Greenboard - Partial Vs Full Bath
Old 03-26-2017, 09:02 PM   #1
artinall's Avatar
Trade: Repairs & Finishing
Rewards Points: 1,550
So many baths I see over the years have been done in typical 1/2".
I've done greenboard immediately surrounding the tub/shower area, and, with another bath ahead now to drywall -- does it really pay to do the full bath in moisture-resistant board? (for paint grade finish, no tile on walls)
I've always used the green - is the purple much different or easier to work?
Might as well review my taping too: I normally use paper tape (or Fibafuse tape, not mesh) with lightweight multipurpose to bed it. I've heard of the term "moisture resistant mudd" being tossed around, but my take on this is that drywallers are simply using setting-type compound OR straight mudd with topping with this description. I've never set eyes on "moisture resistant' compound ...
The room is in the basement with an electric air vent added...
artinall is online now
Old 03-26-2017, 09:13 PM   #2
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 2,223
Re: Greenboard - Partial Vs Full Bath
Can't find greenboard around here any more--just the purple. I don't really see any difference as far as working with the stuff.
If you have good moisture removal (read: fan on a timer), IMO you'd be fine with regular drywall throughout. Doing the whole deal in green or purple would be overkill.
Never had a problem just using all-purpose mud.
Tinstaafl is online now
The Following 2 Users Say Thank You to Tinstaafl For This Useful Post:
artinall (03-27-2017), Golden view (03-26-2017)
Old 03-26-2017, 09:17 PM   #3
edward trowelhands
Golden view's Avatar
Trade: Diplomat
Rewards Points: 4,406
The fan and timer is much more important than the drywall.
Golden view is offline
Old 03-26-2017, 09:54 PM   #4
Framer53's Avatar
Trade: Handyman
Rewards Points: 366
I think I pay a dollar a sheet(4x8)more for the purple drywall.
Why both with trying to say a few when you know it is a better application to use the water resistant drywall?
Framer53 is offline
The Following User Says Thank You to Framer53 For This Useful Post:
gbruzze1 (08-03-2017)
Old 03-26-2017, 10:17 PM   #5
philcav7's Avatar
Trade: Residential Remodeling
Rewards Points: 1,185
I stopped using MR/Barney board in bathrooms. Locally, it's about 40% more than regular board...not that an extra few bucks is a big deal, but I don't really see a point in it. If it gets wet, it still fails. It doesn't paint as well. Properly sized fans pull excess moisture adequately. Showers we build are almost always tile surrounds.
I do use MR in basements as these locations are subject to higher and more continuous moisture and less ventilation.
philcav7 is offline
Old 03-27-2017, 05:42 AM   #6
John1957's Avatar
Trade: Home Improvement
Rewards Points: 212
I pay the few extra bucks and go with mold resistant, but I have done many tear out's where regular rock was in place and didn't see any mold issues.
Most of the mold that I come across in bathrooms is from poor ventilation ducting dripping onto ceilings and walls, and I see it much more in the fairly modern condo type units than I do in stand alone houses.
Most of the mold that I see in stand alone houses is from neglect by the homeowner who doesn't keep up with maintenance.
(caulking around the tubs and showers, bad tub and shower plumbing behind walls and under kitchen sinks)
John1957 is offline
Old 03-27-2017, 07:14 AM   #7
Sean
SLSTech's Avatar
Trade: Principal / Owner
Rewards Points: 110
Green is pretty worthless - the paint & using a timer deals with normal usage (assuming the vent, vents outside)
If you are worried about moisture I would go with a densarmor & not use paper tape
SLSTech is offline
Old 03-27-2017, 07:04 PM   #8
artinall's Avatar
Because it is harder to work with.
Old 03-28-2017, 05:42 AM   #9
John1957's Avatar
Rewards Points: 212
Why is it harder? What problems have you ran into? I have no problems with the newer mold resistant rock. It appears to cut and snap as good as any other. I have more issues with the USG lightweight boards than any of the mold resistant. USG was supposed to have taken care of the problems with the lightweight board, but I still run into air pockets and hard spots.
Gold Bond XP mold resistant (blue board) is very easy to work with. It cuts and snaps pretty nice with minimal rasping.
