Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Drywall
Old 07-19-2009, 06:18 AM   #1
Trade: remodeling and cabinet maker
Dryvit interior finish
this might be the wrong spot to post this ,if so apologies ..Has anyone used any of dryvits interior finishes.. if so how was it work with.
Jerry Purviance is offline   Reply With Quote
Old 07-19-2009, 11:11 AM   #2
Trade: Drywall/Stucco
Used Imasco and Synergy many times on interiors ( swimming pool rooms, solariums, etc.) Dryvit has comparable products, so it must be similar. If moisture isn't an issue, these work great over regular drywall. Ugrade to denshield or cement board for moist areas. The acrylics are as hard to repair damaged walls on the inside as the out!! And pool areas needed an extra coat of a waterproof material (hand applied) before the finish, can't remember what...
DeanG is offline   Reply With Quote
Old 07-19-2009, 11:14 AM   #3
Oh, and they are easy to work with, just MESSY. Cover EVERYTHING you dont want dirty, and throw away your work clothes when your done! lol
Old 07-19-2009, 06:59 PM   #4
Trade: drywall contractor
Are you troweling and floating or spraying?
Tim0282 is offline   Reply With Quote
Old 07-19-2009, 11:56 PM   #5
Trowel and float finish. It will still find its way to where it's not supposed to be!! I've never tried to spray this stuff....is it the same hopper/texture machine as ceiling texture?
Old 07-22-2009, 06:47 AM   #6
Trade: Masonry
dryvit
You can use a hopper gun to apply.
CaseyJones is offline   Reply With Quote
Old 07-22-2009, 06:50 AM   #7
Trade: Masonry
interior eifs
Make sure the substrate is clean and dry. Use plastic drop cloths and masking tape to cover things (like prepping to paint). Use a hopper gun to apply.
dryvit chicago nwcins@aol.com General Discussion 2 05-27-2009 11:54 PM
dryvit over block problem master mason Masonry 3 04-03-2008 04:57 AM
Fake stone over dryvit (effice sp?) 6stringmason Masonry 15 12-16-2007 08:38 PM
Stucco, Dryvit, or masonry? nakins General Discussion 5 09-05-2007 12:46 PM
Dryvit painting MakDeco Painting & Finish Work 17 03-21-2007 09:58 PM
