Estimating Corner Bead Repair
Old 10-25-2017, 04:54 AM   #1
artinall's Avatar
Trade: Repairs & Finishing
Rewards Points: 1,210
I've done estimating. Although when it comes to digging out, re-securing, patch and skim the failing corners I've found them to be angels of deception to say to the least.
Time and effort can vary by a factor of 2-3. You just never know what the removal will be until you execute, at least IMHO.
Anyone else run into this? Only real answer to take what you think X 2 or X 3 ?
artinall is offline
Old 10-25-2017, 09:11 AM   #2
KAP's Avatar
Trade: Custom
Rewards Points: 25,904
Re: Estimating Corner Bead Repair
When estimating something that can have variations in time it takes to complete when a fairly solid time estimate isn't really feasible, we add in a fudge factor to accommodate for it and is different depending what's being done, do it on T&M or advise the customer that the final number is subject to revision within a percentage rannge...
After that, it's one of the reasons you have profit built into each project to pay your company to create Capital Reserves / Emergency Fund so it can absorb things you can't realistically go back and charge for...
KAP is offline
Old 10-26-2017, 01:08 AM   #3
artinall's Avatar
Current customer was unwilling to go T&M. They wanted a hard number, combined with paint.
Another part of the problem is that if fixing cracking corners is being combined with say, painting, and the other areas are being patched, then leaving the corners undone becomes glaringly obvious on the completed project set against the otherwise solid wall surfaces. - That phenomenon of where when some things are patched and made hidden, the next most visible defect becomes greatly accentuated.
And just who is willing to go for $150 to $200+ per corner? Virtually no one from my experience and I've done a lot of drywall correction with varied customers. Which is why most corners are simply left as is, or so many get caulk incorrectly smeared across them.
artinall is offline
Old 10-26-2017, 07:09 AM   #4
KAP's Avatar
Trade: Custom
Sometimes as much as we want it to be (who likes wasting time) we have to realize that not everyone is our customer no matter how hard we may try to accommodate their "preferences"...
No matter how you arrive at the number using the various methods, charge what you need to charge for it to make sense... if it doesn't make sense for either one of you, well...
NEXT !...
KAP is offline
The Following User Says Thank You to KAP For This Useful Post:
artinall (10-26-2017)
Old 10-26-2017, 07:15 AM   #5
artinall's Avatar
NEXT !...
I agree.
artinall is offline
The Following User Says Thank You to artinall For This Useful Post:
KAP (10-26-2017)
Old 10-26-2017, 07:18 AM   #6
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 11,588
T&m
Inner10 is online now
Old 10-26-2017, 07:25 AM   #7
KAP's Avatar
Trade: Custom
Originally Posted by Inner10 View Post
T&m
KAP is offline
Old 10-26-2017, 08:22 AM   #8
Big Johnson's Avatar
Trade: Contractor and Grunt
Rewards Points: 2,474
I agree.
How many are there? If there's 1 I can see $200-$250 but if there's a bunch that should lower your price per corner significantly. Also how bad are they? I've repaired corners that looked good overall but had one spot cracked. Drive in a few screws and mud. I've also had some that were just installed wrong so the layer of mud was paper thin, those had to be redone. Paint is paint, if they want the whole room painted after you fix the corners that would be $***x.
Big Johnson is online now
Old 10-26-2017, 08:26 AM   #9
This space for lease
RangoWA's Avatar
Trade: General
Rewards Points: 4,628
Bid it high enough to cover the worse case scenario.
Bid it low enough to secure the job and work for hamburger flipper wages.
Offer time and materials work.
Those are your options. Their problem isn't your problem unless you make it so.
RangoWA is offline
The Following User Says Thank You to RangoWA For This Useful Post:
Workingmanvan (10-26-2017)
Old 10-26-2017, 01:57 PM   #10
Inner10's Avatar
Guess I should read eh...
Sent from my Nexus 6P using Tapatalk
Old 10-26-2017, 02:43 PM   #11
sparehair's Avatar
Trade: Painting, flooring
Rewards Points: 1,082
You should just bid it including skimcoating all walls to level 5. Otherwise theyll be pissed the texture isnt the same.
sparehair is offline
The Following User Says Thank You to sparehair For This Useful Post:
KAP (10-26-2017)
Old 10-26-2017, 06:01 PM   #12
artinall's Avatar
There are about six outside and a couple inside. The metal outside I started removal and found there were hardly any nails holding the thing on...flimsy.
artinall is offline
Old 10-26-2017, 06:05 PM   #13
John the Builder
SmallTownGuy's Avatar
Trade: Carpenter/Builder
Rewards Points: 8,976
The way it should be.
SmallTownGuy is online now
Old 10-26-2017, 11:35 PM   #14
Workingmanvan's Avatar
Trade: Carpenter-Renovations/Repairs
Rewards Points: 276
I would just visualize how long it will take, and give them a number on that.
For painting, I would just state that simply painting the repair may not result in a seamless blend, especially with an older paint job, and you would recommend painting the wall corner to corner with any repaired areas. If it is that many corners it may be time for a repaint of the place if you talk it up the right way, I think it would make sense with that many repairs being done.
Other than that, think of how long it will take to rip off the damaged beads, re-set new ones or repair existing as necessary. 1-2 more coats as needed. Poly off area if necessary before sanding. Sand, prime, paint however much they are willing to pay for. Remember to include set up and clean up time. Think of it in terms of days spent there, not hours.. That's what helped me get better at estimating stuff like this anyways.
I'd just factor in time fooling around with fast set or whatever else if a corner needed some work once you ripped the bead off. Might be easier just to replace the beads than re-set old ones.
and your price is your price, I wouldn't adjust it for someone else's needs, only the scope.
Workingmanvan is offline
paper corner bead and setting compounds James Brothers Drywall Picture Post 36 06-05-2013 11:59 AM
Paper Faced Metal Bead... or??? Rich D. Drywall 27 01-12-2013 12:22 PM
any tricks for switching to rounded corner bead mas Drywall 3 08-22-2006 09:14 AM
When you cant screw corner bead to a stud Phil Drywall 22 05-12-2006 11:27 PM
Remove corner bead or not? Mike Finley Drywall 5 11-18-2005 05:48 PM
