Bubbled Paper
Son had a few places to bubble on him when he laid the bedcoat and tape where he either didn't have enough mud or squeezed to much when bedding the tape. My wife and I have been dealing with the eminent death of her mom ( day or two now, if not hours), and I have not been able to be there to help with that part. I did go over to do the corners and maybe correct what i could in a rush. Anyway, i had him to cut the few bubbles out and just put more mud on without replacing the paper. Comments appreciated.
Re: Bubbled Paper
Too dumb a question? Or am I the only one to admit doing it?
Trade: Home Improvements
Re: Bubbled Paper
If it's just a small spot like on the edge or a small spot in the middle. I just cut it out and fill it in with durabond. Bigger areas I will pull the tape reapply tape with durabond.
#4 | |
Re: Bubbled PaperQuote:
Normally, I would replace the tape also, but since I am just iin and out now due to ma-in-laws illness I just cut the spots out (some in the middle ) and remudded. I can always fix if it does not hold up. thanks for the response. |
It's all about the Avatar
Trade: I have no face!
Re: Bubbled Paper
Your bedding compound was not wet enough. This is a real common thing for first timers.....The tape will draw the moisture from the compound so fast that it does not have time to bond. If it is just a couple of spots use wood glue under the tape to bond it to the mud and continue on. Wood glue can be used to bond the tape or paper corners to the board. Not very cost effective, but will give fast results.
P.S. Never blame it on a blood relative when a minun or lacky will do.
Re: Bubbled Paper
Also Using a siring inject wall paper past in to the bubble. Done this in the past and works good.
#7 | |
| Type of Paper Under Hardwood | CharlieDaw | Flooring | 2 | 04-12-2007 10:43 PM |
| Paper Adhesive tape. | jstrand23 | Drywall | 1 | 03-07-2007 06:02 PM |
| commercial wall paper removal | rservices | Wallpaper | 1 | 06-28-2006 09:58 PM |
| Felt paper used as insulation??? | Age | General Discussion | 9 | 06-10-2006 04:25 PM |
| why primer is bubbling up over wall paper | Zeebo | Painting & Finish Work | 2 | 07-10-2005 10:11 PM |
