Drywall Pneumatic Nailer?
Old 02-18-2008, 06:25 PM   #1
Roofing Sage
2ndGen's Avatar
Trade: Thoroughbred Roofer
Rewards Points: 2,020
Has anybody used this gun before?
CN351R-ST
It's a Max Drywall nailer.
Can nails ever be as effective as screws to install Drywall?
Thanks.
2ndGen is offline
Old 02-18-2008, 06:48 PM   #2
Rewards Points: 2,000
Re: Drywall Pneumatic Nailer?
Sounds like "One giant leap back to 1960."
neolitic is offline
Old 02-18-2008, 07:20 PM   #3
fr8train's Avatar
Trade: drywall finishing
Rewards Points: 107
I suppose they would work just as well as screws in certain situations, like a hidden firewall, or something similar. But just think what could happen if you tried to use it in living space, over time you would probably have lots of nail pops, and what if you missed a stud? Instead of a neat little screw hole, it could potentially blow out the drywall.
fr8train is offline
Old 02-18-2008, 07:29 PM   #4
Frankawitz's Avatar
Rewards Points: 1,196
Yeah mine is a Bosch and I shingled my house with it, it worked great
Frankawitz is offline
Old 02-18-2008, 07:37 PM   #5
Tim0282's Avatar
Trade: drywall contractor
Hey Frank, do you ever plaster with a sand finish on thin coat? Finish coat floated either lined up swirls or random.
Tim0282 is offline
Old 02-18-2008, 08:01 PM   #6
AtlanticWBConst's Avatar
This is intersting, first I've heard about it.
As stated: It's the 60's again!
- Build Well -
AtlanticWBConst is offline
Old 02-18-2008, 08:24 PM   #7
Royal-T's Avatar
Rewards Points: 75
I see more and more guys using ring shanks to fasten drywall and in my opinion, just spend the money on a good clutch driven screw gun, dont be a window licker and screw in your damn drywall like the rest of us!
Royal-T is offline
Old 02-19-2008, 12:05 AM   #8
Frankawitz's Avatar
Tim not alot cause I do mostly repairs, but I have done it in the past. why what's up you having a problem with a finish? let me know if I can help you.
Old 02-19-2008, 07:06 AM   #9
BUTCHERMAN's Avatar
Trade: DRYWALL PROFESSIONAL
Rewards Points: 2,392
I don't think it is good for hanging rock or will replace screws. Nails do pull out of the ceilings and walls eventualy. Screws bite into the wood and while the board may pull the screws would stay. But depending on the size of the nail heads i would consider it for hanging corner bead. I use a paslode stapler to hang my bead and it cuts the time down by more than half. About it being the 60's. We all learned technechines from the 60's we just improve on them and bring it into today. This could be a good thing given the right use. You might also use it to attach wire screen (for plastering). I need to look into it more.
BUTCHERMAN is offline
Old 02-19-2008, 08:10 AM   #10
taper71's Avatar
Trade: Drywall Taper
Rewards Points: 250
I dont know about where you guys are but with the way most of the boarders( I use this term lightly) around here use a screw gun . That tool may be the answer, but I m sure the boarders would find a way to screw that up too lol.
taper71 is offline
Old 02-19-2008, 08:57 AM   #11
emer constructi's Avatar
Trade: General contractor
I have the Hitachi version of that gun. I use it to set the board in place, nail the edges and come back and screw the field. I like it, but it's hard to find nails.
emer constructi is offline
Old 02-19-2008, 10:40 AM   #12
BUTCHERMAN's Avatar
Still prefer screwed borders. I won't let my hangers even use a hammer. I know it's minimal but nails do pop and the hammer divots usally seperate the paper from the rock which either makes more work for the taper or is ignored by the taper. Either way screwing is the most fool proof way to aviod problems.
Old 02-19-2008, 07:21 PM   #13
Roofing Sage
2ndGen's Avatar
Max is a reputable company. I can't believe they'd produce a gun that would use nails that would eventually pop out anyway.
Now, as for screwguns, which one do you guys think is best?
I'd naturally look at a DeWalt or Bosch product, but you guys would know better.
And...has anybody used the DeWalt cordless drywall gun?
Will it last a day with only one battery change being needed after non-stop screwing?
Thanks.
2ndGen is offline
Old 02-19-2008, 07:34 PM   #14
ghost's Avatar
Trade: DRYWALL
We always used dewalt 255 or 272. I just bought two makita screw guns and I don't think I will go back to dewalt. The makita guns are lighter,quieter, and I like the way the belt clip folds flat it makes it easier to get close to the corners.
snowmobiling cures the winter time blues
ghost is offline
Old 02-20-2008, 12:56 AM   #15
Roofing Sage
2ndGen's Avatar
Used them both.
I was considering the DW269 because it has so much more torque.
Also, I've been eyeing the new Bosch; it looks as if if would be more comfortable over the long hall.
But I love the DeWalts.
2ndGen is offline
Old 02-20-2008, 05:33 AM   #16
Royal-T's Avatar
Rewards Points: 75
Check out he Ridgid screwgun, I bought one to replace an aging DeWalt. It's lighter, just as powerful, and cheaper than the DeWalt. Ridgid tools have come a long way since introduced, they had poor sales in the beginning, so they stepped up from ho grade to contractor grade.
Royal-T is offline
Old 02-20-2008, 09:02 AM   #17
Balding quickly
BattleRidge's Avatar
Trade: The big stuff!
Rewards Points: 588
I have a hard time with keeping a consistant depth with the rigid,but I do like most all their other tools tho. I have been told by multiple guys that the Makita clutch goes out faster, especially doing 5/8s. I've never used it so I don't know for sure... I like the dw272 is all I ever use.
BattleRidge is offline
Old 02-20-2008, 09:47 AM   #18
Roofing Sage
2ndGen's Avatar
Rigid makes one of the best vacuums around.
In a test against Shop Vac and other top manufacturers, it consistantly ranked at the top of the heap and was (though money is no object to me when I'm buying tools) the cheapest.
I love my Rigid Vac.
2ndGen is offline
Old 02-20-2008, 08:59 PM   #19
BUTCHERMAN's Avatar
I don't know if anyone realizes if you buy dewalt products from home depot they are not as good as the ones at a tool supplier. The casings are different and they are not as good. Someone told me certain companys have a cheaper line for home depot. Has anyone seen this?
Old 02-20-2008, 10:04 PM   #20
Roofing Sage
2ndGen's Avatar
I've heard the same...HD has an agreement with DeWalt that their tools have to be produced in Chinese factories for lower costs and that they use more plastic in HD distributed tools.
Take their 3100 Powerwasher. A great machine, except that HD use generic pumps while other DeWalt 3100's use Cat Pumps (a huge difference).
That's a pretty consistent urban legend, but I heard it locally before I saw it being discussed nationwide on the forums.
2ndGen is offline
Ceiling Drywall popping and creaking trimco Drywall 12 06-20-2010 08:54 AM
Lots of questions about drywall and bathrooms nobody Drywall 30 11-27-2008 12:33 PM
electrician seeks drywall help (pictures inclided) filburn Drywall 2 01-21-2008 05:58 PM
Breaking into the commercial drywall work dryrocker27 Commercial Construction 8 12-11-2007 05:48 PM
Pneumatic Siding Nailer dgp Construction 2 08-04-2005 09:07 PM
