#21 | |
Re: Curved StairsQuote:
#22 |
Re: Curved Stairs |
#23 |
Trade: Design
Re: Curved Stairs
Another option for these stairs would be plaster, if you have access to a good plasterer.
#24 | |
KemoSabe
__________________________________ "Walking the fine line between production and perfection" __________________________________ |
#25 | |
drywall supplier. Never thought of the steel studs. Wasted a lot of time building up laminates from 3/8 " ply rips to get the "twist factor."
#26 |
Re: Curved Stairs
That's what I did today. Went to a local building centre and picked up flexible 1/4" sheets.
#27 | |
KemoSabe
#28 |
Re: Curved Stairs |
#29 |
Trade: Home repairs,drywall,trim.
Re: Curved Stairs
Just wondering.....why don't you have the drywall co. come back and pay them to do it?
#30 |
Re: Curved Stairs |
#31 |
KemoSabe
Re: Curved Stairs
fpro, whats the news? Did you get started on those stairs? We want pics, please.
#32 |
Re: Curved Stairs
Ok, here are some pics. It's not complete, but it's coming along.
The curved drywall is 1/4" material and after it's been wet, does yield. Although, instead of using a second sheet to cover the first I think I may resort to plastering it to the finish stage. The section of drywall I cut were using a card board template. If I recut the same pieces they will inevitably end up on the same seams, which will cause more work after trying to get those seamed areas down and covered evenly. If I plaster I can build it up to teh 1/2" stock and eventually even it out cover al the seams nicely. Anyway that's the plan... Here are the pics so far. |
#33 |
Re: Curved Stairs
more pics...
#34 |
Trade: carpenter/ handyman
Re: Curved Stairs
Wow! How in the world did you curve the oak like that? Wouldn't thin MDF work better than sheetrock if you are just going to plaster it anyway?
Steve |
#35 |
KemoSabe
Re: Curved Stairs
fpro, that looks very nice. I see what you meant by the steep angles on the curve now. Looks like the metal studs performed well in that situation. You might be better off with the plastering idea, that is asking alot of the drywall alone. Please post a thread in framing forum with details of how you utilized the metal studs, not everyone looks in the drywall forum. Thanks, looks awesome.
#36 |
Trade: DRYWALL CONTRACTOR/TAPER
Re: Curved Stairs
I did the taping on a staircase like this 10 yrs ago ,they used masonite instead of rock ,we coated with durabond a couple times then plus 3 or some topping mud .I got a feeling that after a few years of bouncing steps and dry wood it's gotta be cracked up.They should've used 1/4"rock.
| The Following User Says Thank You to MUDBUCKET For This Useful Post: | fpro (05-20-2009) |
#37 |
Butt Expert
Trade: Drywall
Re: Curved Stairs
#38 |
Profit is not dirty.
Trade: Residential Drywall and Taping
Re: Curved Stairs
When doing curved stairs, we use blocking every 12" oc, and to get your curve use polly and staple it to the curve you want to create, make sure it is tight, and firm, trace the stair angle to the wall on both sides using a marker, While you are doing this, make sure you have a 12' sheet 1/2" soaking in water. Remove the polly making sure you know which end is up. and trace onto the drywall laying flat. Cut out and install. some triming will needed to be done, and if you dont feel confidant it will fit, might be to narrow, add a bit to our lines.
We have done many, and this is the way we do it, and it works well. Jay
Profit is NOT a dirty word....Cheap is.... |
#39 |
Capra aegagrus
Re: Curved Stairs |
#40 |
Trade: renovator
Re: Curved Stairs
I recently did something similar - a corkscrew-shaped wall in the tunnel for a skylight. The lite was one rafter wide, but the opening in the ceiling was to be two rafters wide, and not centred on the skylight - so one face of the tunnel was between the upper chord at the4 skylight and the bottom chord of the next rafter over, creating a continuously changing angle between them just as these stairs.
So, since we're on the topic, I made a thread in the drywall pic area just for fun: http://www.contractortalk.com/f89/co...-tunnel-59215/ Since a lot of the work is the framing, maybe I'll post a link to it in there too. |
| Tags |
curved stairs ![]() |
| How much to charge for new stairs | skarrlette | Finish Carpentry | 40 | 12-14-2010 05:38 PM |
| Aussie stairs american style | Hofmann | Decks & Fencing | 72 | 07-15-2010 06:15 AM |
| Bamboo on stairs with warped stringers | tgeliot | Flooring | 6 | 11-02-2008 12:35 PM |
| curved deck | greggmig | Decks & Fencing | 22 | 09-12-2008 08:49 AM |
| Are uncut stringers old fashioned for stairs? | atari | Finish Carpentry | 2 | 05-30-2006 01:59 PM |
