Youngster
Trade: Builder / Consultant / Designer
A First For Me.
Surprisingly, this is the first time I've gotten myself into this situation. Drywallers set to come hang, tape, and mud over the next couple weeks. Inspector dragging his feet didn't get the 4-way passed and clearance sent to the gas company until today. Gas company now telling me that it'll likely be the first week in Jan. before they get the meter set. They reserve the right to take up to 30 days from receiving the inspection notice.
So I can't heat the place up. 4200s.f. and the outside temp last night was 2*F. I've always just had the furnace ready to go by this point. How should I heat the house from a drywaller's perspective. If it was just my guys framing I would just tell them to bundle up, but I'm pretty sure the joints are gonna pop if they tape in this cold weather. I also can't just heat it up during the day and then let it drop to 10* at night. Again, joints will pop. I've heard that the propane/kerosine/diesel heaters make the environment too humid, even though that is the most economical approach. The other issue is that the 170,000BTU fuel heaters can't really be left on all night. I don't really have $1,000 bucks right now to drop on a big electric heater. I could spend about $500 on several smaller electric radiant heaters that might just be able to keep the place above 50* at night. What do you guys think? Any suggestions would be nice. I'd rather not put the drywall on hold for 2 1/2 weeks. |
Trade: drywall applications
Re: A First For Me.
How come you cant leave the heaters on at night??? can you make a deal with a neighbor for power?? hook up a temp furnace and offer to pay the neighbors electric bill until you get hooked up.
Steve
Re: A First For Me.
I think he's already got power. Just no heat source.
Re: A First For Me.
i think you can convert a furnace to run on propane well i know you used to be able to. but yeah i would stay away from kerosene heaters, propane isnt such a big deal you'll find the mud will cause alot of humidity anyways.
Professional Instigator
Re: A First For Me.
Pull a meter off an old abandon house, slap it on the one your working at.
Trade: Drywall Taper
Re: A First For Me.
Just run propane. It is a pain and does cause humidity , but it is better than nothing. The Drywallers should understand that all is not perfect in our world.
Trade: Taper
Re: A First For Me.
Propane heaters are fine. Its a wet heat so it takes a little longer to dry but its fine.... at night just plug in a couple electric heaters 220 and you will be fine. Just make sure it doesn't go below 10C.
Trade: Drywall
Re: A First For Me.
If you have access to a rental company,Go and rent a big electric heater for awhile,No need to buy one.
Thom
Re: A First For Me.
You could swap out the orifices in the furnace for propane ones, run it off bottled propane until the gas meter is in place, then switch the orifices back.
Trade: drywall contractor
Re: A First For Me.
Fostoria makes a great portable electric heater that won't put moisture in the house and dries great. You can easily heat a two story house with 2000 sq ft on each floor. Takes a one hundred amp breaker. Fantastic heater, runs quiet and pulls the moisture out.
Profit is not dirty.
Trade: Residential Drywall and Taping
Re: A First For Me.
We are finishing a house and it has wood heat, but it cant keep up, so we have put in 4 220w electric construction heaters...many is florida in there...shorts, sweat..not to mention the mud dries fairly fast. and its -26c outside.
Profit is NOT a dirty word....Cheap is.... |
Trade: Electrician
Re: A First For Me.
cant you get a tank of gas for the furnace in place?
Re: A First For Me.
Did some one change something
and not send me the memo? I,ve used kerosene and propane sallys as well as propane radiant heaters. Maybe my finishers didn't know any better?
Darren@Partners
Trade: Drywall Contractor
Re: A First For Me.
We use propane salamanders eqiupped w/ thermostat. Can be run about 1 1/2 days per 100# LP bottle. We use kerosene over the hangers as easier to transport. That size house normally use one heater per floor and a smaller one for garage. Had a newer LP mushroom almost burn down a house once so make sure GL paid up. Crack a couple of windows to let the humidity out or will never dry. Can also use fans to help circulate heat in dead ends.
PS: use 12ga electric cord or thermostat won't cycle right!!!! Last edited by Darren@Partners; 12-18-2008 at 11:25 PM. Reason: forgot |
Youngster
Re: A First For Me.
Thanks for the responses guys. I would really love to be able to run a big electric heater but as I said before, I don't have $1,000+ $600 for electricity. Those things suck juice like crazy. I called around to see if anyone rents them around here, but no luck. Everyone just rents the propane salamanders
I suppose running the propane sallies all night isn't bad but it sure makes me nervous. Those things will torch a house faster than anything and insurance won't cover fire cause by those heaters. I'd thought about sticking the sally outside and ducting the heat in to help me sleep better at night, but everyone says that is a no-no also. |
Re: A First For Me.
Hire someone to fire watch...then you can sleep better. Give them a cot and a fire extinguisher.
#18 |
Re: A First For Me.
What about some those round units that screw on propane tanks. I have used them in a house once, but it belonged to us, and I do not remember how low the temp got. Set in middle of room and hope no one messes with them.
#19 |
Re: A First For Me.
#20 |
Re: A First For Me. |
