Trade: Hardwood flooring contractor
Ceiling Gaps
Just put up some 5/8th inch drywall and there is some crown molding. I got lazy and put up a sheet and left about an inch gap between the top of the molding and the bottom of the drywall. there is no wood to screw a small piece of drywall to. What would be the best solution. I was thinking spray foam it then caulk it. It's a rental and doesn't have to look perfect. Thanks
Chris Frate Pasquale Floors |
#2 | |
Re: Ceiling GapsQuote:
Fill in the gap with the durabond. When dry, scrape flat. Attach Mesh over the length of the area. Apply a coat of more durabond (fresh batch). After drying- Then coat as needed with regular compound. Example: ![]() ![]()
- Build Well - |
Trade: Drywall, Plaster,Interior Demolitions,Small Repairs
Re: Ceiling Gaps
I like your style.....haha
I second that technique. use some 5 or20 minute.....depending on how much packing you gotta do. |
Re: Ceiling Gaps
Great... thanks so much guys
| Vertically installed suspended ceiling | Maplehead | Remodeling | 13 | 03-29-2007 10:06 PM |
| tips for cutting into a ceiling / wall corner | Zeebo | Painting & Finish Work | 30 | 11-30-2006 09:36 PM |
| Raising ceiling height in the LR and D- room. | marcotte64 | Construction | 2 | 04-02-2006 10:33 AM |
| Drop ceiling question | Eric K | Remodeling | 5 | 12-16-2005 07:47 AM |
