Green Board Vs Mold Moist Resist Board
Old 05-18-2008, 11:26 AM   #1
taperboy's Avatar
Trade: drywall taper
hi every one this is my first post!! i need some helpp.
ok i'm doing drywall mud and tape on a basement, the owner has chosen a room to grow plants where i assume there will be a lot of moisture the room is about 12' by 13' it does have a window.. my question is what would u guys use for that room mold resist board or green board ?? i'm thinking mold/moist resist board,, what u guys think would be best??
taperboy is offline
Old 05-18-2008, 12:14 PM   #2
genecarp's Avatar
Re: Green Board Vs Mold Moist Resist Board
greenboard is fine, as long as he is not hosing the room down, good coat of primer and paint, keep sheetrock 1/4'' off the slab, if no window, i would add exhaust fan or vent to room. WHAT KIND OF PLANTS
genecarp is offline
Old 05-18-2008, 12:16 PM   #3
I am not a hack.
Beater82's Avatar
Trade: California General Contractor/Carpenter
(cough, cough) Is the next post gonna' be some advice on hydroponic lighting?(cough, cough)
Beater82 is offline
Old 05-18-2008, 12:17 PM   #4
genecarp's Avatar
genecarp is offline
Old 05-18-2008, 01:56 PM   #5
TooledUp's Avatar
Trade: Decorator and Taper
"You are through to the drug dependancy help line. If you are addicted to cannibas press the hash key".
Handle every stressful situation like a dog.
If you can't eat it or hump it...
P*ss on it and walk away.
Last edited by TooledUp; 05-18-2008 at 02:13 PM. Reason: There's a free typo in every post
TooledUp is offline
Old 05-19-2008, 08:36 AM   #6
BUTCHERMAN's Avatar
Trade: DRYWALL PROFESSIONAL
I would go with dens-armor. These rooms are humid with consent water on the floor. Green won't stop the mold or mildew. XP would probably work O.K. but that's treated paper as opposed to a mold proof face in the dens-armor. Just use ez sand to tape coat.
BUTCHERMAN is offline
Old 05-19-2008, 09:40 AM   #7
Commercial Estimator
Tony Rio's Avatar
Trade: Drywall, Insulation, Framing, Paint, Roofing, ACT, Mechanical Piping
x2 on Densarmor. The only way to really suppress mold is to get rid of it's "food"... a paperless board like Densarmor would be the way to go. Have you also considered the stud work behind? This would be a good application to consider steel stud if it's not already framed.
Tony Rio is offline
Old 05-19-2008, 04:10 PM   #8
towertaper's Avatar
Trade: taper
I love a good mold resistant plant growing room in the basement their becoming quite popular here in canada.
towertaper is offline
Old 05-19-2008, 05:01 PM   #9
Remodeling GC
kevjob's Avatar
have seen many grow roo.. uh I mean storage space up in the mtns here.
kevjob is online now
Old 05-19-2008, 10:02 PM   #10
Rock it...
BattleRidge's Avatar
people never even use green board around here. Its not very effective IMO I agree with the dens armor
BattleRidge is offline
Old 05-20-2008, 09:02 PM   #11
sapotech101's Avatar
Trade: General contractor fire and flood restoration especialist.
green board would be ok if you want no mold growing just spray with mocro band behind walls and on drywall for moisture you need ventilation mold only grows when there is no air movement and theres moisture in the room.
sapotech101 is offline
Old 05-20-2008, 09:37 PM   #12
BUTCHERMAN's Avatar
Not true mold needs air to grow. You take a chance with green. Green does feed mold dens armor does not. Why even guess about the conditions when you have a sure thing? Also what about mildew?
Old 05-21-2008, 07:29 PM   #13
Carpenter/fencing
nywoodwizard's Avatar
Who the hell grows plants in the basement besides cheech or chong ? Workin for a reefer head growin some homegrown hay?
Learning without thought is labor lost; thought without learning is perilous.
nywoodwizard is offline
Old 05-21-2008, 08:05 PM   #14
mold only grows in humid areas with no air circulating. I know i dry building for living i went to school for that and mildew is a form of mold. Get some mildacide also known as microband and circulate air. you should have no problem and if you still not satisfied spray fosters but is about $500 for a fiver.
Old 05-22-2008, 01:18 PM   #15
taperboy's Avatar
you guys are fun!!! you crack me up!!!
taperboy is offline
Old 05-22-2008, 01:41 PM   #16
taperboy's Avatar
ok guys thanks for your help!! also what about insulation i know some people put plastic on their basement wall don't know what kind of plastic/moisture barrier is that ?? i dont think thats a good idea cause it will trap moisture i never used moisture barrier is that bad??. Toni the basement is already framed with regular 2x4, so i think i'm just going to spray it with some mold control spray.. Also where can i find that microband?? never heard of that ?? again thanks for your help guys..
taperboy is offline
Old 05-22-2008, 09:52 PM   #17
jondon sells it its a flood restoration store. Also a moisture barrier is a bad idea is its just plastic nothing special. i cant count how many basemants i had to tear out because they had a mousture barrier you cant dry the insulatio which can holds one gallon of water per square foot. moisture barriers are so when the grade out side (since your in abasemant ) is cooler than the inside the moisture dont bleed thrugh so they figure it will just condense on the plastic but if you have insulation then it gets wet little by little and then you can have a colony of fungy on the insulation paper. just type jondon dot youknow what the site wont let me post the adress since i dont have 15 post yet. good luck
Green Paint Division toddcla2002 Painting & Finish Work 17 01-24-2008 03:22 AM
Green board & V.Barriers Heritage Drywall 11 12-15-2007 07:09 PM
green board boman47k Kitchens & Baths 16 09-11-2007 08:21 PM
New Construction Showing Mold... thepawnshop Construction 13 10-20-2006 07:43 PM
