Trade: Roofing, Siding and Custom Carpentry
Drywall Over Plaster Ceiling?
Let me start by saying I aint no drywall man. I had a guy call who had a leaking roof, I looked at roof and made repair. He had me come in and look at his ceiling where it had started falling where the leak was. It is plaster over wood strips. the room is 13 x 13 and there is only about a 3 x 3 area that has fell off, leaving just the wood strips.
I bid this to tear out the plaster on ceiling and leaving strips and then installing drywall over wood strips, breaking joints on centers. My drywall guy/buddy and the homeowner have decided they would rather not tear out the old plaster but just go over it with 1/4" drywall letting joints fall where they do and just screwing thru new drywall, plaster and into wood strips What would you guys do? Do you tear out plaster or install drywall over the plaster? Thanks! Randy |
Re: Drywall Over Plaster Ceiling?
If it's an upper floor and
there's loose fill in the attic I'll laminate to save mess.
Trade: GC/Remodeling
long dw screws, into joists...
Then get your azz back outside on a roof
-Steve "The most beautiful thing we can experience is the mysterious. It is the source of all true art and science." ~ Albert Einstein |
| The Following 2 Users Say Thank You to TimelessQuality For This Useful Post: | fez-head (06-17-2009), Morgan Tile (07-11-2011) |
Official CT Greeter!
Trade: General Construction
why use screws? just use super glue, i am sure it will hold, after all it is super correct?
![]() What I have done in the past is put in furring strips, this way I get a flat even surface and don't have to worry about the board waving at you from the other room. Where the plaster has fallen
"Your problem does not constitute an emergency on my part"
CScalf is right. Run fir strips and screw them on well. Drywall screws(even 3") are no match for loose plaster and lath,gravity wins every time. And gluing the plaster just makes it all come down in bigger pieces. I'm not saying I haven't laminated over old plaster ceilings but I AM saying I'd never hang out in 'the new room' for a couple beers
Trade: Home Improvement General Contractor
Or you can give him a quote to just patch the area that fell.
Build it up with drywall, fiberglass mesh it, plaster, prime and paint. If done correctly, it will be seamless and you will look like a pro who really knows his trade. Always give the customer options.
"Enjoy Every Sandwich" Warren Zevon |
#7 | |
Lack Of All Trades
Trade: Professional handyman services
Re: Drywall Over Plaster Ceiling?Quote:
It cuts down on labor and demo charges to the customer. Plus, you finish much faster. Good luck. |
I just love it when trades people go out of their line of work, This is a Insurance repair job, the guy could have had his Insurance company foot the bill, renail the wood lath base coat skim coat prime and paint done deal, no dickin around with drywall
. The guy should of hired a plumber. WTF!www.frankawitz.net |
Darren@Partners
Trade: Drywall Contractor
Ditto Frank. It's only a 3x3 patch. I'm no plasterer, but have done a ton by pulling back the loose stuff, adding 1/4" , and fill and finish with hot mud.
www.partnersconstruction-drywall.com |
#10 | |
No Base = no fu%&ing around with the lath, less mixing, and less dry time. Just my way of doing it.
If the plaster didn't already
have "issues" like cracks, broken keys, .......it probably wouldn't have fallen off the ceiling while they were roofing. ![]() Most folks with those kind of "issues" aren't falling all over themselves to have the mess and bother of a real plaster fix. At least not in my experience.... The guy wanted a roof, not a bathroom renovation.
Trade: drywall finisher
helo I posted on another thread about concrete fill this would solve your problem in a hurry this is how I make my living by repairing things like this and making textured walls and ceilings smooth what I do is mix 30 % con fill and 70% drywall mud togeither and use this to replaster the area con fill has fibers in it that willadhere to the lath so one or two coats of this mix and one or two coats of mud over top depending on how good your are with a trowel and it will come out as smooth as glass you can sand inbetween coats if you need to
#13 | |
woodchuck2
#14 | |
![]() as for time my jobs figure in waiting for mud to dry www.frankawitz.net |
Trade: drywall contractor
Chances are the house is balloon type framing,i just did 2 big rooms in an old farm house,used key hole saw to find ceiling joists then i marked them ,hung drywall finished and came out flawless.i used 1-5/8s screws,remember ceiling joists usually run the shortest span of a house,old 1800 dwellins arent 16 on center,all nominal inch material
#16 | |
If you think you can tell the difference you are either being silly or are just ignorant. Everyone knows (or should know) the proof is in the finish coats. Whether you use plaster or drywall for a base makes absolutely no difference, as long as the last couple of fill coats are plaster followed by a high quality polish coat or two. And remember Frank, Just because the dry time is figured in the price doesn't mean it's not wasted time. You can charge the same while having less dry time. Now, doesn't that make sense?
"Enjoy Every Sandwich" Warren Zevon Last edited by Mellison; 06-19-2009 at 06:28 PM. |
3/8s laminate.. done
#18 | |
No foam, no fur strips, just super glue, damn you people work too hard!
#19 |
Trade: plaster/stucco
[quote=Mellison;704340]Why would you assume you are the only one who has discerning clients?
If you think you can tell the difference you are either being silly or are just ignorant. Everyone knows (or should know) the proof is in the finish coats. Whether you use plaster or drywall for a base makes absolutely no difference, as long as the last couple of fill coats are plaster followed by a high quality polish coat or two. There absolutely is a difference even in base coats. You are reparing a BMW with Yugo parts. The plaster underneath in this house was probably lime or a lime gypsum blend, definitely not the same thing. It may look seamless when you are done but time will tell. I pulled a fair number of of these types of old patches apart after they revealed themselves. The materials do not expand at the same rates. A lime/hair mix (for instance) is typically very flexible and self-healing to a degree. Drywall is not. The proof is how the repair looks years down the road. |
| The Following User Says Thank You to rogerhattman For This Useful Post: | bonz (06-21-2009) |
#20 |
Certified Remodeler
Trade: Kitchen bath remodeler
1/4" or 3/8" drywall over whole ceiling.
Vote for Pedro Kitchen, bath, St Paul remodeling Minneapolis Remodel Blog 203K Loan Consultant Minnesota |
| Drywall Suspended Ceiling? | onefm | Remodeling | 8 | 06-08-2009 04:00 PM |
| Plaster Ceiling Demo Question | nmcomeau | Demolition | 28 | 03-27-2009 11:00 AM |
| Drywall on ceiling bathroom | metiernan | Drywall | 8 | 03-21-2009 12:24 AM |
| sheetrock vs. plaster in bathroom post and beam ceiling | Bunc | General Discussion | 2 | 03-16-2009 09:34 AM |
| Any Of You Guys Use This Drywall? | Ed the Roofer | Drywall | 12 | 03-02-2009 11:16 AM |
