Flexible Drywall
Old 09-13-2012, 06:50 PM   #1
jerzram's Avatar
Flexible Drywall
hi everyone im new to the site. i have a question i live in scranton pa. does anyone know where i can purchase flexible drywall, i hope somebody can point me in the right direction. thank u in advance
jerzram is offline
Old 09-13-2012, 07:08 PM   #2
Drywall & Painting Pro
Sir Mixalot's Avatar
Rewards Points: 18,067
Re: Flexible Drywall
1/4" is about as flexible as drywall gets. That I know of.
What are you trying to do?
Sir Mixalot is offline
Old 09-13-2012, 07:46 PM   #3
Tech Geek
WarriorWithWood's Avatar
Trade: Remodeling Guru
Rewards Points: 1,342
Welcome to the site. It sounds like you need to wet down 2 layers of 1/4" drywall. if that won't work you'll need to be a lot more specific.
-Dennis
WarriorWithWood is offline
Old 09-13-2012, 07:57 PM   #4
Ohio painter's Avatar
Trade: Painting and wallpaper
Rewards Points: 2,160
I am not in your trade but recall buying Hi-flex 1/4" drywall years ago. The claim at the time was you could wrap it around a five gallon bucket.
Do a google search for Hi-flex drywall should be lots of results.
Ohio painter is offline
The Following User Says Thank You to Ohio painter For This Useful Post:
Big Shoe (09-13-2012)
Old 09-13-2012, 08:26 PM   #5
manipulator of wood
I Mester's Avatar
Trade: general contractor
we double up on the 1/4" about as flexible as you can get. or can wet it down a bit to give it a little more flex.
I just love the smell of sawdust in the morning!
I Mester is offline
Old 09-13-2012, 08:32 PM   #6
Big Shoe's Avatar
Rewards Points: 1,718
1/4'' high flex.
check with your local drywall supplier.
Expect the Unexpected
Big Shoe is offline
Old 09-13-2012, 09:06 PM   #7
jerzram's Avatar
thank u everyone for replying im remodeling an old home and the bedroom had a 15 ft wall that had a 30 degree radius 17" off the floor. i ripped out the plaster and latts and now i have to make the same radius out of sheetrock. i found a video on you tube that showed flexible drywall but i could not locate any. if i use 2 sheets of 1/4" will it be flexible enough without cracking and do i install the first sheet and cover the first with the second sheet. Or does anyone know where i can purshase super flex. thanks
jerzram is offline
Old 09-13-2012, 09:21 PM   #8
Yes.
Check with your nearest drywall supply store (Not Home Depot or Lowes).
Here's a link http://www.certainteed.com/products/gypsum/313657
The manufacture is in Valley Forge, PA. Is that anywhere near Scranton?
Old 09-13-2012, 09:35 PM   #9
Every now and then poster
ohiohomedoctor's Avatar
Rewards Points: 3,544
The wetter it gets the more flexible it becomes. At one point you just have to use wacky board and hot mud..
ohiohomedoctor is offline
Old 09-13-2012, 09:52 PM   #10
iDAHOchris's Avatar
Trade: dRYWALL SPECIALIST
Rewards Points: 256
hers a couple round walls and ceilings done with 5/8 and 1/2
flexible drywall-sprintphoto_bbufpc.jpg   flexible drywall-sprintphoto_bih4gc.jpg   flexible drywall-sprintphoto_bovhmp.jpg   flexible drywall-sprintphoto_bypuvi.jpg
iDAHOchris is offline
The Following 8 Users Say Thank You to iDAHOchris For This Useful Post:
BlueRidgeGreen (10-25-2012), hdavis (09-14-2012), JSM_CC (09-24-2012), mikeswoods (06-28-2015), ohiohomedoctor (09-13-2012), Resta (09-23-2012), RiverBG (06-26-2015), Sir Mixalot (09-13-2012)
Old 09-13-2012, 09:59 PM   #11
Nice work Chris.
The Following User Says Thank You to Sir Mixalot For This Useful Post:
iDAHOchris (10-02-2012)
Old 09-13-2012, 10:10 PM   #12
Really Chris, fine looking dwall work sir.
The Following User Says Thank You to ohiohomedoctor For This Useful Post:
iDAHOchris (09-13-2012)
Old 09-14-2012, 05:34 AM   #13
Big Shoe's Avatar
Nice work.
We always would go with 1/2'' when possible...............That makes me wonder if that new ''lightweight'' rock will go around a radius like the old stuff did?
Like me and Mix said, HIGH FLEX 1/4'' from a drywall supplier.
Big Shoe is offline
The Following User Says Thank You to Big Shoe For This Useful Post:
iDAHOchris (09-15-2012)
Old 09-14-2012, 10:10 AM   #14
Red Adobe's Avatar
Trade: Metal Roofs, Sparky , Remodels and beer specialist
Rewards Points: 92
maybe call a plasterer.
You may well find youself over your head fast if you have never hung or taped a curve.....Or plan on lots of sanding
As a plasterer in the comercial side in the midwest we did alot, so when I moved here and found alot of the spanish style done in rock, I had to learn. Not saying its hard but there are things you can do and some that fail miserbly
Red Adobe is offline
Old 09-14-2012, 07:04 PM   #15
jerzram's Avatar
Thank u everyone for the replies i used 2 sheets of 1/4" worked well.
jerzram is offline
The Following 4 Users Say Thank You to jerzram For This Useful Post:
hdavis (09-14-2012), iDAHOchris (09-15-2012), mikeswoods (06-28-2015), WarriorWithWood (09-14-2012)
Old 09-14-2012, 09:04 PM   #16
Glad it worked out.
Get any pics?
Old 09-14-2012, 11:54 PM   #17
Stunt Carpenter's Avatar
Rewards Points: 896
That ceiling looks crazy. How did you get get the sphere shape
Stunt Carpenter is offline
Old 09-15-2012, 01:25 AM   #18
JR Shepstone's Avatar
Rewards Points: 1,550
Looks like pie shaped pieces. Lots of triangular pie shaped pieces. And lots of Advil.
JR Shepstone is online now
Old 09-15-2012, 08:46 AM   #19
iDAHOchris's Avatar
Rewards Points: 256
1/2" drywall on ceiling. Once we got a pattern it went good. Good framing also
Old 09-15-2012, 03:49 PM   #20
Snobnd's Avatar
Trade: Remodeling 30+ yrs
Rewards Points: 1,374
I love to work on curved walls and soffets.
"When the people fear their government, there is tyranny; when the government fears the people, there is liberty"
- Thomas Jefferson-
http://www.savingtherepublic.com/Main.html
Snobnd is online now
Made in USA product list J.C. General Discussion 344 12-24-2017 11:54 AM
autofeed screw guns for decks and/or drywall dale rex Tools & Equipment 11 02-24-2016 10:16 AM
Priming & Painting drywall Repairs, not new drywall mcgyver79 Painting & Finish Work 21 04-23-2013 04:47 PM
Drywall Takeoff Template frankrosales Drywall 2 04-26-2012 12:07 AM
Drywall GettingBy General Discussion 3 06-16-2011 01:58 PM
