Fast Mud Repair
Old 05-24-2012, 10:23 PM   #21
rselectric1's Avatar
Rewards Points: 560
Re: Fast Mud Repair
I saw my drywall guy just yesterday do 3 coats of "5" on a smaller patch (shower ceiling) and had it paint ready in less then 3 hours total (INCLUDING dry time). Yes they had a hair dryer.
Amazing. It only needed a touch of feathering around the edges. So yes it's possible with a pro doing it.
rselectric1 is offline
Old 05-24-2012, 10:27 PM   #22
President of the world
world llc's Avatar
Trade: general contractor
Rewards Points: 2,001
Re: Fast Mud Repair
it was your hole, wasn't it?!
damn sparky's....
world llc is offline
The Following 2 Users Say Thank You to world llc For This Useful Post:
iDAHOchris (05-25-2012), Red Adobe (05-25-2012)
Old 05-24-2012, 10:59 PM   #23
BCConstruction's Avatar
Trade: Construction
Rewards Points: 2,394
Re: Fast Mud Repair
Shows how slow I am at muddying lol. I honestly would have 1/5 a bag on the wall before it went off.
www.bcconstructionllc.com
BCConstruction is offline
Old 05-24-2012, 11:04 PM   #24
Rewards Points: 560
Re: Fast Mud Repair
damn sparky's....
Kinda sorta!
Old 05-25-2012, 07:04 AM   #25
hdavis's Avatar
Rewards Points: 4,559
Re: Fast Mud Repair
Originally Posted by 72chevy4x4 View Post
an important note mentioned earlier is not too thick of a base coat.
I had the heat gun out today trying to move a time sensative patch along...but how much does heat help setting compound?
After it has set, it dries it right out. Before it has set, there's a risk you dry it before it has set all the way, leaving weak compound.
hdavis is online now
Old 05-25-2012, 08:46 AM   #26
boman47k's Avatar
Rewards Points: 2,006
Re: Fast Mud Repair
20 is about as fast as I want to try. I feel like if I tried 5 min in my mud pan for a small repair, I would wind up with my 2" putty knife I use mix it with stuck in a rock.
Or does it stay plliable as long as it is being mixed?
boman47k is offline
Old 05-25-2012, 09:31 AM   #27
I'm on a boat!
J L's Avatar
Trade: Yacht carpenter
Rewards Points: 3,402
Re: Fast Mud Repair
Originally Posted by Sir Mixalot View Post
Ok good.
Two coats of 5 minute mud.
Final skim of thinned AP.
Then use a Heat gun:
That's exactly what we do too. I just did it on Wed. minus the heat gun as we didn't need to paint the same day so I had time to let it dry.
J L is offline
Old 05-26-2012, 07:42 AM   #28
Gary H's Avatar
Rewards Points: 2,342
Re: Fast Mud Repair
I use those cheap plastic pans for hot mud. after it gets hard in the pan , just twist it and it falls right out. Ready for the next batch.
Gary H is offline
Old 05-26-2012, 08:59 AM   #29
katoman's Avatar
Trade: carpenter
Rewards Points: 2,000
Re: Fast Mud Repair
You guys should try this - buy a bag of quick set plaster. Mix it 50/50 with sandable 90.
I keep this in a pail. Now all I have to do is mix it when on site.
The plaster lets you trowel it smooth as it sets. No sanding required.
It seems if you can't buy it in a bag, nobody wants it. My plasterer showed me this trick 30 years ago.
katoman is offline
The Following User Says Thank You to katoman For This Useful Post:
hdavis (05-26-2012)
Old 05-27-2012, 12:14 PM   #30
pro
hangit's Avatar
Trade: wallpaper & fabric installation
Rewards Points: 165
Re: Fast Mud Repair
for small patches there is a neat trick to over cut the patch piece and score and snap the back to size leaving 1 to 2" of paper on the face to bed into 5 minute mud. that and a heat gun, youll be home in time for lunch!
It's called a "hot patch". Used to do them a lot.
Also, cut piece of drywall to size, screw a piece of wood backer to inside wall (i usually use 5 gallon paint sticks, cut to size), then put patch in, screw to backer, tape,mud,etc.
I know a couple people who took a piece of builders paper, dipped it in Gardz, then placed it over a hole and smoothed it out. Said it dried incredibly hard. May be good for anything less than 2"
Nowadays, I just buy the peel and stick metal patches. They're too easy, and they're quick.
hangit is online now
Need to hire full time repair man/woman in phoenix arizona, now!! Phoenix8 Help Wanted or Looking For Work 24 05-16-2012 05:39 PM
Tool repair - small items Hmbldr Tools & Equipment 11 05-10-2012 07:55 PM
Roof repair, what to do? offshorehs Roofing 15 02-19-2012 11:25 PM
RSmeans Repair and Remodeling Cost Data aghdonmc General Discussion 7 08-20-2010 04:39 PM
Wall Repair Old Building Linex General Discussion 3 05-17-2009 03:29 PM
