Framer's Question For You Drywallers
Old 05-11-2017, 12:05 AM   #21
Fire up the BBQ
griz's Avatar
Rewards Points: 18
Re: Framer's Question For You Drywallers
This is a quality and reputation issue.
If you had an existing wall you are adding on to, the corner bead is removed and existing drywall removed to create a staggered joint at the connection of old & new.
The only way corner bead would be left are.....
New wall drywall and double layer hung over both walls.....or
drywall new wall and install 1x paneling over both walls.
I did very well in the remodeling market because you could not tell my job was a remodeled.....
griz is offline
hammer7896 (05-11-2017)
Old 05-11-2017, 01:10 PM   #22
Drywall Slave
blacktop's Avatar
Trade: drywall contractor
Rewards Points: 3,028
Originally Posted by illbuildit.dd View Post
You can leave it but you can get a flatter finish if you remove it.
Originally Posted by Dave in Pa View Post
I would remove it. If not, 9 times out of 10, you will get a hump in the wall.
Originally Posted by John1957 View Post
I prefer to remove the bead because you don't have to bust the joint out as far with mud to kill the visual transition.
You are looking at a 1/8" to 3/16" mud build up from the original bead in place, and now you are adding to it. If you remove the bead and scrape off a little of old mud, you are more or less finishing like it's a normal butt/corner joint. It doesn't take but a few minutes.
Originally Posted by Warren View Post
Always remove it. They always seem to crack if you don't.
Originally Posted by griz View Post
another vote to remove bead.
will be nothing but trouble if you leave it....
Originally Posted by Sir Mixalot View Post
I always remove cornerbead. I guess there could be exceptions to leave the corner bead. But those are rare.
blacktop is offline
The Following User Says Thank You to blacktop For This Useful Post:
Rio (05-11-2017)
Old 07-03-2017, 10:55 PM   #23
always building
parkers5150's Avatar
Trade: general constructiion
Rewards Points: 1,804
it takes less time to pull a corner bead than to start a new thread on CT
"Building trust one job at a time."
www.RDPontheWeb.com
San Diego Contractor Deck and Patio Cover Builder
parkers5150 is offline
The Following 2 Users Say Thank You to parkers5150 For This Useful Post:
Fouthgeneration (12-17-2017), Jay hole (10-01-2017)
Old 07-04-2017, 04:02 PM   #24
Drywall Slave
blacktop's Avatar
Not if it's a 40' bulkhead!
blacktop is offline
overanalyze (07-04-2017)
Old 07-04-2017, 09:41 PM   #25
Drywall & Painting Pro
Sir Mixalot's Avatar
Rewards Points: 18,067
If it's only crimped...
Sir Mixalot is offline
The Following 2 Users Say Thank You to Sir Mixalot For This Useful Post:
blacktop (07-04-2017), overanalyze (07-04-2017)
Old 07-30-2017, 06:03 AM   #26
Big Shoe's Avatar
Rewards Points: 1,718
Always remove bead. Cut back drywall up to one foot. Impossible to finish correctly if you don't.
Sent from my iPad using Tapatalk
Expect the Unexpected
Big Shoe is offline
The Following User Says Thank You to Big Shoe For This Useful Post:
blacktop (08-02-2017)
Old 07-30-2017, 09:30 AM   #27
rjconstructs's Avatar
Trade: Residential remodel
Rewards Points: 168
And don't use mesh tape.
whats wrong with mesh tape?
rjconstructs is offline
Old 08-02-2017, 04:03 AM   #28
Drywall Slave
blacktop's Avatar
What's right ?
blacktop is offline
Old 10-01-2017, 02:46 PM   #29
On Your Side's Avatar
Trade: Home Improvements
I would definitely remove the corner bead . It makes the job look better in the end .
On Your Side is offline
Old 12-15-2017, 07:32 AM   #30
PaulFalls44's Avatar
Trade: Electrical
Rewards Points: 42
I would remove it even though you do not have to
PaulFalls44 is offline
Old 12-17-2017, 01:19 PM   #31
Workin' Hard for the $
Scoma's Avatar
Trade: Home Repair/Remodeling/Renovation
Rewards Points: 35
Originally Posted by BUTCHERMAN View Post
Ok. I missed that. That's on me. Then my question would be why not remove not only the bead but why not gut the existing wall and hang new rock that spans over the pld meeting new to avoid a settling crack?
This is how we do it. Always seem to have settling cracks otherwise.
Sent from my Pixel using Tapatalk
Scoma is offline
Basic question for framers sounder_4 Framing 61 11-10-2015 05:56 AM
I have a question about my truck loan VinylHanger Vehicles 23 06-08-2012 12:00 PM
Question For The Timber Framers Seven-Delta-FortyOne Framing 5 04-04-2012 11:06 PM
Atlanata Area Drywallers and Framers Needed!! C.L.Bailey Drywall 0 11-09-2007 08:45 AM
In Need Of Drywallers And Framers In The Atlanta Area!! C.L.Bailey Introductions 0 11-08-2007 04:03 PM
