Can We Talk Drywall Cracks?
Old 01-12-2018, 02:03 PM   #1
LPG's Avatar
Trade: Residential Contracting
Rewards Points: 126
First off, I am not a framing and drywall sub/company. Just a GC trying to avoid these costly and annoying issues. Despite understanding how many of these occur, there is always the big crack along a board edge in the middle of the family room or kitchen where the homeowners flips out.
Theres always the occasional screw pop or crack along board edges. And depending on the situation, we can typically just re secure the board edge with new screws, OR completely open up the area(if board edge is just hanging free), add some plywood backing and cut a new piece of board, tape,skim, repaint(hopefully not entire room).
So Id like to really discuss-
1)What do you guys find as the most common culprit, and what can we do before they happen.
2) What is the best route to take to fix a crack along a board edge?
LPG is offline
Old 01-12-2018, 02:21 PM   #2
Big Johnson's Avatar
Trade: Contractor and Grunt
Rewards Points: 2,962
Re: Can We Talk Drywall Cracks?
Truss uplift.
Big Johnson is offline
Old 01-12-2018, 06:19 PM   #3
TheConstruct's Avatar
Rewards Points: 2
Interior or exterior wall? Floor above or roof? Vertical or horizontal seem? What do you mean edge of board is just hanging there? The vertical edge of the sheet needs to land on stud or butt board, shouldn't be hanging there. Possibly framing drying and/or house settling as weight in material is added.
TheConstruct is offline
Old 01-12-2018, 06:50 PM   #4
Ohio painter's Avatar
Trade: Painting and wallpaper
Rewards Points: 2,354
As a painter doing repaints in 5 -10 year old houses, I am questioning the amount of mud being used finishing drywall, especially in corners. I think if you add in the overuse of lightweight and ultra lightweight mud, could this be a factor too?
Ohio painter is online now
The Following User Says Thank You to Ohio painter For This Useful Post:
Sir Mixalot (01-16-2018)
Old 01-12-2018, 07:51 PM   #5
Lettusbee's Avatar
Rewards Points: 2,520
My engineer says these cracks come from not having sufficient king/jack stud combo.
Lettusbee is online now
Old 01-14-2018, 08:59 AM   #6
LPG's Avatar
Rewards Points: 126
Typically my projects are single floor residential and cracks have typically occurred in ceilings. We use manufactured trusses and typically run hi hat channel to screw drywall into.
I am really wondering about the comment above regarding too much mud. This just could be it.....
By board edge hanging, it doesnít happen often but we have had some cracks, which upon investigation, the hangers didnít properly screw the board up, or were sloppy in cutting. At that case we would typically cut a hole and resecure with furring/metal studs/whatever we have on site.
LPG is offline
Old 01-14-2018, 09:12 AM   #7
Wormdrive Operator
heavy_d's Avatar
Trade: Contractor
Rewards Points: 6,438
You may have answered your own question.
Sent from my SM-G930W8 using Tapatalk
heavy_d is offline
Old 01-15-2018, 05:44 AM   #8
To clarify, I think I am finding taped joints where there is not enough mud. Especially inside corners.
Old 01-15-2018, 07:33 AM   #9
Thatís what I thought you meant, itís pretty hard to get too much on an inside corner. Iím sure it can be done but I usually see bare tape after the mudder sands.
Ohio painter (01-15-2018)
Old 01-16-2018, 04:55 AM   #10
3bar's Avatar
Trade: carpenter
Rewards Points: 460
biggest cause in my opinion is sloppy framing and lack of bracing and proper nailers. i've probably framed at least 600 units and never really had callbacks for cracks or truss uplift, or screw pops even.
drywall should be glued to studs. and joints prefilled with durabond before tape.
3bar is offline
The Following User Says Thank You to 3bar For This Useful Post:
Sir Mixalot (01-20-2018)
consequences of improper steel stud drop ceiling installation mohdmaruf Drywall 29 04-02-2013 11:43 PM
"Quick" drywall patch robert c1 Drywall 23 01-23-2013 05:10 PM
Looking for Drywall Sub in Norman OK Kaiser Help Wanted or Looking For Work 0 12-12-2012 02:04 PM
Drywall sagging on 24" o.c. ECinc Drywall 20 10-30-2010 08:31 PM
Radiant Ceiling Heat - Drywall Falling Again CliffHollen Drywall 7 04-05-2010 04:18 AM
