Caulk The Corners?
Old 10-09-2009, 08:53 AM   #21
Superintendent
CINEMASUPER's Avatar
Trade: commercial construction superintendent
Re: Caulk The Corners?
Only a hack would leave work like that.IMHO
CINEMASUPER is offline
Old 10-09-2009, 10:43 AM   #22
Frankawitz's Avatar
Well they must figure since commerical buildings are always changing why waste the time tapen and mud just slap caulk on it then stand back and say "Looks go from my house!" when it comes to commercial work you can get away with cutin corners, cause there aint no one living there to see all the crap
Frankawitz is offline
Old 10-09-2009, 10:50 AM   #23
Rockhound's Avatar
Trade: Drywall Hanger
Send a message via Yahoo to Rockhound
Alot of prefabs and no-frills builders do this. Yes its quicker. Yes it looks better than nice clean sharp corners....if you are drunk or leave the lights off. The outfits that prefer this also love doing things like dropping in ugly bulkheads for heat returns that the inspector found were never put into the plans, wedging a toilet between the crappy tub and a closet sized perfectly for a folded washcloth, and having doors hinged to hit the landing thats too close to the front wall.
Rockhound is offline
Old 10-09-2009, 11:30 AM   #24
wmallock's Avatar
Trade: home improvment
just plain lazy and wrong and will bite you in the ass
wmallock is offline
Old 10-09-2009, 10:14 PM   #25
Construction Connoissuer
CCCo.'s Avatar
Trade: Construction Remodeling - Renovations Repairs
Location: Kirklin, IN "Proudly Serving Central Indiana Area"
I definetly would say that it isn't the proper method, but I can see some instances where it may work or be a viable option, such as;
I have done it personally in really tight closets that you just can't hardly get into them period to hang, let alone get your knive in there to tape and mud it correctly.
I also think in a commercial application that most walls aren't load bearing at all, so IMO this method would be more suitable against stress cracks and/ or settling.
I would never do it in a residential situation, or a commercial wood frame structure, because there will definetly be problems, and warranty call back issues.
Just because its "FAST" doesn't make it right, or make it the most cost effective method. If your called back to repair it later, you didn't save a penny with the "FAST" approach.
CCCo. is offline
Old 10-09-2009, 10:34 PM   #26
stp57's Avatar
Trade: carpenter/ handyman
Sheesh! How many tubes did that guy use? Maybe he should have shoved foam caulk saver in there first?
Steve
Originally Posted by Frankawitz View Post
I run across caulk in the corners all the time, but that's plaster and a lot of guys figure it's easier to caulk then tape and mud the corners, but new sheetrock with no tape that is just wrong
stp57 is offline
Old 10-09-2009, 10:43 PM   #27
CCCo.'s Avatar
Originally Posted by stp57 View Post
Sheesh! He should have shoved foam caulk saver in there.
You mean "backer rod"
Never heard it called caulk saver, thats funny.
The things people will do to save money.
CCCo. is offline
Old 10-09-2009, 11:23 PM   #28
Anti-wingnut's Avatar
We do it sometimes in commercial work, but when we do, we put a piece of L-metal corner on the new wall, and leave a slight gap against the old. It certainly doesn't save any time, but gives a good product against movements
Anti-wingnut is offline
Old 10-09-2009, 11:53 PM   #29
Plaster Guy's Avatar
Trade: Plaster/Drywall
If it doesn't save time why not do it the right way? Doesn't sound like a very good 'short-cut'.
(I'll grant you that it'll probably hold up fairly well with the L-metal though.)
Plaster Guy is offline
Old 10-10-2009, 09:28 AM   #30
boman47k's Avatar
Steve
Only if he has no 3/4" caulk.
boman47k is offline
Old 10-10-2009, 11:38 AM   #31
Head sawdust creator
Bummie's Avatar
Trade: Jack of All.... Master of a Couple
Sounds like a hack!!!
I like the idea of using it on the flats but filling the bevel .... and making it look good .... would be a real test!!!! LOL
"Whether you think you can or think you can't.... you are right!!!" Henry Ford
Bummie is offline
Old 10-10-2009, 11:40 AM   #32
Like I said, it doesn't save time, and possibly costs more. As such, it is not a short-cut, and is done solely to give a better product under some very specific conditions.
One location could be where a partition wall abuts a curtain wall at a 90* angle. Sometimes the wind loading will crack any tape joint, and the caulk/corner bead combo gives a product which resists cracking better than other products.
