Drywall Overtop Foam Board
Old 11-07-2009, 08:37 PM   #1
im4snow's Avatar
Trade: Homebuilding
I'm thinking of running 1" foam board around the inside of a new home. So the 2x6 walls will have r-19 insulation, than 1" foam board nailed to studs on inside of home.
Issue will be drywall installation. Any code/other issues anyone know of?
Local code requires gluing and screwing drywall to studs.....but not sure glue will be of much value if I'm hanging directly against foam board?
Any advice/experience would be appreciated.
im4snow is offline
Old 11-08-2009, 08:06 AM   #2
Ancient Rocker
Ancient Rocker's Avatar
Trade: drywall hanger
Re: Drywall Overtop Foam Board
I have had way too much experience with this crap. From an insulation standpoint., it's a great product,but from a drywall perspective it's a nightmare. Whenever you put something between the framing and the drywall,bad things happen. The worst part is trying to set the screws, because the cushion of foam makes it impossible to set the screws because 99% of the screws will tear the face paper thus losing their holding power. You can't glue it either because all the foam board I have seen has a "wrapper" of plastic. The other downside is that the foam board needs to be fastened as well as drywall because the drywall is not going to "tighten" the foam board. I have never even seen the foam board put up properly, so the drywall job becomes impossible to correctly. The last problem is windows and doors. I assume you rout your windows and doors, so you will need to put extension jambs on prior to hanging or hand cut the windows and doors and that is just crude. If you are that energy conscious, why not try foam insulation in the cavities? Expensive, but if done properly, it's the greatest.
Ancient Rocker is offline
The Following User Says Thank You to Ancient Rocker For This Useful Post:
Dairylander (11-09-2009)
Old 11-08-2009, 09:04 AM   #3
genecarp's Avatar
Thanks for posting on ContractorTalk.com. The Moderators of this forum would prefer if you post Do It Yourself related topics on our sister site www.DIYChatroom.com
ContractorTalk.com is designed for professional contractor's to discuss issues and topics related to the construction and remodeling industries. Many of our professional contractors are also members at DIYChatroom.com and are looking forward to assist you with your needs.
Please take a moment to post your question at www.DIYChatroom.com If your not already a member of DIYChatroom.com you can sign up for a free account by going to http://www.diychatroom.com/register.php/
We apologize for any inconvenience that this may have caused. This thread has been closed.
genecarp is offline
Radiant Ceiling Heat - Drywall Falling Again CliffHollen Drywall 7 04-05-2010 05:18 AM
TX Drywall License arnoldjch Drywall 1 06-24-2009 06:16 AM
Stone over drywall fakie99 Masonry 6 04-07-2009 08:30 PM
Drywall Scratches - Level 5 Smoothwall HUNG BY FOOT Drywall 15 03-10-2009 06:19 AM
drywall romaina-europe crystal Drywall 20 02-08-2009 05:28 PM
