The ceiling grid itself, if hung correctly could support the weight of 1/4 inch drywall, they make vinylrock ceiling tiles that are about 3/8 inch thick drywall covered with vinyl. But don't hang drywall from it, ceiling grid is pretty flimsy and drywall needs a solid surface to hang from. You can frame the ceiling down or as mentioned above they make a suspended ceiling grid that is ridgid and gets screwed together that is meant for hanging drywall from. I have used them many times and they work great, ten times stronger then normal ceiling grid.
