#41 | |
Trade: Framing Contractor
Re: Caulk The Corners?Quote:
I'm not saying to caulk inside corners, but it did work in my house for 11 years for some reason.
Joe Carola |
#42 |
Trade: Control Systems
One part of me was thinking "that ain't right" but at the same time I couldn't think of a good reason not to do it....
Caulk is more flexible then mud...but I'm pretty clueless about such things. |
#43 |
Trade: Drywall
weird but it seems like it would work if the the hanging was real tight. i think i will stick with taping the corners.
#44 |
Linear Shower Drains
Trade: Linear shower drain installations & waterproofing
Yes it's very common.
You will see all unskilled dry-wallers and DIY'ers doing this after they struggle with inside corners. Most don't know to hit one half of the corner first and go back to the other half the next day. After failing miserably Chaulking seems to make sense. I like to pro bead (paper faced metal) inside corners. Takes almost all the skill set out of it and makes for killer cut lines for the painter.
John Whipple (By Any Design Ltd.) - Member of Terrazzo Tile and Marble Association of Canada, the National Kitchen & Bath Association and the National Tile Contractors Association. Specializing in Vancouver bathroom renovations, linear shower drain installations and shower waterproofing procedures. |
#45 | |
paper hanger,painter
"]Takes almost all the skill set out of it and makes for killer cut lines for the painter Thanks for that |
#46 | |
Trade: Drywall
#47 |
I'm not sure if there was any sarcasim in the past posts.
There is skill of course in install paper beads. But if you watch a master drywaller install inside corners they make it look easy. I have tried and tried and can't pull it off. But with the probeads we take our time 10' at a time and don't have to worry about taping half the seem at a time. With a little practice those inside corners will look like a pro did them. Setting the outside corners with pro beads is another matter. Much larger learning curve.
| 100 miles of caulk | Tinstaafl | General Discussion | 52 | 08-26-2009 07:59 PM |
| Problem in corners | woodchuck2 | Painting & Finish Work | 28 | 08-01-2009 11:07 AM |
| To Caulk or not Caulk. | HandyHails | Ceramic & Stone Tile | 11 | 03-10-2009 07:45 PM |
| Feedback on corners with J pocket | swanee | Windows, Siding and Doors | 7 | 11-16-2008 09:10 PM |
| Caulk quality | Ralph6 | Windows, Siding and Doors | 5 | 09-04-2008 06:33 PM |
