Repair expert
Trade: General Construction(industrial/commercial maintenance)
Drywall Over Old Plaster..need Advice
ok,so i know this is kind of being hypocritical to my "repair expert" lol,but im doing this in an old residential townhome,and i do very little residential,and i cannot tell ya the last time i delt with plaster...
so i'm doing a job for a friend with old plaster walls,behind it is the old wire mesh and done up with a brown coat. She had a roof leak and got it repaired,the problem is the leak went down behind her walls,hence..needs to be repaired..now i've repaired drywall over a million times,as has any contractor..but maybe plaster once or twice. my question is..after i tear out the area where the plaster was damaged,can i tear out the wire mesh and replace it with jack studs? or does it have to stay,and if so how what the hell am i going to screw to? also,she has 3 or 4 dents on her outside corners at the opening leading to the dining room..i want to put a corner bead over it and mud it in so she can paint it and it will cover the damage,will the mud damage or mess with the plaster at all? any advice would be more than appreciate it,thanks! |
#2 | ||
Re: Drywall Over Old Plaster..need AdviceQuote:
Priced In
Trade: Exiled For Life
As a matter of fact setting compounds use plaster of paris in them. I don't know how much time you want to spend on this but using a "hot mud" might be what you want.
Chief Toilet Mover
Trade: Bathroom Remodeling
Just fill it was some sort of backer, anything will do, drywall, screen, couple of old tires? Mud over the whole mess and match the texture.
All my patch jobs with existing plaster were with drywall backer/fillers and I use hot mud exclusively for patch work since I dont wanna be there anylonger than I have to. Never had a crack call back
Repair expert
thanks guys! i think i am going to try the hot mud and see how that turns out
tore out the wall last night,turns out there was a wooden frame already in place,and drywall nailed up! someone came on and put plaster over it! no wonder it was falling apart with nothing to lock the plaster in! as for the ceiling she told me she had johnny contractor come in and repair it the first time,he had 3 sheets of 3/8 up there screwed to a 1x...besides the fact that he stripped all but maybe 5 screws,i barley pulled on it and it fell on my head(was not prepared for that). her trusses are a little moldy but if i let the ceiling dry out it should be a breeze repairing it. thanks again! |
Kill the mold and put an exclusion in your contract. Here's mine.
"The Contractor can not and will not be held responsible or liable for the presence of any fungi, algae, lichens, slime, mold, bacteria, wet or dry rot and any byproducts of these organisms however produced that may or may not be present now or at any time in the unforeseeable future."
| Plaster vs drywall | GridRunnerFloor | Drywall | 69 | 08-18-2011 07:05 PM |
| Plaster pro's I need your advice! | Drywall1 | Drywall | 10 | 06-23-2007 03:53 PM |
| Need advice on drywall pricing. | bsdstone | Drywall | 14 | 08-11-2006 08:22 AM |
| Hanging Drywall on Cement or Plaster | jlscas | Drywall | 2 | 02-20-2006 02:06 PM |
| drywall over interior plaster/ brick walls | n8sr | Drywall | 10 | 11-10-2005 10:18 PM |
