Drywall Screw Length Vs Vapor Barrier
Old 02-08-2009, 12:13 PM   #1
blacksheep's Avatar
Trade: homebuilder
Send a message via AIM to blacksheep Send a message via MSN to blacksheep
hi to all,.
I know this site is mainly for professional builders; I'm just a lowly amateur among you but I'm in the finishing stages of building my own home (see attachment, old picture) which has been a fantastic project
I learned a lot of things from this site but now I have a pretty specific drywall-related question that I've been unable to find an answer for.
I hope this forum of professionals can help me out.
I'm putting up 5/8" X-type drywall on my garage ceiling. It will be screwed into 1x4 furring strips (in fact 3/4" thick, as you all know) which are nailed into the trusses. Sandwiched between the trusses and furring is a .006" poly vapor retarder. R40 cellulose will be blown in there afterwards.
If I use the recommended 1 5/8" screws to hang the sheetrock, the screw tips will stick out about 1/4" past the furring strip. All these screw tips will end up puncturing the vapor retarder.
Is this an accepted practise? If not, is there an alternative?
Thanks in advance!
blacksheep is offline
Old 02-08-2009, 12:21 PM   #2
precisionbuild's Avatar
Trade: Contractor
Re: Drywall Screw Length Vs Vapor Barrier
Originally Posted by blacksheep View Post
hi to all,.
Thanks in advance!
1. Your Question: That's fine.
2. Why all the strips on your Tyvek?
3. They are gonna make you go over to the sister DIY site.
precisionbuild is offline
The Following User Says Thank You to precisionbuild For This Useful Post:
blacksheep (02-08-2009)
Old 02-08-2009, 12:31 PM   #3
blacksheep's Avatar
Trade: homebuilder
So it's accepted practise? Great, thanks!
they're only to keep it from flapping around until I do the exterior finish. Everything will be covered up with styrofoam ine one way or another.
Ground floor will be Permacon Sure-Touch stone (styrofoam backed system ... I can't post a link since my post count is too low) and the rest will be James Hardie over 1" styrofoam with a few areas done in Dryvit acrylic
that's possible ... I hope I can still access this forum for stuff I can't get answered elsewhere. Sometimes there's no substitute for a real pro
Old 02-08-2009, 12:37 PM   #4
And always will be.
......there's no substitute for a real pro
So very true.
Please don't feed the TROLLS!
neolitic is offline
Old 02-08-2009, 05:34 PM   #5
Tim0282's Avatar
Trade: drywall contractor
Blacksheep, why did you use the 1x4 on the bottom of the truss?
Tim0282 is offline
Old 02-08-2009, 07:08 PM   #6
blacksheep's Avatar
Trade: homebuilder
there's a 12' wide livable area above the garage, so I had to add trimmers and additional 2x10's in between trusses to get 12" OC floor support
there's a little difference in height between the trusses, the connectors and the additional 2x10's, so the 1x4's (installed perpendicular to the trusses) help even things out.
Also, I guess that's just "how things are done" around here, I've never seen sheetrock applied directly to the trusses in any local building
Old 02-08-2009, 08:14 PM   #7
dlcj's Avatar
Trade: home builder carpenter Central Alabama
I was wondering why you had to fur the trusses with 1x4s too. I see why now and thats understandable but no its not standard practice and i have never done or seen it done with out it being a special case like you have there. Most around here would have used floor trusess or I-joist on that floor and stick built the roof. Looks good anyway
dlcj is offline
Old 02-08-2009, 09:01 PM   #8
Back from the dead...
ProWallGuy's Avatar
Trade: Paperhanger/Painter
Thanks for posting on ContractorTalk.com. The Moderators of this forum would prefer if you post Do It Yourself related topics on our sister site www.DIYChatroom.com
ContractorTalk.com is designed for professional contractor's to discuss issues and topics related to the construction and remodeling industries. Many of our professional contractors are also members at DIYChatroom.com and are looking forward to assist you with your needs.
Please take a moment to post your question at www.DIYChatroom.com If your not already a member of DIYChatroom.com you can sign up for a free account by going to http://www.DIYChatroom.com/register.php/
We apologize for any inconvenience that this may have caused. This thread has been closed.
ProWallGuy is offline
Drywall Scratches - Level 5 Smoothwall HUNG BY FOOT Drywall 15 03-10-2009 06:19 AM
Any Of You Guys Use This Drywall? Ed the Roofer Drywall 12 03-02-2009 11:16 AM
drywall romaina-europe crystal Drywall 20 02-08-2009 05:28 PM
Screw length for fastening 2 x Ipe? Chris G Decks & Fencing 9 09-18-2008 07:50 PM
How much advantage is 5/8 drywall over 1/2"? Jim S. Drywall 2 08-26-2008 11:52 AM
