Drywall Cracks, Installed Yesterday
Old 03-06-2018, 07:10 PM   #1
la_bacon's Avatar
Rewards Points: 4
I usually do the drywall work on jobs but this time my boss subbed it out because we're super behind. They finished yesterday but when I looked at it today I noticed tons of cracking. Mainly in corners, which won't be hard to caulk in, but there is a really big one on the ceiling, right in the middle of the joint (not the edge of the tape). I've never seen this happen so quickly. What's going on?
Also, what's the best way to fix it? Can I just skim coat it or should I use some tape (they used paper but I prefer mesh for non-corners)? Should I be worried about something structural? We were replacing their drywall because the ceiling had been starting to fall down, but not in the area of this ceiling crack. We were worried it was termites, it wasn't, and my boss shrugged it off as just old drywall. Also, this crack is near where some of the garage door hardware is attached. Could how they re-hung the garage door be effecting it?
Thank you!
la_bacon is offline
Old 03-06-2018, 07:56 PM   #2
John the Builder
SmallTownGuy's Avatar
Trade: Carpenter/Builder
Rewards Points: 9,928
Re: Drywall Cracks, Installed Yesterday
lordy
SmallTownGuy is online now
The Following 4 Users Say Thank You to SmallTownGuy For This Useful Post:
avenge (03-06-2018), Bull Trout (03-06-2018), MarkJames (03-07-2018), tang (03-07-2018)
Old 03-06-2018, 08:53 PM   #3
Mordekyle's Avatar
Rewards Points: 3,300
Pictures?
Mordekyle is online now
Old 03-07-2018, 06:48 AM   #4
This space for lease
RangoWA's Avatar
Trade: General
Rewards Points: 4,628
The drywall subs don't know how to deal with it? Why should you fix their mistakes?
RangoWA is offline
The Following User Says Thank You to RangoWA For This Useful Post:
Old 03-07-2018, 07:59 AM   #5
la_bacon's Avatar
Rewards Points: 4
I don't trust them to do it right. If this wasn't a garage I would be re-hanging sheets and skim coating everything. It'll be faster to do it right myself.
la_bacon is offline
Old 03-07-2018, 08:03 AM   #6
Big Johnson's Avatar
Trade: Contractor and Grunt
Rewards Points: 3,434
If it’s a garage, did you think it might have cracked due to a shift in the weather before it was fully dry? I heard mud takes a couple days minimum to dry all the way through and that’s in a controlled environment. Even if it looks dry, it’s not necessarily.
I’m not a drywaller, I Jaws that shlt out.
Big Johnson is offline
Old 03-07-2018, 08:14 AM   #7
la_bacon's Avatar
Rewards Points: 4
If it?s a garage, did you think it might have cracked due to a shift in the weather before it was fully dry? I heard mud takes a couple days minimum to dry all the way through and that?s in a controlled environment. Even if it looks dry, it?s not necessarily.
I?m not a drywaller, I Jaws that shlt out.
I've done a lot of drywall in new builds before they are climate controlled as well as other garages and haven't seen anything like this. I'm in Phoenix so we're pretty mild, mid 40s thru low 70s but it did jump up to 80 yesterday.
la_bacon is offline
The Following User Says Thank You to la_bacon For This Useful Post:
Big Johnson (03-07-2018)
Old 03-07-2018, 10:08 AM   #8
la_bacon's Avatar
Rewards Points: 4
Originally Posted by Mordekyle View Post
Pictures?
The joists are running perpendicular to the ceiling crack. Also included an example of the cracking that is all over the place in the corners.
la_bacon is offline
Old 03-07-2018, 01:43 PM   #9
Snobnd's Avatar
Trade: Remodeling 30+ yrs
Rewards Points: 1,894
It’s probably because of improper blocking in the ceiling area, every 7 feet you should have blocking in the ceiling Joist. Seems like movement above for sure.
"When the people fear their government, there is tyranny; when the government fears the people, there is liberty"
- Thomas Jefferson-
http://www.savingtherepublic.com/Main.html
Snobnd is online now
Old 03-07-2018, 06:54 PM   #10
la_bacon's Avatar
Rewards Points: 4
Originally Posted by Snobnd View Post
It?s probably because of improper blocking in the ceiling area, every 7 feet you should have blocking in the ceiling Joist. Seems like movement above for sure.
Oh, is that for the additional weight of the garage door?
There were also cracks on the walls, mainly horizontal but also vertical, and I know those studs were at least 24" on center. There's also cracking in every corner, where the ceiling meets the wall and where the walls meet.
la_bacon is offline
sparehair (03-09-2018)
Old 03-07-2018, 07:13 PM   #11
Maybe the garage door was operated before the mud fully dried???
