Dish Soap In Mud
Old 04-16-2011, 06:23 AM   #1
Pheasant89's Avatar
Rewards Points: 97
Dish Soap In Mud
New to contractor talk and trying to use "search" but not good luck trying to use it. ButI know this is probabaly been talked about alot before but what in fact does (dish detergent ) do to help mud ? I am a carpenter and do some drywall but recently noticed on ajob the drywallers were squirting DAWN dish soap in there pan and mixing it by hand with there 4 in blade. Is it for the last coat, all coats and what exactly does it do?? Always looking for tips in the drywall area
Thanks
Pheasant89 is offline
Old 04-16-2011, 07:02 AM   #2
boman47k's Avatar
Rewards Points: 2,006
Re: Dish Soap In Mud
I used to be a proponent of using Dawn. Its been a while, but I used it to make the mud creamier and the tools easier to clean.
That being said, I now wonder if it causes fish eyes sometimes. Especially, if I add water to it also. I'm thinking maybe water and the soap causes bubbles. Bubbles pop and leaves little holes.
I guess the amount of water and soap has a bearing on this, not to mention the thickness of the mud.
Maybe a few times I just applied it a little thick.
boman47k is offline
Old 04-16-2011, 07:17 AM   #3
Chief Reporter of Spam
Tech Dawg's Avatar
Trade: Kitchen and Bathroom Remodeling
Rewards Points: 1,280
You don't want to use dish soap on your first coat...
The purpose of it is to prevent bubbling when recoating or atleast that is what I was tought... only need a drop or two.
Todd
Alone Eagle Remodeling, LLC
Tech Dawg is offline
Old 04-16-2011, 06:34 PM   #4
mrkjb's Avatar
Trade: drywall
it is used to make the plaster feel creamier. thats it.
mrkjb is offline
Old 04-17-2011, 02:57 PM   #5
Tim0282's Avatar
Trade: drywall contractor
Ever try using white glue instead of dish soap? Has the same benfit of soap yet gives a little extra glue to the mud. Makes the mud amazingly smooth. Three tablespoons is all you need. Works great!
Tim0282 is offline
Old 04-17-2011, 10:41 PM   #6
30 yrs carpentry/drywall
Carpenter Wayne's Avatar
Trade: Interiors/finishes
Rewards Points: 75
Be extremely careful - this is the same as an old wives tale. Some claim it makes the mud smoother, others that it makes it easier to sand when dry, some say it reduces bubbling, and others that it makes it easier to clean up your tools, etc.
but
the one thing it DOES for 100% sure is:
when you mix it in with your mud and apply it to walls/ceilings, etc. you end up with a mud that doesn't adhear properly and peels off the surface/s (in fact) I've seen where guys used it and the mud started falling off when the painter and/or home owner started the painting process! It will stick to the rollers by coming off in clumps and then you have to scrape it all off and re-tape/re-mud to correct the problem
http://hstrial-pdsdrywall.intuitwebsites.com/
He who lives on hope - dies of starvation
Carpenter Wayne is offline
The Following User Says Thank You to Carpenter Wayne For This Useful Post:
ccappaul (05-15-2011)
Old 04-18-2011, 12:31 PM   #7
aptpupil's Avatar
Rewards Points: 1,894
it's a wetting agent so it theoretically makes it smoother. i've used it with premixed mud and not seen any appreciable difference so i don't do it anymore.
aptpupil is offline
Old 04-18-2011, 01:55 PM   #8
G Teoli
Teoli's Avatar
Rewards Points: 150
This topic has come up before. Look back in the archives. Some guys, if I remember correctly, had the proper ratio to make this work.
Add too much and you're in trouble
Teoli is offline
The Following User Says Thank You to Teoli For This Useful Post:
Big Shoe (04-19-2011)
Old 04-18-2011, 07:27 PM   #9
Tim0282's Avatar
I don't like the idea of using soap in the mud. Just my .02 worth. Like a lot of new and wonderful ideas. Sometimes the come back to bite you. It is hard to beat the old tried and true ways.
