Best Way To Smooth Wall Over Knockdown Texture
Old 01-14-2007, 02:11 AM   #1
dforeid's Avatar
Trade: Misc. Residential
Have a small bathroom remodel job. Currently the walls and ceilings are all knockdown texture. Client wants to go with a 5 foot wainscotting and then smooth wall from the wainscotting up to the ceiling as well as smooth on the ceiling. My thought was to skim coat mud over the existing knockdown to accomplish this. What would you suggest, and what process/mud materials would be best?
Any and all suggestions very much appreciated.....
Don
dforeid is offline
Old 01-14-2007, 07:25 AM   #2
Frankawitz's Avatar
Re: Best Way To Smooth Wall Over Knockdown Texture
Don
The problem your going to have here is that the mud will not stick to a painted surface you should sand the ceiling and walls first then use Durabond 90 brown bag as your basecoat then use topping compound for your skimcoat then sand it out to a smooth finish.
Frankawitz is offline
Old 01-14-2007, 02:52 PM   #3
dforeid's Avatar
Originally Posted by Frankawitz View Post
Don
Frank,
To what degree would you suggest I sand? Just enough to knock off some of the high spots, or completely sand smooth? Also, are you talking sanding screen or more on the lines of an orbital with say a 150 grit? Is there a primer I can/should use before the Durabond 90?
All help appreciated.... also, if there is an easier way to accomplish what I'm trying to do, I'm all ears! This sounds like it's gonna be a pita.
dforeid is offline
Old 01-14-2007, 11:44 PM   #4
theworx's Avatar
Might be a stupid idea. But have you tried scraping the texture off. A spud bar would work quite well (flooring guys use them to scrape a floor). That way your floating would be less to deal with. Something to consider. It's still a lot of work for a small space... Hope you make out OK!!!
theworx is offline
Old 01-15-2007, 12:18 AM   #5
drywaller74's Avatar
Trade: drywall. framing. plastering
Don,
Never had a problem with ez sand 90 sticking to paint, It wouldn't hurt to take some 80 grit on a pole and scuff it up. It may take 2 coats of 90 and then one coat of plus 3 or some other light weight. good luck
Robert
drywaller74 is offline
Old 01-15-2007, 08:41 AM   #6
Frankawitz's Avatar
Don
I would use a palm sander with 80 grit sandpaper to scuff up the paint finish so that you get a bond to the surface. as for using ez sand it's like using ready mix in the busket both are soft, with Durabond in the brown bag it drys rock hard, but the main thing is the bond to a painted surface, the thing is that if it doesn't bond when you go to prime and paint it will bubble and peel. that's the problems I've seen. we talked about this before about mud not sticking to a painted surface. good luck
Old 01-15-2007, 06:36 PM   #7
Custom Finisher
Dwallguy's Avatar
Trade: Drywall
Don
Can you cover it with 3/8 board ( Rerock it)
Dwallguy is offline
Old 01-31-2007, 05:33 PM   #8
Sharp Improvements
Norrrrrrrrrrrrm's Avatar
You can wet it with a spray bottle and use the spud bar thewox was talking about. It should scrape right off, then skim it.
Norrrrrrrrrrrrm is offline
Old 01-31-2007, 07:47 PM   #9
Ohio Drywall's Avatar
Trade: Drywall
Use easy sand durobond,but use 20 min or 45.Something that drys quicker.
Ohio Drywall is offline
Old 02-01-2007, 02:25 AM   #10
Woz the Painter's Avatar
Knock off all that you can with an old 10 inch knife, then use easy sand and skim her out till shes smooth, sand ,prime and paint...
Woz the Painter is offline
Old 02-01-2007, 07:36 AM   #11
Frankawitz's Avatar
The thing with easy sand is it's just like using the ready mix joint compound out of the bucket it's to soft also when you go to paint you may end up with mud peeling off the walls good luck.
Load bearing wall or not??? BMAN Remodeling 26 07-28-2008 07:16 PM
smooth wall questions/frustrations Cummins Painting & Finish Work 23 08-16-2007 10:37 AM
Backyard office, retaining, and privacy wall Team Scream Masonry 8 08-02-2007 11:27 PM
texture to smooth wall seednumb Drywall 2 03-23-2005 07:39 PM
