   #33
artinall's Avatar
Rewards Points: 942
prefill.
Seems a little tough to fill with 20 minute (or durabond or any compound) -- and leave a caulk gap at the bottom. You fill completely full?
artinall is offline
Old 08-11-2017, 07:26 PM   #34
hdavis's Avatar
No, I leave a gap for caulk. I also either use Fibafuse (now), or in the past I've used mesh.
artinall (08-11-2017)
Old 08-12-2017, 09:31 AM   #35
artinall's Avatar
Rewards Points: 942
I've done a lot of drywall, and am wondering what technique you use to leave that remaining gap between the shower edge and the taped 20 min.
Even if you use a knife guide, the compound will want to pull off when the knife is removed and reset... and it will sag due to lack of support
artinall is offline
Old 08-13-2017, 09:01 AM   #36
hdavis's Avatar
I mix the setting compound stiff, so I use a trowel, not a knife. I'm not sure what you mean by knife guide, I use the same technique as getting excess mud out of a corner - knife on edge run along the corner.
artinall (08-13-2017)
Old 08-13-2017, 11:44 AM   #37
artinall's Avatar
Rewards Points: 942
...I'm not sure what you mean by knife guide, I use the same technique as getting excess mud out of a corner - knife on edge run along the corner.
KG - simply a taping blade held horizontally as a guide.
artinall is offline
hdavis (08-13-2017)
Old 10-24-2017, 09:20 PM   #38
Kumpel's Avatar
Rewards Points: 28
Good luck.
This
Kumpel is online now
The Following User Says Thank You to Kumpel For This Useful Post:
blacktop (10-25-2017)
Old 10-25-2017, 02:05 AM   #39
Drywall Slave
blacktop's Avatar
Trade: drywall contractor
Rewards Points: 2,742
Originally Posted by Kumpel View Post
This
Shoe is right. If you keep your home dry ... you won't have mold . It's that simple .
blacktop is offline
Free standing Wheelchair ramp by Creative Bath Systems Creative Bath Specialty Trades Picture Post 5 05-30-2012 06:40 PM
Indianapolis Master Bath Remodel - Shed Dormer Extension ChrWright Remodeling Picture Post 16 12-13-2009 10:59 PM
