Drywall Over Drywall? Thoughts?
Old 04-25-2010, 03:54 PM   #1
SkinnyVinny's Avatar
Trade: Drywall
hey guys, I just was asked to do a job from a friend who is a painter. He says the walls are beyond the point of repair and wants me to slap 1/4" drywall over it. For some reason, this method never sat right with me because your shortening the room, the outlets and light switches have to be brought out, and just the fact that you are fastening it to a not so level and messed up wall...Just rubs me the wrong way... I would just rather take it all down and hang new 1/2" up. What are your guys thoughts on this process? am I being to anal?
Skinny Vinny's Drywall
http://www.skinnyvinnysdrywall.com
SkinnyVinny is offline
Old 04-25-2010, 03:59 PM   #2
Geometrist
Warren's Avatar
Trade: framing/remodeling
Rewards Points: 6,419
Re: Drywall Over Drywall? Thoughts?
How does tearing out and rehanging the drywall do anything to straighten up the "not so level" walls? Years ago, when I used to hang drywall for my previous employer, we sometimes would hang 1/4 over walls. A lot less mess and labor. I don't think any codes permit that as an acceptable solution though.As for shortening the room, that half inch by half inch reduction will result in about a whole sq ft of loss per room.
Easy Gibson
Warren is offline
Old 04-25-2010, 04:06 PM   #3
Trade: Drywall
I hear ya.. I guess the only thing that would constitute me tearing down the walls would be to fur the actual studs rather than furring the existing wall.. I feel as though you are just bypassing the "real" problem the wall has by slapping it over..
Old 04-25-2010, 04:25 PM   #4
JonM's Avatar
Rewards Points: 1,216
Happens all the time here, but usually with plaster walls with 3/4 inch trim...you'll need longer screws for the outlets. It all depends what the coustomer wants and can pay for...it's his call...their is no code violation
JonM is offline
Old 04-25-2010, 04:41 PM   #5
Professional Services Inc
Nicholas25's Avatar
As you know it can be done both ways. Ask the client if they want perfectly level walls. If so you should rip it out down to existing studs and install new gypsum. Furring or shimming where necessary.
If the client dosent care about the walls being perfectly level, then 1/4" over existing is fine. Use longer screws to secure any outlets or switches to gem or junction boxes already existing in walls.
You will have to remove and replace existing base moldings should you decide to laminate with new 1/4" over existing. Also any other trim or moldings such as crown oir dentil at ceiling if it exists.
Sometimes it is best to rip out, sometimes it is besat to laminate over, and sometimes it is best to skim 3 coats with durabond, plaster, compound, fiberglass mesh applied first etc. This all depends on who is doing the work, the level of skill they posess, and what the client wants to pay for.
Nicholas25 is offline
Old 04-25-2010, 04:43 PM   #6
topsail's trimcat
woodworkbykirk's Avatar
Rewards Points: 384
its acceptable, if the homeowner wants fresh walls when there is old wallpaper on them we simply skip stripping the wallpaper because the'll have to be skimmed anyway. so we just goto new 1/4" on top
1/4" is fine for the outlets as well, at 1/2" you need longer screws for the plates and in some instances extensions for the boxes so it meets code
woodworkbykirk is offline
Old 04-25-2010, 05:17 PM   #7
boman47k's Avatar
Rewards Points: 2,006
What about the door jams in a situation like this? Can you get 1/4" mud rings?
Years ago, we had paneling put over dw. I'm sure the rec were just handled by bringing the rec out and placing covers back on them. I changed this mysel by gutting the rooms myself.
One more ?. Does the 1/4" dw not get wavy? Use glue between the studs to partially glue the old and the new rock??
boman47k is offline
Old 04-27-2010, 05:40 AM   #8
Big Shoe's Avatar
Rewards Points: 1,728
Walls have to be pretty bad to go this route. Must be plaster walls?
1/4'' should be laminated with mud and or glued and screwed if the walls are uneven.
3/8'' is alot stiffer but you may only need to srcrew it.
If the door caseing is not comming off you may need to flat tape around them.
Let us know how bad those walls are, skimming normally works.
Big Shoe is offline
Old 04-27-2010, 09:17 AM   #9
vandy
vandyandsons's Avatar
Trade: painting, decorating, wallcovering
Rewards Points: 250
I am getting ready to finish a ceiling that will be laminated over with 3/8"
I don't see anything wrong with it as long as it will look good when done.
vandyandsons is offline
Old 04-27-2010, 05:24 PM   #10
Nicholas25's Avatar
We could all go on forever about this topic. The bottom line is, who ever is doing the work must figure out all the factors involved and decide which route to take and what process or combination of processes he will use.
Each one of us may select different methods based on several factors. In order to truly decide how to complete this work we really need to be the one doing it.
Old 04-27-2010, 09:37 PM   #11
The Brains
JKBARR127's Avatar
Trade: carpenter
Rewards Points: 150
we opened a wall up a few weeks ago in a building that is f---ed in every corner u look. this wall had 3/8 on top of paneling on top of 1/2 inch. we took all down and put new.
Its no good-Take it down
JKBARR127 is offline
Old 04-28-2010, 08:36 AM   #12
Profit is not dirty.
AARC Drywall's Avatar
Trade: Residential Drywall and Taping
Rewards Points: 266
Hey all,
1/4" drywall in most cases would be fine, but if the wall is that gone, it should be removed...in my opinion the 1/4" drywall is not stiff enough to be straight when screwed to the studs...if the drywall is in that bad of shape with cracks, dents, missing, the 1/4" will be mimicking the bottom layer in some areas. You will be floating out the 1/4 to make it straight.
Tare it off and use the proper thickness of board....just my thoughts...
J
Profit is NOT a dirty word....Cheap is....
AARC Drywall is offline
Old 04-28-2010, 08:38 AM   #13
Rewards Points: 266
Old 04-28-2010, 01:00 PM   #14
Nicholas25's Avatar
Thanks. Glad you agree! And you are right, I hate CHEAP Also. Cant stand guys who think the only way to get work is by lowballing. It destroys our living!!!
Drywall over plaster ceiling? RandyB1986 Drywall 34 11-29-2011 04:09 PM
Have any of you been following this Frankawitz Drywall 5 04-12-2009 08:47 PM
Drywall Scratches - Level 5 Smoothwall HUNG BY FOOT Drywall 15 03-10-2009 05:19 AM
Any Of You Guys Use This Drywall? Ed the Roofer Drywall 12 03-02-2009 10:16 AM
How much advantage is 5/8 drywall over 1/2"? Jim S. Drywall 2 08-26-2008 10:52 AM