Tim0282 is offline
Old 04-19-2011, 12:55 AM   #10
2buckcanuck's Avatar
Trade: taper/drywall
Rewards Points: 75
I 2nd tims .02 worth,,,,so there's my 2bucks worth
2buckcanuck is offline
Old 04-19-2011, 05:32 AM   #11
Big Shoe's Avatar
Rewards Points: 1,832
Just a dash.
Big Shoe is offline
Old 04-19-2011, 02:49 PM   #12
Nouveau Eccentric
Diamond D.'s Avatar
Trade: masonry/hardscaping
Rewards Points: 2,548
I don't use, either.
If it was so wonderful, after all these years, you think it would be mentioned on the bag or added to the bucket at the plant.
Another, .02, into the pot,
D.
" ROCK YOUR WORLD "
fb
Diamond D. is offline
Old 04-19-2011, 05:20 PM   #13
Tim0282's Avatar
I like putting glue in the mud to give a little insurance and it makes wiping the tape amazingly easier. But the dish soap makes the mud smell yucky.
Tim0282 is offline
Old 04-20-2011, 10:57 PM   #14
mrkjb's Avatar
Trade: drywall
but
thats what happens if you add to much. not if you use a small amount.
mrkjb is offline
Old 05-14-2011, 11:15 AM   #15
taperdave's Avatar
Trade: Drywall contractor
We have been adding a very small amount of "sunlight" to our topping mud for years. It helps with removing air in the mud as well as it improves the mud workability. Watch it though it will void manufactures warranty.
taperdave is offline
Old 05-15-2011, 11:08 AM   #16
Veterans Drywall Repairs
vetsdrywall's Avatar
Trade: Owner/carpenter/drywaller
I agree and it gives you a "glazed" look once you sand it. It does not match the first coat. Very obvious.
vetsdrywall is offline
Old 05-16-2011, 12:02 PM   #17
Frankawitz's Avatar
Rewards Points: 1,196
why waste your time and money on Dish Soap it's for DISHES not drywall mud all it does is make the mud smell good
If you get small bubbles in your mud it's cause you beat it to much with your drill and you have trapped air in the mud, or your pulling the mud fast will cause bubbles too!
Frankawitz is offline
The Following User Says Thank You to Frankawitz For This Useful Post:
Darwin (05-18-2011)
Old 05-16-2011, 05:15 PM   #18
Grand Rapids Remodeling
Paulie's Avatar
Rewards Points: 2,052
Fraaaaaaaank, what's up dude!!!
Paulie is offline
Old 05-16-2011, 05:35 PM   #19
oldrivers's Avatar
Trade: drywall applications
Rewards Points: 522
you shouldnt worry to much about bubbles until you put on the finish coat. when doing your finish coat it shouldnt take that much mud so the mud shouldnt even be thick enough to have any major bubbles. try putting a heavier fill on your fill coat so your final coat is thinner. thinner mud less bubbles thicker mud more bubbles . i mean thickness of mud depth not consistancy -wetness .
oldrivers is offline
Old 05-16-2011, 06:44 PM   #20
dave_dj1's Avatar
Trade: general contractor
Rewards Points: 812
we've used dawn for the last 30 years and never had one single problem, it makes the final coat glide on. Just like anything good in life, don't over do it!
dave_dj1 is offline
Soap for aluminum siding Chuck Kiser Painting & Finish Work 3 09-07-2010 07:38 PM
dish soap in joint compound Bencouver Painting & Finish Work 2 04-13-2010 08:57 PM
dish washer hook up rservices General Discussion 4 09-11-2008 09:57 AM
Putting soap in mud Chazbe Drywall 37 01-31-2008 11:15 PM
Would you pay $20 for a bar of soap if it was made using a bike? Mike Finley Off Topic (Non Trade) 5 08-22-2006 12:26 AM
