Evaluating Fibafuse Tape
Old 04-04-2017, 08:16 PM   #1
artinall's Avatar
Trade: Repairs & Finishing
Rewards Points: 974
Fibafuse seems to offer low build qualities (less tapering) & strength...
Does it offer any real worthwhile antimicrobial properties? One customer told me his prior drywallers wanted to apply it but he refused, thinking mold in the lower basement may catch hold in the tape.
What I really want, now that I've taped with it on several patches, and before I have it over a multitude of projects (only recently) -- is how strong it holds relative to paper tape. Is it really stronger even on larger patches secured 16" on center even? Over time?
artinall is offline
The Following User Says Thank You to artinall For This Useful Post:
Big Shoe (04-08-2017)
Old 04-04-2017, 09:19 PM   #2
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 1,195
Re: Evaluating Fibafuse Tape
No, but think about it. It's made of glass. Not a microbe killer, but certainly not something yummy for them. It's essentially neutral.
As for strength, good question. In the raw, it tears more easily than paper when stressed at 90. But I would venture to say that when embedded, it would be stronger longitudinally than paper.
Tinstaafl is offline
Old 04-04-2017, 09:28 PM   #3
hdavis's Avatar
Rewards Points: 4,665
Cut a square of it, and grab two opposing corners, then pull. Notice how it stretches? It's like mesh in that regard, just not as bad.
Paper is better when you have framing movement.
hdavis is online now
Old 04-04-2017, 10:33 PM   #4
donerightwyo's Avatar
Trade: custom builder
Rewards Points: 568
It makes me itch just looking at it
I can't compete with hacks.
donerightwyo is offline
The Following User Says Thank You to donerightwyo For This Useful Post:
BlueRidgeGreen (04-08-2017)
Old 04-04-2017, 11:26 PM   #5
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 10,672
It's nice to work with.
Sent from my Nexus 6P using Tapatalk
Inner10 is online now
Old 04-04-2017, 11:33 PM   #6
VinylHanger's Avatar
Rewards Points: 7,050
I don't use anything else these days.
VinylHanger is offline
Old 04-05-2017, 01:13 AM   #7
Want to play a game?
CrpntrFrk's Avatar
Trade: I do that too!
Rewards Points: 4,196
Yeah....don't put that crap in your pocket and forget about it.....don't ask me how I know that. Lol
CrpntrFrk is offline
The Following User Says Thank You to CrpntrFrk For This Useful Post:
donerightwyo (04-10-2017)
Old 04-05-2017, 04:30 AM   #8
John1957's Avatar
Trade: Home Improvement
Rewards Points: 212
I use Fibafuse, and I can't say that it is any better or worse than ordinary mesh when it comes to repair work. I have seen it crack at factory edges and butt joints just as often I have with paper or regular mesh. Most often, it had been applied improperly, as I have been running into a lot of repairs the past 4-5 years with Fibafuse bedded in with regular mud and seeing the fiber ends sticking out the through the finish in slick walls and ceilings.
My only serious knock against Fibafuse is when I am doing patch work repairs over thick nugget knockdown finished walls. Regular mesh seems to be a little more pliable and takes less hot mud to feather the repair into the surrounding area. The ends of the Fibafuse strands are a little more rigid and will tend to pop through the hot mud unless I coat it more heavily and bust the repair out wider before tooling it down with a 6" knife as it sets off.
With that said, Fibafuse does make a thinner mesh, and I have 4 rolls of it on the shelf out in the garage. I will try the thinner stuff eventually and how see how it works.
As far as it's ability to withstand mold? It is a nice marketing ploy, but why would I care about this at all? If you have mold at the board joints, then you have a much more serious problem than worrying about the type of tape you have been using.
John1957 is offline
Old 04-05-2017, 08:50 AM   #9
artinall's Avatar
Rewards Points: 974
Just not be clear - this is about 'fibafuse' tape and not 'fibatape' mesh.
Definitely some confusion in the way they did the naming...
artinall is offline
Old 04-05-2017, 12:37 PM   #10
Don't use anything else. Lays smooth, quick and clean. I had to scrounge up some paper for a repair a while back and it was like going back to the 90's. 1890's.
