Drywall Pin Holes (Air Bubbles)
Old 01-27-2008, 06:45 PM   #1
It's all about the Avatar
woodmagman's Avatar
Rewards Points: 1,016
I went to look at a new job on Friday. They’d had an addition put onto their home a couple of years earlier. The first thing the customer pointed out was pin hole in the drywall patches. I have seen this many times and said that their painter should have touched them up. (Home owner did the painting). They were very unhappy with the job. Personally the taping was spot on. There was pin holes….
What do you think causes this? It has been a common problem.
What is the solution? Besides passing it onto the painter.
woodmagman is offline
Old 01-27-2008, 06:57 PM   #2
Rewards Points: 2,000
Re: Drywall Pin Holes (Air Bubbles)
Come on, fess up, you're just trying to provoke
another "soap-in-the-mud" thread!
The last one was only about a month ago.
neolitic is offline
Old 01-27-2008, 07:05 PM   #3
woodmagman's Avatar
No really not soap....
Anyone posts soap will get the typing fingers washed out..
Old 01-27-2008, 07:09 PM   #4
Liquid dish soap.
SSSSH! Sparks will fly over
how much and what brand.
(I learned it must be 2 jiggers of Ivory )
Yes it works, and do a search and you'll
learn more than you ever wanted to know!
neolitic is offline
Old 01-27-2008, 07:09 PM   #5
Drywall & Painting Pro
Sir Mixalot's Avatar
Rewards Points: 18,145
Ask and Ye shall receive
http://www.contractortalk.com/showth...highlight=soap
Sir Mixalot is online now
Old 01-27-2008, 07:14 PM   #6
woodmagman's Avatar
Noooooooo.......!
it is not soap
Old 01-27-2008, 07:20 PM   #7
Originally Posted by woodmagman View Post
Noooooooo.......!
it is not soap
You are correct .
The answer is really.....
The number 42.
Keep it under your hat.
neolitic is offline
Old 01-27-2008, 07:32 PM   #8
woodmagman's Avatar
You are correct .
The number 42.
o.k. I'll bite, I need to put soap under my hat and turn around 42 times and.....what happens?
Old 01-27-2008, 07:47 PM   #9
The answer to the meaning
of life, the universe, and everything...
Is The Number 42!
(reference:
The Hitch Hiker's Guide To The Galaxy
4th book in the trilogy)
neolitic is offline
Old 01-27-2008, 08:14 PM   #10
woodmagman's Avatar
Is The Number 42!
(reference:
If that is the ultimate question...then the number "42" does not exist.
Old 01-27-2008, 08:17 PM   #11
Kinda disappointing huh?
neolitic is offline
Old 01-28-2008, 06:58 PM   #12
oldrivers's Avatar
Trade: drywall applications
Rewards Points: 522
The drywaller finishes sanding and then the stupid homeowner takes a vacumm to it exposing pock marks. You should only wipe off any excess dust.
oldrivers is offline
Old 01-28-2008, 08:28 PM   #13
kgphoto's Avatar
Trade: Residential Remodeling
Rewards Points: 250
If this is a serious question, then the cause is air migrating from the mud to the outside. Since it can't go back through the wall it comes out the front making the bubbles. soaping you mud may help, I have never tried it. Mixing your mud to a smooth consistency will help. So will wiping it tight on your second, third and fourth coats.
It is more prevalent with AP mud or any mud over a painted surface, like when you are remodeling.
kgphoto is offline
Old 01-29-2008, 12:56 AM   #14
Raven
raven2006's Avatar
Trade: drywall finishing and texture ceilings
Rewards Points: 75
I find the holes happen when mud is put on too thick or it is put over paint. Put mud on in several thin layers and as for mud over paint, despite a thread on this site with dozens of ideas, I still can't get rid of them. Repeated layers of mud seems to eventually get rid of them if you have the patience.
raven2006 is offline
Old 01-29-2008, 07:38 AM   #15
Frankawitz's Avatar
Rewards Points: 1,196
pin holes in mud is because they pulled the mud to fast across the surface of the board, when you do this air gets traped then comes to surface once it drys you get pin hole or pot holes, the Painters are suppose to spackle, this is something Home Owners don't understand about painting they think once the drywall or plaster is done it should be free of any inprefections, this is why there are Painters who know how to paint. I just did a bid where a Home Onwer had her friends do the drywall, well they used all mesh tape and all their joints cracked. she asked me to come in and fix it. Just like a Home Owner. DIYer's are a funny group when their job doesn't turn out right.
Frankawitz is offline
Old 01-30-2008, 05:35 AM   #16
paper hanger,painter
chris n's Avatar
Trade: wallpaper hanger,painter
Rewards Points: 4
the Painters are suppose to spackle, this is something Home Owners don't understand about painting they think once the drywall or plaster is done it should be free of any imperfections, this is why there are Painters who know how to paint.
I am a painter and know how to paint but would expect the the dry waller would know how to apply mud and leave me with a finished product( his or hers job) so I can do my job.Yes, as a homeowner,I would expect when the dry waller is done that there would be few imperfections.
chris n is offline
Old 01-30-2008, 06:29 AM   #17
Frankawitz's Avatar
Well as for painters who think drywallers are to have prefect walls please. Painters now a days do very little work.When I started out some 28 years ago we had to mix our own paint colors they didn't mix it up for you. we also had to do all patching of anything smaller then a quarter now painters are just Blow & Go they don't spackle or caulk or even putty they just want to paint. I bet very few painters even know how to mix colors or make up wood stains colors. Home Owners are bad enough when it comes to filling pot holes but when Painters complain well I guess they really aint Painters. Just Blow & Go cause they don't know how to paint
Old 01-30-2008, 07:05 AM   #18
player2watch's Avatar
Trade: metal studs and drywall
in smoth wall finishing, after sanding the 3rd coat, take a damed sponge and wipe down all joints and nails or screws, then using a light to veiw the walls use mud with a small amount of blue chaulk mixed up in it. then touch up all pin holes and other inperfections. then you go back to the blue spots and sand off the edges.
player2watch is offline
Old 01-30-2008, 07:40 AM   #19
Originally Posted by Frankawitz View Post
...When I started out some 28 years ago we had to mix our own paint colors they didn't mix it up for you.....
To bad you couldn't find a paint store.
In 1980 they all had tint machines,
as did every Sears Roebuck, and 90%
of all the Mom and Pop hardwares.
Oddly when I pay a drywall finisher,
I expect him (or her, Raven)
to finish the drywall!
I expect the painter to paint it.
neolitic is offline
Old 01-30-2008, 08:15 AM   #20
bujaly's Avatar
Trade: Commercial interior super
AH!! I like that, the blue chalk.
This is what I do, but with out the chalk. I don't have to many problems when I'm finishing or repairing, but it does happen on occasion.
"Relentless in Reliability and Satisfaction!"
Oh yeah, 1 other thing...
Assuming doesn't make an a55 out of me and you, it makes an a55 out of YOU and YOU!!!
bujaly is offline
Lots of questions about drywall and bathrooms nobody Drywall 30 11-27-2008 12:33 PM
electrician seeks drywall help (pictures inclided) filburn Drywall 2 01-21-2008 05:58 PM
Bubbles when taping over paint raven2006 Drywall 30 12-23-2007 03:39 PM
Breaking into the commercial drywall work dryrocker27 Commercial Construction 8 12-11-2007 05:48 PM
What the heck? Holes in basement floor Terrence Remodeling 4 06-13-2007 01:06 AM
