Eifs
Old 10-07-2009, 08:13 PM   #1
Tim0282's Avatar
Trade: drywall contractor
Eifs
Do any of you guys do any EIFS? I have a question on applying base coat. Wondering if anybody sprays on the base and trowels the mesh into it. Seems like it should work if you sprayed on heavy enough and thick enough.
Tim0282 is offline
Old 10-08-2009, 08:44 PM   #2
plazaman's Avatar
Re: Eifs
EIFS basecoat is not something you want to leave on thick. If too thick, it will crack. The thickness of the final product should be just enough that no mesh showing. I dont see a reason to spray basecoats unless you have really large flat areas of walls. Plus you'll need a team of plasterers to do the final finishing.
plazaman is online now
Old 10-08-2009, 10:09 PM   #3
Plaster Guy's Avatar
Trade: Plaster/Drywall
Re: Eifs
I do quite a bit of EIFS. Never sprayed the base coat or heard of anyone else spraying it. (Spray finish all day long though.) I usually precut my mesh, spread the section, embed the mesh, then take all my lines out and leave it flat. If you have a couple good plasterers I don't see how a sprayer would save a lot of time since you can't get too far ahead with the mud anyway or it will dry out before you get mesh in it.
Plaster On.
Plaster Guy is offline
Re-Stucco Application Hard Coat EIFS plazaman Masonry 12 08-10-2009 12:06 AM
Installing replacement windows in EIFS or stucco thatguy Windows, Siding and Doors 0 03-26-2009 11:51 AM
EIFS tearoff Swhit Masonry 15 10-20-2008 10:51 PM
eifs problem Dorin Morgos Masonry 24 10-05-2008 04:10 PM
tenting in over EIFS 6stringmason Masonry 5 12-10-2007 06:48 AM
