Ceiling Tile Smell?????/
Old 03-08-2011, 08:12 PM   #1
buildpinnacle's Avatar
Trade: Public Insurance Adjuster
We recently had a fire loss at a municipal building and as a part of the restoration replaced all of the tiles in the building. We used 2 types of tiles.....standard contractor grade tiles and a USG Illusion 2742 reveal edge tile in some portions of the building. We have had several complaints from staff that the areas where we used the reveal edge tiles are emitting an obnoxious smell that is giving the Secretary and City Manager headaches. It is most noticeable after the offices have been locked up over the weekend and after you have been in there awhile it is more faint. I have never smelled it very strongly, but they insist it is really bad when you first open up the offices. I have smelled the reveal edge tiles and the standard tiles and I do recognize some emission from the reveal edge tiles that I do not recognize from the standard tiles. It seems to be a paint type smell to me which makes sense, but it will not go away. I have found several posts on the internet of people complaining of this from Armstrong tiles, but not USG.
Has anyone experienced this and what did you do to resolve it? I am scheduling an air monitoring test in there to determine whether the smell is harmful but even if it is not it will not make it go away.
Appreciate the thoughts in advance.
Pinnacle Limited - Public Insurance Adjusters
http://pinnaclelimited.com
http://harrycane.com - An Amusement Park for Weather Freaks
buildpinnacle is offline
Old 03-08-2011, 08:49 PM   #2
Drywall & Painting Pro
Sir Mixalot's Avatar
Rewards Points: 18,067
Re: Ceiling Tile Smell?????/
You probably already saw this. But, here's the MSDS on those tiles-->http://www.usg.com/rc/data-submittal...ata-SC2288.pdf
Apparently these tiles are a
Low Emissions (VOC Class)
Classified as low-emitting per standards established
by the Collaborative for High-Performance Schools
(CHPS), following California Specification 01350
testing methods.
-Paul
Sir Mixalot is online now
Old 03-08-2011, 09:26 PM   #3
Commercial Contractor
Mud Master's Avatar
Trade: Commercial General Contractor
Rewards Points: 1,000
Send a message via AIM to Mud Master
Perhaps someone just has REALLY bad gas and is blaming it on the ACT.
Originally Posted by katoman View Post
And when the day is done, I can look myself in the mirror, with pride, and say " you're a craftsman, well done. "
Mud Master is offline
Old 03-08-2011, 09:39 PM   #4
That could very well be.
-Paul
Old 03-10-2011, 04:58 PM   #5
CJA's Avatar
Rewards Points: 150
If you installed what was spec'ed then suggest to the client an alternitave tile. As a C/O of course.
CJA is offline
Old 03-10-2011, 05:47 PM   #6
BigReds's Avatar
Trade: General Contracting / Handyman
Rewards Points: 75
sounds like poor ventilation. Is there enough return openings in ceiling?
BigReds is offline
Old 03-11-2011, 09:45 AM   #7
Apparently, there is a product called Butyric Acid that is used in the mfg process and in very extreme cases, it can emit an odor. The odor is considered nontoxic and is not harmful to humans, but that doesn't solve the odor issue. We have a rep from USG coming in to investigate further. How much you want to bet their solution is going to be to take a couple tiles out of each room, throw some fans in there to move the air around. We have also decided to install charcoal fileters at all return air units to filter any fumes presently in the area. I'll post the solution in case anyone ever comes up against it down the road.
Thanks for the thoutghts.
Tile on the Ceiling orson Tiling 23 06-18-2013 03:27 AM
Tile Installation Failures in a High End Remodel ChrWright Tiling 139 03-04-2013 06:28 PM
big tile job mnjconstruction Tiling 68 05-23-2010 09:44 AM
information on fixing a bad tile job bford General Discussion 4 09-30-2008 07:44 AM
How do you install marble tile on the ceiling? c1238 Tiling 14 05-20-2008 01:03 AM
