Fastest Way To Get Hanging Done?
Old 10-23-2011, 04:01 AM   #1
Master of Rocket Science
finakat's Avatar
Rewards Points: 123
I want advice from the full time rockers, I have alot of drywall sidejobs coming up (small-residential) under 100 boards. Im using a panel lift / rotozip.
There's two of us; me and my partner who are both "mechanics" although he is less exp than me. Should I have him follow my lead as a glorified "helper" or should we both split up and hang separately as much as we can?? Trying to get this done quick and efficient and see what were capable of. Thanks.
finakat is offline
Old 10-23-2011, 08:30 AM   #2
Drywall & Painting Pro
Sir Mixalot's Avatar
Rewards Points: 18,145
Re: Fastest Way To Get Hanging Done?
Yep. I'd have him as my helper. Tack the boards up and let him finishing screwing them off while your cutting the next boards.
-Paul
Sir Mixalot is offline
The Following 3 Users Say Thank You to Sir Mixalot For This Useful Post:
ryanshull (08-04-2013), TiM Management (07-21-2013), ToolNut (08-03-2013)
Old 10-23-2011, 10:25 AM   #3
WICKED WOODCHUCKER
mnjconstruction's Avatar
Trade: Finish carpentry, drywall, Tile
Ive always found that using a helper is much faster then each hanging seperatley
mnjconstruction is offline
Old 10-23-2011, 10:28 AM   #4
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 3,558
Sub it out to some real hangers.
Warner Mill Works
Facebook
YouTube
WarnerConstInc. is online now
Old 10-23-2011, 11:05 AM   #5
SuperiorHIP's Avatar
Trade: Home Improvement Contractor
Rewards Points: 1,346
As I was reading the title I was thinking about everytime I need to get a sheetrock job done faster your response is the first through my head. All my drywall comes out perfect but anything over 10-20 sheets just takes too long.
SuperiorHIP is offline
Old 10-23-2011, 03:06 PM   #6
Head sawdust creator
Bummie's Avatar
Trade: Jack of All.... Master of a Couple
Rewards Points: 1,032
Hang big sheets on the ceiling together...tacking only as many nails as required to hold up sheet. Hang big sheets on the wall together... tacking only. Then split up and do the small stuff individually. One guy screws the place off as the other cleans up scraps.
OR
Sub out to some rockers!!!!!!
"Whether you think you can or think you can't.... you are right!!!" Henry Ford
Bummie is offline
Old 10-23-2011, 04:59 PM   #7
Want to play a game?
CrpntrFrk's Avatar
Trade: I do that too!
Rewards Points: 4,196
Get rid of the drywall jack! Those things take more time then putting it on your head and going to town.
As mentioned hang and tack with nails together. While he nails off you are measuring for the next sheet. When all large sheets are hung split up to do rippers, windows, corner bead, and screw off.
CrpntrFrk is offline
The Following 2 Users Say Thank You to CrpntrFrk For This Useful Post:
JWilliams (10-23-2011), tedanderson (07-21-2013)
Old 10-24-2011, 04:57 AM   #8
Big Shoe's Avatar
Rewards Points: 1,830
The better of the two needs to be the leader and the other the helper. And the ''helper'' needs to understand that. This would work best on new clean hanging.
Small remodels might work better to split up if it's alot of small stuff. And team up on the big sheets.
A good cutter can bury a helper.
And.............Forget the panel lift!
Big Shoe is online now
Old 10-24-2011, 08:34 AM   #9
finakat's Avatar
Rewards Points: 123
Thank you all very good insight, I appreciate it.
finakat is offline
Old 10-24-2011, 08:43 AM   #10
Profit is not dirty.
AARC Drywall's Avatar
Trade: Residential Drywall and Taping
Rewards Points: 268
The only time you should split up is when you are confidant that he is as good as your or better...and not to mention has the drive...otherwise, you are looking for a big headache..
Profit is NOT a dirty word....Cheap is....
AARC Drywall is offline
Old 10-24-2011, 10:36 AM   #11
ArchieOval's Avatar
Trade: LondonDeco
I had a similar problem recently. Leading installer assisted by a helper approach worked for me.
_____________
Archie, London Painters and Decorators
ArchieOval is offline
Old 10-24-2011, 06:20 PM   #12
VanGoghFinish's Avatar
Trade: Drywall
Rewards Points: 61
The fastest way would be to just sub it to me! lol Where ya from?
