Graco RTX900
Old 08-10-2012, 07:33 AM   #1
Milhaus's Avatar
Trade: Residential Remodeling
Rewards Points: 254
Graco RTX900
I just bought a used Graco RTX 900 from a guy that used to work for me. We tried spraying sand texture 12 yesterday and couldn't get the adjustments fine enough to spray it correctly. Any of you that use one of these ever tried this? For the price, it seems you should have the capability. I cleaned the gun completely after it failed the first time. Does this machine have the air pressure to do this successfully or it is only capable of splatter or orange peel?
I ended up going back to the tried and true hopper/air compressor, but was pretty disappointed that I couldn't get the Graco to function properly.
mark
Milhaus is offline
Old 08-10-2012, 10:32 PM   #2
bluntman001's Avatar
Trade: Taper
Re: Graco RTX900
I have a Graco RTX 1400 but I've never tried to spray sand texture. I've sprayed many other types of ceilings textures, but really doesn't much pressure in the machine, if the stuff is real thick, and you got the extra long hose going up the stairs or something, it doesn't flow properly.
Drywall In Camrose
bluntman001 is offline
Old 08-11-2012, 10:16 AM   #3
Drywall & Painting Pro
Sir Mixalot's Avatar
Rewards Points: 18,173
Re: Graco RTX900
mark
I don't own a 900. But, I have a 1000 which Graco doesn't make anymore. The 900 is the new version of the 1000.
My suggestion would be check the material dial on the machine and also the one on the gun. You might need to loosen up the material a little more too.
-Paul
PeckDrywallandPainting.com
Checkout my YouTube Channel with 20,000 Subscribers and over 5,000,000 Views
https://www.youtube.com/paulpeck
Twitter Facebook Google+ Instagram
Sir Mixalot is offline
Graco Auto Clean HandyHails Painting & Finish Work 9 11-13-2014 08:04 AM
Graco Proshot FineFinish Issues Winchester Tools & Equipment 8 07-11-2012 10:52 AM
Best Finish Spray Rig, with Best Waterbourne Cabinet Finish in Satin? Graco 9.5? FineLine Lead RRP Discussion 0 06-11-2011 05:33 PM
Graco damaged out of box JKBARR127 Painting & Finish Work 2 01-21-2010 06:25 PM
Graco SUCKS Capt-Sheetrock Drywall 20 09-29-2009 08:07 AM
