Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Drywall
Old 02-01-2006, 09:50 AM   #1
Trade: Drywall
Question Bulging Screwheads not ScrewPops...4 year problem
We have been having a problem with high-end drywall construction for 4 years. We are screwing and gluing and sanding the screw heads after 3 coats. The house is fine while it sets, but when the heat is turned on there is usually a paper thick film of compound bulging on the screw heads. We are properly setting the screw heads and not breaking the paper. We have tried many different types of compound, glue, and screws. We are leaning toward moisture in the lumber, but in some cases it happened in both existing framing and new framing. Anyone else having this problem or does anyone have any ideas for a remedy? Thanks
georgiamudman is offline   Reply With Quote
Old 02-01-2006, 04:25 PM   #2
You're probably using 1 5/8" screws, - - use 1 1/4" or even 1", - - you'll get less shrinkage along the screw length.
Tom R is offline   Reply With Quote
Old 02-01-2006, 06:35 PM   #3
Any of these jobs involve trusses or really long spans?
TimNJ is offline   Reply With Quote
Old 02-01-2006, 08:41 PM   #4
Trade: drywall
do you notice this before or after it's been painted?
drywaller56 is offline   Reply With Quote
Old 02-02-2006, 07:53 AM   #5
Trade: Drywall
Usually large trusses in these houses. The problem is happening on almost every screwhead on the walls and ceiling. Usually in the middle floor of the house. We have seen it before the houses are painted and after. It just depends on when the heat is kicked on. They are so much easier to repair when nonpainted. Thanks
Old 02-02-2006, 06:38 PM   #6
Trade: drywall
how are you finishing them without the heat being on? What are the conditions when you do the finishing?
Old 02-03-2006, 01:00 PM   #7
Trade: Drywall
The temperature is moderate enough in Georgia to finish without the heat being on. The drywall is usually done without the heating and air being operational. Space heaters are used if needed. The conditions vary, but the problem usually happens after the homeowner has moved in and turns on the central heat and air.
Old 02-03-2006, 04:57 PM   #8
bulging heads
are you using a premix, or not? we always use easy sand 90, tow coats, and then a plus 3 third. have never had a prob, and dont sand them either
S&P Builders is offline   Reply With Quote
Old 02-03-2006, 05:05 PM   #9
Thats an extreemy long time to have the problem, but is a seasonal problem, or only happens with a certian builder?.
I (once again) would have to agree with Tom R. It sounds like you may be using too long of a screw.
Next time, use a moisture meter on the lumber and see what it says.
Afetr four years, you should at least have the conditions figured out.
Peladu is offline   Reply With Quote
Old 02-03-2006, 08:55 PM   #10
FRAME ON!
A+Carpenter's Avatar
Trade: Decks,All phases of remodeling,
It is the lumber pushing the screw out. The lumber yard is demanding lumber faster then the kiln can dry it. TRUST ME I AM PROFESSIONAL. I would back the screw size down as said above also.
A+Carpenter is offline   Reply With Quote
Grading problem and solution needed, water can't escape... Little Excavation & Site Work 12 05-15-2007 02:45 PM
Washing Machine/Floor Vibration Problem NHCharger General Discussion 13 01-18-2006 07:52 PM
Electrical problem? Brian Electrical 5 12-27-2005 11:16 AM
Landscape solution to basement moisture problem RJC Construction 3 11-21-2005 01:34 AM
