Framer's Question For You Drywallers - Drywall - Contractor Talk
Old 05-09-2017, 05:19 AM   #1
phil
phnola's Avatar
Trade: general contractor
Rewards Points: 35
Hi ,
Quick question for you drywallers from a residential remodeler. If I am tying in to an existing finished outside corner with new framing (basically extending the plane of the existing wall) is it necessary to remove the corner bead before I fasten the 2x4 framing to the wall through the drywall? Or can you tape the joint between the new board and the corner bead.
Thanks
Phil
phnola is offline
Old 05-09-2017, 08:26 AM   #2
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 2,445
Re: Framer's Question For You Drywallers
No problem with leaving the bead there, as long as you have a decent mud man.
Tinstaafl is online now
The Following 2 Users Say Thank You to Tinstaafl For This Useful Post:
Metro M & L (05-09-2017), phnola (05-09-2017)
Old 05-09-2017, 02:18 PM   #3
GC/carpenter
Californiadecks's Avatar
Rewards Points: 706
Why not just remove it? It has to be redone anyway. Might as well start from the corner.
_____________
Californiadecks is offline
The Following 4 Users Say Thank You to Californiadecks For This Useful Post:
Bummie (07-04-2017), Dirtywhiteboy (05-10-2017), greg24k (05-10-2017), phnola (05-09-2017)
Old 05-09-2017, 05:46 PM   #4
House surgeon
illbuildit.dd's Avatar
Trade: building/remodeling
Rewards Points: 2,062
You can leave it but you can get a flatter finish if you remove it.
illbuildit.dd is offline
The Following 4 Users Say Thank You to illbuildit.dd For This Useful Post:
blacktop (05-11-2017), Bummie (07-04-2017), phnola (05-09-2017), Sir Mixalot (05-10-2017)
Old 05-09-2017, 05:54 PM   #5
Dave in Pa's Avatar
Trade: restoration/remodeling
Rewards Points: 1,272
I would remove it. If not, 9 times out of 10, you will get a hump in the wall.
Dave in Pa is offline
The Following 5 Users Say Thank You to Dave in Pa For This Useful Post:
blacktop (05-11-2017), Bummie (07-04-2017), Fouthgeneration (12-17-2017), greg24k (05-10-2017), phnola (05-09-2017)
Old 05-09-2017, 06:07 PM   #6
John1957's Avatar
Trade: Home Improvement
Rewards Points: 212
I prefer to remove the bead because you don't have to bust the joint out as far with mud to kill the visual transition.
You are looking at a 1/8" to 3/16" mud build up from the original bead in place, and now you are adding to it. If you remove the bead and scrape off a little of old mud, you are more or less finishing like it's a normal butt/corner joint. It doesn't take but a few minutes.
John1957 is offline
The Following 2 Users Say Thank You to John1957 For This Useful Post:
Bummie (05-09-2017), phnola (05-09-2017)
Old 05-09-2017, 06:10 PM   #7
Geometrist
Warren's Avatar
Trade: framing/remodeling
Rewards Points: 6,615
Always remove it. They always seem to crack if you don't.
Easy Gibson
Warren is online now
The Following 4 Users Say Thank You to Warren For This Useful Post:
blacktop (05-11-2017), greg24k (05-10-2017), Metro M & L (05-09-2017), phnola (05-09-2017)
Old 05-09-2017, 06:45 PM   #8
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 1,072
Another vote for removal.
Sent from my SM-G920V using Tapatalk
overanalyze is online now
Old 05-09-2017, 06:53 PM   #9
Geometrist
Warren's Avatar
I always strike the edge of the bead with the claw of my hammer to remove it. Work your way from top to bottom and the drywall is not harmed.
Easy Gibson
The Following 7 Users Say Thank You to Warren For This Useful Post:
antonioooooooo (06-18-2017), Dirtywhiteboy (05-10-2017), greg24k (05-10-2017), griz (05-09-2017), overanalyze (05-09-2017), phnola (05-09-2017), Sir Mixalot (05-10-2017)
Old 05-09-2017, 08:51 PM   #10
House surgeon
And don't use mesh tape.
