How much more should I charge for the high stuff ie. regular rate x what factor?
as a union electrician, I get 10% for height over 40 feet. Not sure how that would translate into your computations but if it helps...
Also what is the best way to get up there to board and tape - fixed/rolling scaffolding, skyjack, trampoline?
I like the trampoline idea. Guys get their work and exercise in at the same time. Heck, maybe you could charge your guys for you supplying the "fun time"
Should I or the GC supply?
Your choice. If GC has other work where whatever lift is needed , it could be a cost savings to him to supply it. You can present the bid both ways and let the GC decide.
If a powered man lift can be used on whatever floor there is, it may be more cost efficient than rolling scaffolding. That assembling and climbing time is a lot of wasted time. If not, the rolling scaffold would seem to fit the bill.