John1957 is offline
Old 03-28-2017, 01:59 PM   #10
artinall's Avatar
My experience is that it is harder to cut, more brittle, and heavier to boot.
Old 04-05-2017, 04:31 PM   #11
Drywall Slave
blacktop's Avatar
Trade: drywall contractor
Rewards Points: 3,930
Oh you poor thang!
blacktop is offline
Old 04-05-2017, 06:38 PM   #12
Framer53's Avatar
Trade: Handyman
Rewards Points: 366
Huh?
Your experience is not the norm, for sure.
Framer53 is offline
Old 04-05-2017, 10:16 PM   #13
artinall's Avatar
Okay, I guess greenboard could have only seemed heavier...
Huh?
You don't notice it being more difficult to cut?
Blacktop: maybe you have some green to contend with in the a.m.? You're trying to psyche it out? ... But I see you agree and that's good enough!
Old 07-22-2017, 07:56 PM   #14
artinall's Avatar
I've searched and there are no stores around here that have 1/2 inch purple (they'd have to order a stack).
With 1/2" green needing 12" joist spans (ours are 16" on center) -- would the 1/2" even suffice for the ceiling? Isn't the 1/2 purple less resistant to bowing than the green?
Since the 1/2" purple is supposed to be fireproof - do you really need 5/8 on the ceiling?
Only other option I can find now is to use 5/8 purple (the only purple around) on ceiling and 1/2 green on walls.
Old 07-22-2017, 08:11 PM   #15
Framer53's Avatar
Trade: Handyman
Rewards Points: 366
First, 1/2" rock is good for 16 centers.
Second purple is green just a different manufacturer.
As far as fireproof all rock has a 20 minute rating. Purple is not different. They do not use paper that will become moldy.
Framer53 is offline
Old 07-22-2017, 08:16 PM   #16
Talking Head
EthanB's Avatar
Rewards Points: 96
All of them will grow mold. We see it on a weekly, if not daily basis. Mold resistant means little when an actual leak is present. I'm of the belief that in most situations, regular board is fine as long as waterproofing and ventilation are properly managed. If they aren't managed properly, green or purple won't save you. Mold will grow on studs, insulation, trim or the surface of the paint just as easily.
Planer.....
EthanB is online now
The Following 6 Users Say Thank You to EthanB For This Useful Post:
asevereid (07-22-2017), hdavis (07-22-2017), heavy_d (07-22-2017), Jaws (08-04-2017), rrk (07-23-2017), Xtrememtnbiker (08-11-2017)
Old 07-22-2017, 08:39 PM   #17
avenge's Avatar
Rewards Points: 2,856
WTF? That's all I care to say.
avenge is online now
Old 07-23-2017, 07:23 AM   #18
artinall's Avatar
Nobody here is of the opinion that greenboard is better than regular drywall when it comes to inhibiting moisture? But that it requires 12 inch OC for ceilings?
There will be no tile and a fairly strong vent has been installed (even though its preset tabs space it 1/2" down from joist). Just want to go that extra mile.
My thoughts (incorrect ?) are that the 5/8 green could be 16" OC
Regular 1/2" is stronger, that's clear.
Then there is that argument that greenboard should be used without vapor barrier - by manufacturers (even on the plumbed wall?) This doesn't include kraft paper insulation does it?
Old 07-23-2017, 08:13 AM   #19
hdavis's Avatar
Rewards Points: 683
Green board has wax in it, so it does better than regular if you have water on it. It can get wet and not turn to mush the first time. A lot of people just use it on walls around the shower, not on the ceiling. OTOH, I've done entire baths with it.
You shouldn't use a vapor barrier with it.
hdavis is online now
artinall (07-23-2017)
Old 07-23-2017, 08:26 AM   #20
artinall's Avatar
plastic vapor barrier? (Kraft paper okay?)
I've done a lot of drywall repair. Always, in baths, it has been where a ceiling fan went out, and it occurs right around the shower/surround.
My first question is always...have you been using the ceiling fan? Then I get that look.
Free standing Wheelchair ramp by Creative Bath Systems Creative Bath Specialty Trades Picture Post 5 05-30-2012 05:40 PM
Indianapolis Master Bath Remodel - Shed Dormer Extension ChrWright Remodeling Picture Post 16 12-13-2009 09:59 PM