VanGoghFinish is offline
Old 11-08-2011, 04:52 PM   #13
finakat's Avatar
Rewards Points: 123
Lol, yeah I suppose it would be but im doing the job myself because I want to make the cash, im not the GC on this one. Im from jersey dude....
finakat is offline
Old 11-08-2011, 05:35 PM   #14
Fortune and glory, kid.
moorewarner's Avatar
Trade: Remodeler/Restorer
Rewards Points: 1,022
No one uses a lift for ceiling boards? Your head? really??
I still have a crik in my neck from the last ceiling I did like that in '85.
"If you don't have time to do it right, when are you going to have time to do it over?" ~ Wise Old Timer
moorewarner is offline
The Following 4 Users Say Thank You to moorewarner For This Useful Post:
deter (07-22-2013), jproffer (07-23-2013), Metro M & L (07-21-2013), ryanshull (08-04-2013)
Old 11-08-2011, 05:57 PM   #15
CrpntrFrk's Avatar
Yes really!! What a pain in the a$$ those stupid jacks are!! Spend more time effin around with them than getting the rock on the ceiling.
Seriously ....cut.....flip....up.....nail....done!!!
Sorry but as you can tell I don't like jacks unless you are all by your onesies.
mikeswoods (07-21-2013), TiM Management (07-23-2013)
Old 11-09-2011, 05:18 PM   #16
Designer/Contractor
Rio's Avatar
Rewards Points: 1,530
Well, I guess they are kind of wimpy but I love my Gypsy Jack; haven't used it for a while but man it was nice when putting up 4x12 sheets. We used that and a Senco strip screwer and a rotozip and it actually became kind of fun to do drywall!
No measuring and screwing up where outlet boxes went, just tack up the board and rotozip out the openings. It might not have been the fastest way to do it but it sure was easy
Rio is online now
Old 11-09-2011, 08:43 PM   #17
Balding quickly
BattleRidge's Avatar
Trade: The big stuff!
Rewards Points: 588
well dont use you head, you just make it so your elbow locks in when the rock hits the ceiling, then you hold it and have a clear view of where to screw.
www.battleridgebuilders.com
BattleRidge is offline
The Following User Says Thank You to BattleRidge For This Useful Post:
iDAHOchris (08-10-2013)
Old 11-10-2011, 05:03 AM   #18
Big Shoe's Avatar
Back when we nailed ceilings we held boards up with our heads. Everyone did it that way. Chicago burbs in the 70's.
We had a couple guys that hung whole houses by themselves. They used those machines/lifts to hang ceilings and walls. Back in those days we were not pushed to get a house hung in a day!
When I moved to Florida we adjusted our benches to straight arm the board up so we could screw it up. No more nailing.
Then we were turned on to 3 man team, two hold it up and one screwing. 8' ceilings.
And the there is the ''kick-stick'' method. Where you prop/wedge the T-pole under the board to hold it up.
Did I miss any techniques? Enlighten me.
The Following 2 Users Say Thank You to Big Shoe For This Useful Post:
j_sims (07-27-2013), TiM Management (07-23-2013)
Old 11-10-2011, 08:51 AM   #19
Rewards Points: 268
Jacks are a waist of time, and money... I suppose they are fine if you only have yourself and a few sheets, and you have not friends..
The Following 3 Users Say Thank You to AARC Drywall For This Useful Post:
Big Shoe (11-10-2011), CrpntrFrk (11-10-2011), TiM Management (07-23-2013)
Old 11-10-2011, 01:24 PM   #20
Livin the dream...
Spencer's Avatar
Trade: Remodeling/Finish Carpentry
Rewards Points: 5,496
I agree. Jacks are slow. But so are most guys after that hang rock the hard way for about 10-15 years.
I know a couple drywall contractors who had to throw in the towel because they had such bad neck problems. It was either quit or live with pain the rest of your life.
I've got a lot respect for rockers. I can slap on shingles and love it all summer long, hanging rock sucks but is much better with guys who know what they're doing. I've watched a couple crews who can hang super fast and make it look effortless.
Lewis Carpentry
Spencer is offline
The Following 2 Users Say Thank You to Spencer For This Useful Post:
moorewarner (11-10-2011), tenon0774 (04-21-2013)
Hanging Crew Wanted - Kansas City Metro mds120 Help Wanted or Looking For Work 0 05-21-2011 08:17 AM
Hanging Doors-What causes this... BC Carpenter Windows, Siding and Doors 10 01-12-2011 01:57 PM
Pocket door hanging hardware. loneframer Finish Carpentry 32 05-21-2010 05:29 AM
hanging wire p.e. Drywall 4 01-20-2010 10:00 PM
Hanging a floating vanity Gus Dering Finish Carpentry 28 05-08-2009 09:22 PM
