Trade: General
Blue Board
Is it ok to only finish blue board the same as typical drywall instead of white coating the entire board? Will the unfinished surface take paint the same as white board or MR (green) board?
I am asking for another guy, so I don't know this, does blue board have tapered edges or square edges? Concerned about the D/W tape being covered easily with the block and skim coats. Last edited by 240 LTS; 02-17-2009 at 08:23 AM. |
Butt Expert
Trade: Drywall
Re: Blue Board
Are you talking about drywall or plaster board?
I like Green things
Re: Blue Board
Same thing, different paper. Same set up as regular dry wall just special paper for absorbsion of water from the veneer coat plaster.
Why would you spend the money on blueboard and finish it like regular rock? |
Darren@Partners
Trade: Drywall Contractor
Re: Blue Board
Core is different, paper just different color so can tell it apart. Yes edges are tapered, finish same as reg. drywall. Use primer and 2 coats of color, should cover fine. "Blue board" being moisture resistant also comes in shades of green. Purple (here) is plaster base.
#5 | |
I like Green things
Re: Blue BoardQuote:
Look that up, I am positive the paper is the difference. |
#6 | ||
Sean
Trade: drywall contractor
Re: Blue Board
It used to be the blue board or Kal Board was not tapered, but the last times we have used it, it was tapered, so we pre filled with base coat before skimming the whole wall with base coat, then finish. The paper is definitely fuzzier so you might have to sand the primer after it is dry, then paint.
| Licensed & Insured | bjg5240 | Business | 34 | 06-09-2009 07:56 PM |
| Stucco over Permabase Board? | slapash14 | Masonry | 5 | 02-12-2009 08:56 PM |
| OSB with rigid foam board factory attached | im4snow | Framing | 1 | 10-29-2008 09:22 PM |
| Haint Blue | Dave R | Painting & Finish Work | 6 | 06-02-2008 11:03 PM |
| Transitioning drywall with cement board | Lone Wrencher | Drywall | 19 | 03-02-2008 07:05 AM |
