Trade: drywall remodeling new con.
Could Use A Scend Opinion
Can anyone tell me how much movement there would be in a roof at a 45 degree angle.
I’m remodeling a loft and I’ve added some walls that run parallel to the trusses. My concern is that if there is movement, the tape will peal out where the new drywall on the walls meats the old drywall on the ceiling. Normally I leave my screws some distance from any interior wall to prevent this but this time it wasn’t an option since the ceiling was already there. |
Re: Could Use A Scend Opinion
Looks a lot like what I did in my
attic 30 years ago, no cracks so far. Of course it also depends on how stiff the floor is. That's where the pumping would come from.
Trade: DRYWALL PROFESSIONAL
As long as the framing wood is dry and the house is a couple years old there should be no problem. I do notice a door close to the corner. To play it safe I would run a bead of tite bond heavy duty construction adhesive down the angle and butt the wall up to it. This should lock the ceiling to the wall and solve any separation problems.
Rock it...
you can float that much 5/8s and be fine
| Wavy OSB roof, your opinion needed. | Apt Builder | Roofing | 48 | 02-08-2008 06:23 PM |
| Electrical Contractors Opinion | hanapaa | Contractor Licensing | 0 | 01-10-2008 01:57 PM |
| Any Opinion on Spacepak? By what I've seems I am convinced this will replace | A.D. Const | HVAC | 9 | 08-23-2007 04:34 PM |
| the best exterior finish -your opinion | milos | Painting & Finish Work | 5 | 03-20-2007 10:16 PM |
| Opinion about material pricing | eXpatRioteX | Construction | 9 | 03-12-2007 02:53 PM |
