Green Board & V.Barriers
Old 12-10-2007, 08:24 PM   #1
Average Joe
Heritage's Avatar
Trade: D/B, Management, Consulting, Contracting.
Got into a debate over this at work today when we were boarding up a bathroom.
I say:
You can't put a vapour barrier behind Green board because it creates a double moisture barrier (especially where the boards are getting tiled over).
You shouldn't be putting "safe and sound" insulation in there either, because that might screw up the moisture/air flow behind the boards.
Numb-nuts says:
The exact opposite.
"Safe and sound" the entire bathroom...including ceiling.
Vapour barrier everything...tuch tape all around seams.
So what's the verdict?
Toronto General Contractor-Renovation Blog-Contractor on Facebook-Renovation on twitter-Contractor Youtube
Originally Posted by rex View Post
i get high with my left hand.....
Heritage is offline
Old 12-10-2007, 09:53 PM   #2
Tom R's Avatar
Re: Green Board & V.Barriers
I say:
You are correct, - - it creates a double barrier and can actually lock moisture in.
But, - - you not only shouldn't be tiling over greenboard, - - greenboard isn't even recommended for walls anymore, - - for all it's hype it has failed the test of time miserably.
http://www.tr-built.com
Tom R is online now
Old 12-10-2007, 10:34 PM   #3
reveivl's Avatar
Trade: Renovations
What Tom said. Around here you can't even get greenboard anymore. Now it's paperless drywall: nowhere for the mold to grow. Drywall is not a suitable substrate for tile in a wet area, or really anywhere, maybe a backsplash here or there.
reveivl is offline
Old 12-11-2007, 12:01 AM   #4
Average Joe
Heritage's Avatar
Rreeeallly?
I go Cement in the tub enclosure, but to date I've always used Greenboard on the walls.
Didn't know it was failing. They sell them like hotcakes over here. I must say...this is making my life a little bit harder.
But on a happy note...Numb-nuts is wrong and I'm right...kinda
Good enough for CANADA!
Gracias Amigos!
Heritage is offline
Old 12-11-2007, 05:06 PM   #5
Tom R's Avatar
You don't really have to worry about any you have already applied, - - it's not like it's falling off the walls or anything. It just didn't pan out to be as good as it was projected to be . . .
Tom R is online now
Old 12-13-2007, 12:31 PM   #6
justinhorton24's Avatar
Trade: Home Improvement
i recently tore out a ladies bathroom and she specifically asked to have green board put back in. well after i finished she told me that i was supposed to have put the green side facing in.
justinhorton24 is offline
Old 12-13-2007, 07:20 PM   #7
Tom R's Avatar
Sheesh!! Should'a told her you would have, but luckily, you noticed the 2 X 4's were installed backwards . . .
Tom R is online now
Old 12-13-2007, 09:27 PM   #8
erikb45's Avatar
Trade: carpenter
i too heard that greenboard is done. we still usse a purple moisture and mold resistant board commercially
erikb45 is offline
Old 12-14-2007, 01:47 PM   #9
Tom M's Avatar
You cant use green board. Like Reveivl said the moisture not water would would pass through the tile then the board and hit the vapor barrier. Then it would sit there and cause the paper to soak the moisture and grow mold.
Does anyone ever use regular rock in the bath ceiling? I dont do much in the way of baths but 1/2 water resist is not allowed and I cant see use the 5/8 through out a bathroom ceiling.
Tom M is offline
Old 12-14-2007, 09:03 PM   #10
kgphoto's Avatar
Trade: Residential Remodeling
Heck! All I install is 5/8's Rarely ever 1/2 inch.
kgphoto is offline
Old 12-15-2007, 07:08 PM   #11
dryrocker27's Avatar
Trade: Drywall Contractor
We were told by a rep. from national gypsum that green board was designed to use in sauna's and steam rooms behind the cedar boards.
Builders started using it in bathrooms to prevent the mold from growing on the ceiling, The problem was that the bathroom was not vented as they are now and the mold was on the paint, not the drywall.
Now that bathrooms are vented, mold is not an issue. In our area, the exhaust fan is connected to the main lighting fixture so it come on any time the light is on.
Robert
dryrocker27 is offline
Old 12-15-2007, 07:09 PM   #12
by the way, we install regular drywall and all bathroom ceilings are painted with semi-gloss.
Robert
Licensed & Insured bjg5240 Business 34 06-09-2009 07:56 PM
Transitioning drywall with cement board Lone Wrencher Drywall 19 03-02-2008 07:05 AM
Green Building Moscow General Discussion 5 12-16-2007 04:38 PM
green board boman47k Kitchens & Baths 16 09-11-2007 08:21 PM
The Green Economy woodmagman Green Building 10 03-04-2007 03:51 PM
