Drywall Sanders
Old 03-11-2008, 09:54 PM   #1
Worm Drive's Avatar
Trade: carpenter
Drywall Sanders
Anyone tried any of the porter cable knock offs (sand tech, big jack, ect.)? Found some pretty cheap on ebay and don't do enough rock to justify buying a new P.C. @ $900-$1000. Don't want to end up with a P.O.S., though. Any thoughts?
Worm Drive is offline
Old 03-11-2008, 10:02 PM   #2
BUTCHERMAN's Avatar
Trade: DRYWALL PROFESSIONAL
Re: Drywall Sanders
If you just by the head you can use the contractor shop vac. The shop vac is about 80 dollars at lowes. Just make sure you run two cords because you lose the outlet on the vac and the auto control (it isn't worth $200). Also make sure you use bags or the fliter will clog in seconds. All together it should cost between $500 & $600 dollars.
BUTCHERMAN is offline
Old 03-12-2008, 09:00 PM   #3
Tim0282's Avatar
Trade: drywall contractor
Re: Drywall Sanders
You can buy a Porter Cable for little over 700. If you're buying a knock off for 500-600, I think you're better off spending the extra on the real thing. Or wait a couple months and buy the one Festool has in the UK. It is hard to beat the real McCoy.
Just my not so humble opinion...
Tim
Tim0282 is offline
Old 03-12-2008, 09:56 PM   #4
Worm Drive's Avatar
Trade: carpenter
Re: Drywall Sanders
The knock offs I looked at were around $200 for the sanding head w
/ hose. I have a couple shop vacs, if I can figure out how to mount a bag on the intake. $700 would still be more than I could justify spending, I haven't even bothered pricing the festool, I'm sure that's way out of my price range.
http://cgi.ebay.com/NIB-Portable-Var...QQcmdZViewItem
Old 03-12-2008, 10:19 PM   #5
BUTCHERMAN's Avatar
Re: Drywall Sanders
It's easy, open the shop vac. Take off the hose. On the inside where the hose comes in there should be a small black thing that slides up. Take this thing out and plug it into the bag (make sure the bags are shop vac bags for what ever gallon size your shop vac is). Then slide the piece with the bag on it back in place. Reconect the hose and you are set. Also i forgot to mention you may want to go to lowes and get a double end connector. You could go directly in, but i find the longer hose works better. The piece sort of looks like an ice cream scoop comming through a wall ( in case you need to buy one). If you have to buy one look at the store models to be sure you get the right one.
Old 03-13-2008, 12:15 AM   #6
Worm Drive's Avatar
Trade: carpenter
Re: Drywall Sanders
cool, thanks.
Old 03-13-2008, 05:17 AM   #7
BUTCHERMAN's Avatar
Re: Drywall Sanders
No problem, good luck.
Old 03-13-2008, 06:05 PM   #8
Tony M's Avatar
Trade: Drylining
Re: Drywall Sanders
Tim
Am picking up a Festool tomorrow to try. Will let you know my thoughts on it.
Tony M is offline
Old 03-13-2008, 08:07 PM   #9
Tim0282's Avatar
Re: Drywall Sanders
Tony, I'd like to know what you think. I have most of their wood working tools. Really well made stuff. We can't get the drywall sander, yet. They are working through the electrical part. Should be available this summer, they say.
Tim0282 is offline
Old 03-13-2008, 09:08 PM   #10
Sharp Improvements
Norrrrrrrrrrrrm's Avatar
Re: Drywall Sanders
Do you know if H.D. carries these bags for the rigid vacs? I have a 16 gallon and would like to try this. Thanks.
Norman Sharp
http://www.sharpimprovements.com
Norrrrrrrrrrrrm is offline
Old 03-13-2008, 09:53 PM   #11
BUTCHERMAN's Avatar
Re: Drywall Sanders
I would think so. I don't use rigid but in the N.Y. area home depot does carry rigid. Shop vac bags may work also if the hose setup is the same. If you can get a bag rigid should work as well.
Old 03-13-2008, 11:52 PM   #12
Sharp Improvements
Re: Drywall Sanders
So I have been doing a little research on the set-up for the P.C. and the P.C. system appears to be efficient for dust collection. Does the P.C. sander and a personal shop vac w/bag do a good job for dust? what would you rate it from 1-10? Have you used the P.C. compared to your set-up? I would like to save money if possible. I see the P.C. sander from tool king for $250, Is it better to stick with my personal vac and bag system? I am mostly concerned about dust and clean up. If the P.C. is woth it, I would factor the price of the unit into the job price. I figure the less you have to clean the more money I make in the long run. Thanks.
Norman Sharp
Old 03-14-2008, 05:56 AM   #13
BUTCHERMAN's Avatar
Re: Drywall Sanders
As far as results go, the same no difference. You lose the ability to plug the sander into the vac and turn the vac on and off from the sander. if it were not as good i would'nt use it. By the way, i maybe be wrong, i beleive shop vac makes the porter cable vac.
Old 07-16-2009, 03:57 PM   #14
Hammerstein's Avatar
Trade: Drywall
Re: Drywall Sanders
Did you get the Festool Planex? What do you think of it? How complete is the dust extraction?
Hammerstein is offline
Old 07-16-2009, 05:02 PM   #15
Home Depot aisle walker
willworkforbeer's Avatar
Trade: home remodeling
Re: Drywall Sanders
I bought one of these and it works great, dont use it a lot so cant vouch for its reliability, $180 now http://www.kingdrywall.com/Default.asp?Redirected=Y
willworkforbeer is offline
Old 07-16-2009, 07:33 PM   #16
Jeff
jkfox624's Avatar
Trade: master turd burglar
Re: Drywall Sanders
Does the one from king have an articulating head? We rent the porter cable one from rental store enough times a year that we've probably bought 2 by now. Thing holding us back on buying one is it always seemed to be not working right, could just be the rental store abuse though.
jkfox624 is offline
Old 07-16-2009, 07:58 PM   #17
Re: Drywall Sanders
Yep if you mean swivels both ways, I've never used a PC so I cant judge it against one but it works great for me. Comes in a plain cardboard box, no logo or namebrand on the sander, just says, drywall sander variable speed
Old 07-16-2009, 10:23 PM   #18
I like Green things
WarnerConstInc.'s Avatar
Re: Drywall Sanders
looks just like the pc
WarnerConstInc. is offline
Old 07-16-2009, 10:43 PM   #19
Tim0282's Avatar
Re: Drywall Sanders
I have both. The PC is better, but the King is good. We use both equally. I'd buy another King when it does wear out. I've had the Porter Cable for twelve years or so. Takes a little getting used to the head so you don't leave swirls while sanding. Once you do you will sand everything with it. Either one is worth the money.
Tim0282 is offline
Old 07-16-2009, 10:51 PM   #20
danielsdrywall's Avatar
Trade: drywall finisher
Re: Drywall Sanders
I bought 2 pc sanders a couple years back, new, and paid about $450 apiece for them. no vac just sander
danielsdrywall is offline
Ceiling Drywall popping and creaking trimco Drywall 12 06-20-2010 09:54 AM
Loose Drywall Tape hanover Drywall 7 12-03-2009 11:43 PM
Lots of questions about drywall and bathrooms nobody Drywall 30 11-27-2008 01:33 PM
electrician seeks drywall help (pictures inclided) filburn Drywall 2 01-21-2008 06:58 PM
Breaking into the commercial drywall work dryrocker27 Commercial Construction 8 12-11-2007 06:48 PM
