Trade: General contractor/property manager
Ceiling Texture - Small Question
I am contracting a basement for my brother in law and he decided that he would hang and finish the drywall. This is someting that I advised him not to do. I explained time and time again how easy it is to screw up - but he said he could do it and needed to save money.
When texturing the ceiling with a stomp brush - there is usually sort of a ridge made which the painter can run his brush in to trim out the ceiling. I am painting so this is why I am wondering - to make sure that this is done right. What technique is done to get that smooth edge/channel for in inside corner that touches the ceiling. If someone could explain I would appreciaite it. Thanks |
#2 | |
Butt Expert
Trade: Drywall
Re: Ceiling Texture - Small QuestionQuote:
After you brush the ceiling to put on texturing, stomping, I believe it can be called. How does the mud not get on the walls? And how do you make the transition from wall to ceiling in the corners where the wall ends and the ceiling starts? Do you just run a knife along the corner or is ther something else to it?
This may be a bad question but I am not understanding how it works? It seems like when you coat the brush in mud and smack it against the ceiling that it would splatter against the walls a bit especially right near the finished walls. |
Trade: General
My painter can do this by hand! and eye...
But since your Not a painter...If it's a rounded edge use a Chalk line (White) to snap a straight line you can follow. If it's a corner with ceiling thats heavy in texture you may want to use a 12" taping knife to guard the ceiling from paint... as you move along the top (cutting in). GOOD LUCK! |
Trade: drywall
After you texture,use a 5 or6 " knife to skim coat the top wall angle.
Use the same mud that you textured with. First off, Scrape off the excess mud left from the texture. It will tack up pretty quick, and coat the angle. After the ceiling dries, sand with an angled sanding block. |
#6 | |
Trade: Drywall, Modulars, Remodeling
The house I grew up in these guys came in and did a stomp brush pattern with a design in the center of the room and they made a border all along the ceiling (on the ceiling) with a 4" knife, flat and smooth. It actually looked pretty cool.
| ceiling texture labor | Jthebuilder | Drywall | 9 | 10-08-2011 10:37 PM |
| ceiling texture | Jthebuilder | Drywall | 5 | 07-05-2011 08:03 AM |
| Billing on small jobs | Philly Dude | Business | 14 | 11-16-2008 04:25 PM |
| Question about small drywall job we're doing.. | Dorman Painting | Painting & Finish Work | 4 | 10-30-2008 06:40 PM |
