Fibafuse
Old 09-03-2011, 11:34 PM   #1
Alanwolf's Avatar
Trade: General
Fibafuse
Heard some issues with fibafuse paperless tape cracking. Wondering if it's just application error and if anyone uses it or prefers to use it over paper?
Alanwolf is offline
Old 09-04-2011, 01:33 AM   #2
Redliz75's Avatar
Trade: Female Electrician
Rewards Points: 250
Re: Fibafuse
When my home was built over 6 years ago they used mesh tape and everything looks as good as the day it was finished.
Redliz75 is offline
The Following User Says Thank You to Redliz75 For This Useful Post:
TNTSERVICES (09-05-2012)
Old 09-04-2011, 09:39 AM   #3
Alanwolf's Avatar
Trade: General
Re: Fibafuse
We may not be talking about the same product. Here's a link.
http://www.sg-adfors.com/Brands/Fiba...lReinforcement
Alanwolf is offline
Old 09-04-2011, 09:50 AM   #4
smuhhh's Avatar
Trade: Restorations
Rewards Points: 250
Re: Fibafuse
Know nothing about it but it sounds like a gimick.
smuhhh is offline
Old 09-04-2011, 10:18 AM   #5
doncando's Avatar
Trade: carpentry and painting
Rewards Points: 25
Re: Fibafuse
Fibafuse is a relatively new product and I haven't heard anything negative about it nor do I think it's a gimick.
I have used it very succesfully on butt joints. It seems to have at least as much strength as paper and significantly reduces the typical butt joint hump.
So yes, I prefer it over paper, but it's probably not necessary for inside corners or taper joints.
And, BTW, I don't care for fiberglass mesh tape.
doncando is offline
Old 09-04-2011, 12:09 PM   #6
Alanwolf's Avatar
Trade: General
Re: Fibafuse
I agree. I think it's better than paper looking at it similarly because it truly fuses with the compound. Wondering if it would be beneficial to use it over mesh rape for large gaps? On any joints, gave you noticed if you oversand it, do the hairs pop out or do they shave off?
Alanwolf is offline
Old 09-04-2011, 01:24 PM   #7
doncando's Avatar
Rewards Points: 25
Re: Fibafuse
For large gaps, Fibatape makes a 6" wide mesh tape that works well. That' the one I use for patching cracks in plaster.
Fibafuse does leave little "hairs" sticking up if you oversand, but a quick swipe with some sandpaper after priming takes care of it.
doncando is offline
Old 09-04-2011, 07:55 PM   #8
Alanwolf's Avatar
Trade: General
Re: Fibafuse
Do you think that fiba fuse is a product that could replace paper or will paper continue to be the standard
Alanwolf is offline
Old 09-04-2011, 09:12 PM   #9
doncando's Avatar
Rewards Points: 25
Re: Fibafuse
I think Fibabfuse COULD replace paper tape, but other than butt joints, there's no real advantage. Paper is strong enough, cheap enough, readily available, a well-tested product and in the hands of professional drywallers (which I am not) probably a little faster to install.
I keep Fibabfuse on hand mostly for repairs which, technically, are butt joints.
doncando is offline
Old 09-04-2011, 09:41 PM   #10
Alanwolf's Avatar
Trade: General
Re: Fibafuse
Looking at all the technical data it's clearly a superior product but of course that is supplied by the company.
Alanwolf is offline
Old 12-01-2011, 05:01 PM   #11
Kiwidude's Avatar
Trade: drywallnut/general B
Re: Fibafuse
I use paper tape in all my joints with hot mud.....as I do alot of smooth wall, and providing you have the right mix, won't have any cracking. Why would anyone want to change a proven method that is fool proof.
I am interested in learning more about fibafuse and would like to know how it will go with hot mud.
Hey Liz, if you have mesh you probably have texture and will not notice any cracks.
Kiwidude is offline
Old 12-01-2011, 05:15 PM   #12
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Rewards Points: 1,114
Re: Fibafuse
Paper can be tricky for the occasional installer. Bubbles behind the tape can be an issue. Fibafuse solves that problem. It's also much stronger than paper. Why wouldn't you want a solution like that?
Angus
angus242 is offline
The Following User Says Thank You to angus242 For This Useful Post:
intjonmiller (03-30-2014)
Old 12-01-2011, 07:58 PM   #13
VanGoghFinish's Avatar
Trade: Drywall
Rewards Points: 61
Re: Fibafuse
Can this Fibafuse be ran threw bango's or bazooka's?
VanGoghFinish is offline
Old 12-01-2011, 08:18 PM   #14
Kiwidude's Avatar
Re: Fibafuse
Angus, the only 3 reasons why there are bubbles behind the paper tape....1/ there is movement in the drywall when mudding and air is puffed in. 2/ the mix is too stiff or not enough. 3/ or ?
If you put paper tape tight between your hand and try pull it apart, you can't. I haven't tried that test with fibafuse yet, but I do look forward to seeing what it can do.
Angus, how do you know fibafuse is stronger?
Kiwidude is offline
Old 12-01-2011, 08:54 PM   #15
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Re: Fibafuse
From their sell sheet. They claim Fibafuse is 76% stronger then paper tape. Even if it's only 50%, it is still stronger. It's made from fiberglass.
I don't tape and mud often...actually hate doing it...but I'm forced to as I cannot get a pro drywaller to come tape and finish seams on 1 or 2 sheets of drywall in my bathroom remodels. To a pro like yourself, I'm sure paper tape is so easy, you could successfully install it in the dark while drunk. I struggle with paper. But beyond that, I don't use any kind of paper in my remodels. I use DensArmor drywall. I had been using a mold-resistant mesh tape but have now switched to FibaFuse. Only have tried it once but I like it. Easier to finish (to me) than much thicker mesh tape.
Angus
angus242 is offline
Old 12-02-2011, 05:44 AM   #16
Big Shoe's Avatar
Rewards Points: 1,718
Re: Fibafuse
The only times I've used paper with hot mud is with 45 or 90. And I rarely use paper at all anymore.
As far as Fibafuse ........are we talking about their 2'' mesh tape or that cloth-type sheet on the link of the OP??
Big Shoe is offline
Old 12-02-2011, 06:58 AM   #17
Grand Rapids Remodeling
Paulie's Avatar
Rewards Points: 2,052
Re: Fibafuse
If you view the video, 'ole Myron eventually gets to using tools with it. I have yet to try it and I doubt if there is a bathroom job big enough for me to use my bazooka with it so I'll probably never know. But I will try it in my next bathroom and hand tape.
I'll stick to using good 'ole paper on large jobs and wait for the feedback after this new product is vetted for a few years.
Paulie is offline
Old 12-02-2011, 12:47 PM   #18
Kiwidude's Avatar
Re: Fibafuse
I agree with Paulie .....
Hey big shoe....we are talking about the paper tape replacment which is 2" roll.
Kiwidude is offline
Old 12-03-2011, 06:52 PM   #19
Paulie's Avatar
Re: Fibafuse
Is Fiba Fuse self sticking like reg. mesh?
Paulie is offline
Old 12-03-2011, 07:03 PM   #20
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Re: Fibafuse
Nope. Installs just like paper.
Angus
angus242 is offline
Paulie (12-03-2011)
