Cracked Walls
Old 07-13-2009, 09:05 PM   #1
Paragon Home Re's Avatar
Trade: Home Renovations
Cracked Walls
Two years ago, I built a sunroom addition on a house. The floor joists are above ground and supported by a ledger board attached to the house and a beam which is supported by 3 metal posts with helical plates drilled six feet into the ground. Every winter there appears a 1/4" vertical crack in the wall above the sliding patio doors running up to the ceiling. The crack closes in the summer.
I'm pretty sure the foundation is not moving so I am wondering if there is just some movement in the wall where the patio doors are that is causing the crack to open. Could it be expansion and contraction of the wall frame doing this? Its a shed style roof and the crack appears on the side wall above where the patio door is.
Any ideas on either a cause or a solution?
Paragon Home Re is offline
Old 07-14-2009, 01:08 AM   #2
Darren@Partners
Darren@Partners's Avatar
Trade: Drywall Contractor
Re: Cracked Walls
Does this home have a whole-house humidifier? Assuming this addition is heated/cooled with the rest of the house. Have seen these seasonal cracks before and 9 out 10 times the home is not equipped with a humidifier. Need to keep it set on about 25-28%.
Darren@Partners is offline
The Following User Says Thank You to Darren@Partners For This Useful Post:
coveinspiration (07-14-2009)
Old 07-14-2009, 11:11 PM   #3
Drywall & Painting Pro
Sir Mixalot's Avatar
Trade: Hang, Finish, Texture, Paint, and Repair.
Re: Cracked Walls
Is it a vertical crack at one of the corners of the slider? When hanging drywall, it is best not to have a joint in these areas.
Sir Mixalot is online now
Cracked Walls Paragon Home Re Construction 4 07-06-2009 09:37 PM
prepping cracked bathroom walls 72chevy4x4 Painting & Finish Work 8 03-26-2009 08:16 AM
Tall walls (2-storey walls) Zoltar Framing 21 03-11-2009 01:00 AM
here's a painting price list...... Jer44 General Discussion 9 02-17-2009 08:30 AM