Old 03-08-2018, 08:12 PM   #12
Big Shoe's Avatar
Rewards Points: 1,858
Tapes lifted. Watery paint or improper taping. See if tape peels out easily. Do not tape over.
Wow. Somebody’s going to loose some money here.
Sent from my iPad using Tapatalk
Expect the Unexpected
Big Shoe is offline
The Following 2 Users Say Thank You to Big Shoe For This Useful Post:
Bummie (05-09-2018), hdavis (05-09-2018)
Old 03-09-2018, 08:38 PM   #13
Drywall Slave
blacktop's Avatar
Trade: drywall contractor
Rewards Points: 3,888
Wet mud over wet mud and then paint over wet mud ? I think you know where in going with this !
Sounds like one of those ..let's git er done in two trips kinda deals .. with a tail light warranty.
The tape coat has to be cured before the block coat goes on . The block coat has to be cured before the skim coat goes on. The skim coat needs be cured before it can be sanded!
READ THE BUCKET !!
blacktop is offline
The Following User Says Thank You to blacktop For This Useful Post:
Bummie (05-09-2018)
Old 03-09-2018, 08:47 PM   #14
Drywall Slave
blacktop's Avatar
Overloaded mud in the angles can cause the angle cracks. Or the tape was still wet when they coated them ..And when the tape coat starts to cure out under a wet block coat ! It causes the angle to hair line crack in the crease .
blacktop is offline
Old 03-09-2018, 08:58 PM   #15
Drywall Slave
blacktop's Avatar
It's a garage that's not air controlled ? Where you been man? All garages hung with regular sheetrock go to chit within the first year or so . You can't put regular sheetrock outside !!! It will fail . It needs to be air controlled . It's called DRYwall . If you want drywall to hold up outside? You got to go with W/P.
blacktop is offline
The Following 3 Users Say Thank You to blacktop For This Useful Post:
asevereid (03-10-2018), cedarboarder (05-09-2018), Easy Gibson (05-20-2018)
Old 03-09-2018, 09:03 PM   #16
Drywall Slave
blacktop's Avatar
I'm calling H/O on this .
blacktop is offline
Bull Trout (03-10-2018)
Old 03-10-2018, 10:04 AM   #17
la_bacon's Avatar
Rewards Points: 4
I think you guys are right with watery mud not curing.
Wednesday I re-taped the cracks (on walls horizontal and vertical, on ceiling on joists and perpendicular to joists, corners I just caulked). Used mesh tape and a thick coat of 45 minute mud then topped it with regular mud. So far no cracking, which is good because their stuff was still wet when I saw the cracks. I didn't remove the old tape but if I have to do more repairs (which I'd bet on) I will.
When I was cleaning up the job site I found a 5 gallon bucket half full with a super watery mud mixture. Much looser than I'd even use in a hopper. More like the stuff at the bottom of your cleaning bucket after mudding for a week. My boss said they were using it to apply the tape (adhering it to the wall and giving it a first coat). I guess they used a normal consistency mud after that, but you're kind of f-ed after a first coat like that. Plus since it was so watery, I'm sure it didn't dry out well enough before the next coats.
I am just totally amazed that people could screw something up so badly.
la_bacon is offline
Old 03-10-2018, 10:10 AM   #18
la_bacon's Avatar
Rewards Points: 4
I'm in Phoenix so our weather is pretty mild and I think that makes a difference. The garages are weatherproof but not climate controlled. Using drywall in them is pretty standard, even the new builds I've done. My detached garage's drywall is 20+ years old and doing fine.
What is W/P? And H/O?
la_bacon is offline
blacktop (03-10-2018)
Old 03-10-2018, 10:23 PM   #19
Drywall Slave
blacktop's Avatar
T[QUOTE=la_bacon;6877466
What is W/P? And H/O?[/QUOTE]
Water proof . And homeowner . And I'm guessing your an H/ O .?
blacktop is offline
The Following 2 Users Say Thank You to blacktop For This Useful Post:
Californiadecks (03-11-2018), cedarboarder (05-09-2018)
Old 03-12-2018, 12:26 AM   #20
3bar's Avatar
Trade: carpenter
Rewards Points: 466
living space above?
floor flexing too much?
3bar is offline
drywall over drywall nwksremodeler Drywall 11 01-14-2014 08:57 PM
1927 Oliver 117-A Bandsaw Restoration..... PrestigeR&D Tools & Equipment 49 01-12-2014 10:35 AM
How is tile installed in new homes in your area? jarvis design Tiling 9 07-10-2013 05:46 PM
drywall subs needed ASAP estimating2013 Help Wanted or Looking For Work 4 04-27-2013 06:46 PM