Similarly, at times a new wall may join an extensive existing wall. If the tape is ran onto the existing wall, the entire old wall may be needed to be painted. This wall could be up to 100' long, with many high-tech work stations along the way. Using the caulk method will allow the painting to end at the new wall, and the existing need not be painted. Using this rather unconventional method allows the customer to save money, to not interrupt work operations, and to receive a product of high quality. You may disagree with it, but in commercial work other variables come into the decision making process that are not factors in taping up a new bedroom.
The Following User Says Thank You to Anti-wingnut For This Useful Post:
Plaster Guy (10-10-2009)
Old 10-10-2009, 12:02 PM   #33
When you're working on the 40th floor of a 50 storey building downtown, with the suits and high-brow architects and designers, you'll realize just how stupid a statement that is. This kind of stuff is renting for $50.00/ sq ft per year. Not like the high skill required to finish off a kiddie room.
Old 10-11-2009, 10:20 PM   #34
stp57's Avatar
Thanks, I couldn't remember what it was called? It does save caulk, but it still doesn't make it right to use caulk in the corner.
Steve
stp57 is offline
Old 10-12-2009, 09:12 AM   #35
Frankawitz's Avatar
Boy anti-wingnut I guess you don't look around your commerical building to much, cause if you read the posts there are a lot of guys who know this is going on yet a Super hasn't seen it. Yeah maybe you should look closer to your buildings, I bet your from New York paying that kind of money per sqft You couldn't pay to live there.
The Following User Says Thank You to Frankawitz For This Useful Post:
jeremy-lvhm (10-15-2009)
Old 10-12-2009, 11:52 AM   #36
Profit is not dirty.
AARC Drywall's Avatar
Trade: Residential Drywall and Taping
that would never fly around here...we would be laughed out of town. if its for commercial that is different. the walls are ment to be temporary. therefore they can be taken appart easily.
Profit is NOT a dirty word....Cheap is....
AARC Drywall is offline
Old 10-14-2009, 10:30 PM   #37
Big Shoe's Avatar
Trade: Home repairs,drywall,trim.
What are all you guys crying about.... whats wrong with caulking an ''occasional'' joint on remodels or repairs.If you need to be done today and the painters are comming tommorrow. I frame it strong ,hang it tight, flat tape if needed and then caulk it. Works for me and never had any problems. Also this system only works when new wall is tied into an existing wall.
All new(board) walls and ceilings always gets angle taped for sure!
Big Shoe is offline
Old 10-15-2009, 08:06 AM   #38
Sharp Improvements
Norrrrrrrrrrrrm's Avatar
I have seen inside corners taped and mudded then the final is a bead of caulk to fill any imperfections. The one thing I did notice was the paint was shinier in the corner. Anyone see the shiny corner as well?
Norman Sharp
http://www.sharpimprovements.com
Norrrrrrrrrrrrm is offline
Old 10-15-2009, 09:23 AM   #39
jeremy-lvhm's Avatar
Trade: HVACR
I see it alot it commercial applications but admit I am seeing it more and more in residential where it shouldn't be done. My mother bought a flipped house a few years ago where they did that EVERYWHERE. On top of that they sheetrocked over all the old stuff. Caulked corners, around door trim, at the baseboard. EVERYWHERE. I'm actually surprised they didn't duct tape the center joints too.
It sucks because they never caught it when buying the place and I never got a chance to see it before they decided otherwise I would have stopped them. It was harder to notice when everything was fresh and new. A few years later it sticks out like a sore dk.
jeremy-lvhm is offline
Old 10-15-2009, 06:59 PM   #40
kai4791's Avatar
Trade: Residential and Commercial Remodeling
I always run a bead of caulk around all my corners after the primer but before putting a finish coat of paint on. I use Phenoseal, which I feel is by far the greatest caulk out there, to give a nice inside corner.
kai4791 is offline
100 miles of caulk Tinstaafl General Discussion 52 08-26-2009 07:59 PM
Problem in corners woodchuck2 Painting & Finish Work 28 08-01-2009 11:07 AM
To Caulk or not Caulk. HandyHails Ceramic & Stone Tile 11 03-10-2009 07:45 PM
Feedback on corners with J pocket swanee Windows, Siding and Doors 7 11-16-2008 09:10 PM
Caulk quality Ralph6 Windows, Siding and Doors 5 09-04-2008 06:33 PM