Old 04-08-2017, 05:39 AM   #11
Big Shoe's Avatar
Rewards Points: 1,720
Yes. True.
Expect the Unexpected
Big Shoe is offline
Old 04-08-2017, 05:45 AM   #12
Big Shoe's Avatar
I stick with mesh. Fibafuse is a pain for me. It tears and leave strands and also seems to want to raise up more. Not to mention trying to find the end on the roll.
And for you new guys......I'm 100% patch and repair. No time for paper. New construction, whole houses always get paper here.
And they never sent me my free roll. How long ago was that????
Big Shoe is offline
Old 09-15-2017, 08:12 PM   #13
Profit is not dirty.
AARC Drywall's Avatar
Trade: Residential Drywall and Taping
Rewards Points: 266
Fibrafuse is the way of the future, I use it all the time, Cleaner, less chance of air bubbles, but there is one drawback... in the angles. I likes to tear when flushing it, or at least i find it to do that.
Runs through the autotaper easily, coats over nicley, dries quicker than paper tape.
All in all a great product. It costs more, but it evens out if you cut any call backs out of the equation.
Profit is NOT a dirty word....Cheap is....
AARC Drywall is offline
Old 09-16-2017, 09:33 PM   #14
artinall's Avatar
Rewards Points: 974
Originally Posted by AARC Drywall View Post
Fibrafuse is the way of the future, I use it all the time, Cleaner, less chance of air bubbles, but there is one drawback... in the angles. I likes to tear when flushing it, or at least i find it to do that...
I get that too. Which begs the question - can paper tape be applied overtop the fibafuse, are the two "compatible".
Like for a ceiling or wall patch that includes the corner?
artinall is offline
Old 09-16-2017, 09:44 PM   #15
Capra aegagrus
Tinstaafl's Avatar
Fibafuse "integrates" with compound better than paper tape; I'd be confident paper over fibafuse would work even better than the converse.
Which still begs the question: Why would you use fibafuse in a corner to begin with, since you know it's susceptible to that tearing? Leaving aside the fact that a guy with a good touch can do that.
Old 09-16-2017, 10:05 PM   #16
avenge's Avatar
Rewards Points: 2,612
I'll use fibafuse over paper all day long except in corners unless you're Hispanic and use your hands to apply mud. I have repaired mesh countless times and refuse to use it, it's junk.
And what do you mean "compatible'???? I use paper or something like Strait flex in corners, fibafuse on flats does that mean something's going happen where they overlap? It's not like they adhere to each other without mud.
avenge is offline
Old 09-16-2017, 10:06 PM   #17
artinall's Avatar
Rewards Points: 974
Which begs the question yet further, even for a guy with such a touch as my own would consider, given the advantage of fibafuse on the remaining sides versus what lingering uncertainty of compatibility remains...
I'm repairing mesh on the job I'm on right now.
Any time dissimilar materials are being used in contact with one another I tend to question ...
artinall is offline
Old 09-16-2017, 10:39 PM   #18
hdavis's Avatar
Fibafuse over or under paper - doesn't matter.
I'll run corners with it. Light touch with a drywall knife, or if you have a corner trowel worth picking up (most aren't), they're a breeze.
Old 09-16-2017, 10:51 PM   #19
avenge's Avatar
As I said paper and fibafuse need mud to stick so how can they be in direct contact with each other. Paper tape is paper, drywall is paper so I guess we can't use fibafuse in contact with drywall paper? Thank goodness there's mud between them.
avenge is offline
The Following User Says Thank You to avenge For This Useful Post:
artinall (09-17-2017)
Old 09-17-2017, 10:03 AM   #20
artinall's Avatar
Rewards Points: 974
Point taken.
artinall is offline
Water resistant tape measures. carsonbdavis Tools & Equipment 8 07-19-2015 09:29 PM
Mud over tape hillbilly512 Drywall 22 02-06-2015 11:28 PM
Blue tape, suddenly seems useless VinylHanger Painting & Finish Work 37 05-16-2014 07:03 AM
1/2" tape problems cleveman Plumbing 8 12-24-2011 10:24 AM
Help. Self Adhesive paper tape problem. jstrand23 Drywall 1 11-28-2007 02:09 PM