Old 05-09-2017, 09:06 PM   #11
Fire up the BBQ
griz's Avatar
Rewards Points: 2,838
another vote to remove bead.
will be nothing but trouble if you leave it....
griz is offline
The Following 2 Users Say Thank You to griz For This Useful Post:
Bummie (05-09-2017), greg24k (05-10-2017)
Old 05-09-2017, 11:09 PM   #12
avenge's Avatar
Rewards Points: 2,966
It's beyond me why you would even contemplate leaving the bead. not only would I remove the bead I'd remove at least some of the drywall due to the build up of mud from the bead.
avenge is offline
The Following 2 Users Say Thank You to avenge For This Useful Post:
Californiadecks (05-09-2017), Snobnd (07-05-2017)
Old 05-10-2017, 01:29 AM   #13
Dirtywhiteboy's Avatar
Rewards Points: 8,214
It only takes seconds with the framing claw,,,
I 3rd it.
Dirtywhiteboy is offline
Old 05-10-2017, 09:15 AM   #14
BUTCHERMAN's Avatar
Trade: DRYWALL PROFESSIONAL
Rewards Points: 2,392
To me it depends on the circumstances. I wouldn't be so quick to have the knee jerk reaction to remove it. While I agree in most cases you are better off removing it, there are exceptions to the rule that require a little more information. For example, Is it a plaster wall to where the bead is deeply embedded to the point where removing it could loosen the existing plaster from the lathe? Could it be in a awkward place that can cause more harm than good to remove it?
I wouldn't answer the question without knowing the condition of the existing wall. I will say this, either way you go, I can tie it in and have.
BUTCHERMAN is online now
Old 05-10-2017, 09:54 AM   #15
GC/carpenter
Rewards Points: 706
The OP said it was drywall. If you leave the bead it will be crowned right there. Attaching a 2x4 to it, before removing the bead, is not best practices.
_________________
The Following User Says Thank You to Californiadecks For This Useful Post:
Old 05-10-2017, 10:24 AM   #16
BUTCHERMAN's Avatar
_________________
He didn't state what the existing wall was. Maybe I missed it, I just don't see it. Two things I'm pointing out here. One which I said was for the most part I would remove the bead. Second is that there are exceptions. The point is, The circumstance determine the answer. There is no one size fits all. Being drywallers, we know better. No two drywallers are the same. That's why we have different answers. Also you can say for sure it will be crowned. How do you know the framer won't compensate for it? How do you know the condition, size or any other determining factors that can come into play such as doors windows and arches?
My point is, there isn't a straight forward answer that will determine the best result. If you want a straight forward answer, the truth is, It can go either way. But that doesn't say what's the best and I mean best way to go.
His question was is it necessary. Is it? Or are we answering is it best? I tried to answer both.
Old 05-10-2017, 11:30 AM   #17
GC/carpenter
Rewards Points: 706
Originally Posted by phnola View Post
Hi ,
Thanks
Phil
Not trying to argue, but I was referring to this. However I agree there can certainly be exceptions.
_____________
Old 05-10-2017, 01:55 PM   #18
BUTCHERMAN's Avatar
Ok. I missed that. That's on me. Then my question would be why not remove not only the bead but why not gut the existing wall and hang new rock that spans over the pld meeting new to avoid a settling crack?
The Following User Says Thank You to BUTCHERMAN For This Useful Post:
Californiadecks (05-10-2017)
Old 05-10-2017, 09:38 PM   #19
Drywall & Painting Pro
Sir Mixalot's Avatar
Rewards Points: 18,261
I always remove cornerbead. I guess there could be exceptions to leave the corner bead. But those are rare.
-Paul
TextureMaster.com
Checkout my YouTube Channel with 20,000 Subscribers and over 5,000,000 Views
https://www.youtube.com/paulpeck
Twitter Facebook Google+ Instagram
Sir Mixalot is offline
The Following User Says Thank You to Sir Mixalot For This Useful Post:
Old 05-10-2017, 10:08 PM   #20
Who has time to feather in that lump Leave the ridge of mud for the drywaller to pop off
Sir Mixalot (05-11-2017)
Basic question for framers sounder_4 Framing 61 11-10-2015 04:56 AM
I have a question about my truck loan VinylHanger Vehicles 23 06-08-2012 11:00 AM
Question For The Timber Framers Seven-Delta-FortyOne Framing 5 04-04-2012 10:06 PM
Atlanata Area Drywallers and Framers Needed!! C.L.Bailey Drywall 0 11-09-2007 07:45 AM
In Need Of Drywallers And Framers In The Atlanta Area!! C.L.Bailey New Member Introductions 0 11-08-2007 03:03 PM
