Densglass For Interior Bath Walls
Old 01-01-2009, 03:39 PM   #1
justinae's Avatar
Trade: Green Building
As a non drywaller is there any issue with using Densglass Moisture and Mold resistant (the yellow stuff) as interior bathroom wall surface (including ceiling)? I'm assuming I can countersink the screws and skim the surface to prep for painting.
thanks and happy new year.
justinae is offline
Old 01-01-2009, 03:46 PM   #2
precisionbuild's Avatar
Trade: Contractor
Re: Densglass For Interior Bath Walls
Densglass is a commercial exterior board. I don't know why you would want it for this application. DensArmor Plus Interior Guard is a better choice, but it cannot be used in commonly wet areas or shaft wall applications.
As long as it is not in the bath/shower walls, why not just use MR board?
precisionbuild is offline
Old 01-01-2009, 04:26 PM   #3
justinae's Avatar
To be honest when I called the supplier I just told them to deliver moisture and mold resistant drywall and that is what they delivered. I assumed it would be green board. Like I said I'm not a drywaller but it got me to thinking why couldn't I use it. If it's rated for exterior then it should be above and beyond what I need for a bathroom.
justinae is offline
Old 01-01-2009, 04:31 PM   #4
Trade: Contractor
It's not made for finishing and painting and will not do so well.
Old 01-01-2009, 04:44 PM   #5
justinae's Avatar
even if you skim coat it?
justinae is offline
Old 01-01-2009, 04:46 PM   #6
Trade: Contractor
You can , but it's just so much more labor intensive. Plus the costs end up being alot more. eg. cost of board, more mud, etc.
Old 01-01-2009, 04:50 PM   #7
justinae's Avatar
good point and well taken. I think I'll take this as an opportunity to notch another tick on the learning curve with different products. I also think that taping the seams (I'll use mesh) will be an issue as there isn't any taper. But that isn't too different from regular drywall.
justinae is offline
Old 01-01-2009, 05:00 PM   #8
Trade: Contractor
Good luck! Tell us how it turned out.
Old 01-01-2009, 05:14 PM   #9
justinae's Avatar
thanks and will do.
justinae is offline
Sanding Walls with 80 Grit Paper on Orbital Questions plazaman Painting & Finish Work 5 12-19-2008 04:01 PM
Why Build ICF monsterconstruc Green Building 32 09-28-2008 11:48 PM
Floating Basement Walls McMasters Framing 15 08-26-2008 11:43 PM
Bridging for above grade Concrete Walls ETHICS05 Construction 1 11-21-2005 12:43 PM
