Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Drywall
Old 09-29-2009, 01:52 PM   #1
Trade: handyman
drywall finishing question. new ceiling, finished wall.
ok this one is a bugger because theres nothing on it in my drywall book and its impossible to find anything online about this unless theres a term i just dont know so im caving in and here i am asking lol.
i have to finish some bare drywall on a ceiling. the side walls are finished and i cannot tape the edges and corners because of this. the home owner suggested cutting back the finish, but thats alot of work and its going to be noticeable like crazy. UGLY basically.
so i was thinking high porformance spackle. that stuff holds really strong. any other suggestions?
thanks guys!
mechanix is offline   Reply With Quote
Old 09-29-2009, 01:59 PM   #2
genecarp's Avatar
Crown
genecarp is online now   Reply With Quote
Old 09-29-2009, 02:35 PM   #3
Illusion of Perfection
CookeCarpentry's Avatar
Trade: Residential Remodeler/Custom Carpenter
Sand and prime the top corners of the walls. Mud and tape. Prime and paint.
Mark
Wayne, PA
"It is what it is."
CookeCarpentry is online now   Reply With Quote
Old 09-29-2009, 04:00 PM   #4
jarvis design's Avatar
Exactly!!
Do it Right the First Time....or someone else will!!
www.JarvisDesignBuild.ca
jarvis design is offline   Reply With Quote
Old 09-29-2009, 04:09 PM   #5
Trade: GC/Remodeling
If I said latex caulk, would you do it???
Originally Posted by jeremy-lvhm View Post
...just stop it. go sit down and have a lollipop and think about what your saying.
TimelessQuality is offline   Reply With Quote
Old 09-29-2009, 04:21 PM   #6
Why not white silicone? No need to worry about cutting in any edges.
Mark
Wayne, PA
"It is what it is."
Old 09-29-2009, 06:20 PM   #7
samccard's Avatar
Trade: Builder/Remodeler
Crown molding!
samccard is offline   Reply With Quote
Old 09-29-2009, 08:06 PM   #8
Trade: Plaster/Drywall
^^ These guys got it right, crown covers all and if you can’t do that, then you should do it right and just repaint.
That being said:
A old plasterer showed me a trick that works for plaster but I’ve never had to use it for drywall but I think it should work. You could mesh the corner but only put about 1/16 – 1/8 of the mesh on the vertical wall. Go over the mesh with hot mud and stay off the wall. The mud thickness should cover the mesh completely and if you put it on straight you’ll have the mesh in the corner and a clean wall. Win win! (still best to do it right though)
Plaster Guy is offline   Reply With Quote
Old 09-29-2009, 09:18 PM   #9
Capt-Sheetrock's Avatar
Trade: Drywall
thanks guys!
ya mean theres a book???? dern wish I had known that !!!!!!
really man,,, just tape off the wall with blue tape, then flat tape the ceilings, sand, then cut the tape line with a razor knife and pull off.
Thats GOT to be in the book,,,,,, just look a little harder
Capt-Sheetrock is offline   Reply With Quote
Old 09-30-2009, 11:44 PM   #10
Trade: handyman
thx for all the good ideas guys! this seems to be a good topic.
one issue thourgh with sanding and taping, or using the blue tape meathod of taping then cutting, im going to get a challenge.
how do i get the texture to look right down the wall on that 3 inch strip that i sand or cut away? i have a redtail texture gun..... but is there a hand method? cuz matching texture seems to be a big nono in most cases.
maybe ill just do crown.... seems to be the smartest way to go here guys.
Old 10-01-2009, 12:16 AM   #11
nEighter's Avatar
Trade: Painting/Framing/Drywall/Tile
oh man. so the walls are textured? Is the ceiling popcorned? What is going on with everything (more detail) AND what the hell happened to where they would "finish" without finishing? takes all kinds.
nEighter is offline   Reply With Quote
Old 10-01-2009, 05:26 AM   #12
Frankawitz's Avatar
Trade: Plastering, Drywall, Painting, Woodworking, Stucco, refinishing woodwork
Walls are textured and they had you replace the ceiling? What kind of texture and can you post some pictures?
Frankawitz is offline   Reply With Quote
Old 10-01-2009, 06:39 AM   #13
Oh this changes everything since the walls are textured.
Give them a bid for sheetrocking an entire house, after you give them a ballpark on demolishing the existing and rebuilding - that's the only way you can overcome this obstacle.
Mark
Wayne, PA
"It is what it is."
Old 10-01-2009, 11:39 PM   #14
Trade: handyman
ya lol the walls are textured the ceilings had damage i guess. it used to be a crackhouse so u never knew wth happened.
so im really thinking to just slap some trim up on the walls. i want to avoid using crown though (expensive. this is just a rental for my customer. she wants things done cheap)
do u think i could get away with just plain door casing around the top?
Old 10-01-2009, 11:43 PM   #15
Trade: handyman
they want to keep the walls that are there. its not my house and honestly it would be a dumb business move to do what you are suggesting because they will simply say nogo and hire someone else. we are talking about turning a 400 dollar job into thousands which i know they will not go for. they are aware the texture wont match but they dont care.
Old 10-01-2009, 11:45 PM   #16
Trade: handyman
i think the walls are orange peal and she said to just do knockdown on the ceiling. lol its going to look bad but this girl just wants to rent this place out asap.
Old 10-02-2009, 05:40 AM   #17
Frankawitz's Avatar
Well then just hang and finish ceiling then take your hopper and hit the ceiling with a texture as for the corners that meet the ceiling fill them with Durabond 90 in the brown bags texture by hand to match at the top of your walls done deal. then paint it out.
as for moulding and door case moulding
Old 10-11-2009, 04:13 AM   #18
Trade: This & That
So it was a crackhouse, now a ghetto rental, and she's worried about how one little corner is going to look?
+1 caulk it!
Dash808 is offline   Reply With Quote
The Following User Says Thank You to Dash808 For This Useful Post:
nEighter (10-12-2009)
Old 10-12-2009, 10:36 AM   #19
Profit is not dirty.
AARC Drywall's Avatar
Trade: Residential Drywall and Taping
If all she wants is to rent the place out, then re-do the ceiling as required, then around the edges take 1/4 round mounlding, and then dap the top and bottom. Done. easier than crown and is inexpensive.
Hope that helps
J
Profit is NOT a dirty word....Cheap is....
AARC Drywall is offline   Reply With Quote
Drywall over plaster ceiling? RandyB1986 Drywall 27 06-22-2009 04:35 PM
Drywall Suspended Ceiling? onefm Remodeling 8 06-08-2009 03:00 PM
Have any of you been following this Frankawitz Drywall 5 04-12-2009 08:47 PM
Scaffolding Question, distance from wall plazaman Masonry 21 10-13-2008 11:49 PM
How much advantage is 5/8 drywall over 1/2"? Jim S. Drywall 2 08-26-2008 10:52 AM
