Best Roller Pad To Use For Skim Coating
Old 03-15-2009, 11:56 PM   #1
stlfixit's Avatar
Trade: Home Remodeling, Basement Finishing
First post! I was wondering what size nap you all use to roll on a skim coat. I played around a little with a 1/2 and 3/8 in. weenie roller
But they both seemed like they wouldn't hold hardly any mud. Is there a lot of sanding
Involved? Will a 9 in. Lambs wool roller work any better? Never done this before
And I'm trying to skim coat over a sand textured wall. What's the best way to do this?
stlfixit is offline
Old 03-16-2009, 12:59 AM   #2
d's's Avatar
Trade: Drywall
Re: Best Roller Pad To Use For Skim Coating
I've had the best luck with 240mm/18mm rollers - get the good quality ones that don't lose their pile. Roll on and pull off tight with your widest trowel or knife. May require 1,2,+ touch up coats depending on the underlying texture. Best to have one guy rolling and another following behind and just do it in 1 meter strips, edges require a bit more attention. The sanding will depend on your skill at applying it but it's pretty easy to get good results - pole sand, light and sponge, then touch up any remaining tool marks or bare patches.
Good luck,
D's
d's is offline
Old 03-17-2009, 01:59 AM   #3
One Life so Live It
Tonyeo's Avatar
Trade: Handyman
So how thick and what type of mud do you use ?
Tonyeo
I only ask because I want to know
http://www.whitebearhm.com
Tonyeo is offline
Old 03-17-2009, 08:28 AM   #4
Darren@Partners
Darren@Partners's Avatar
Trade: Drywall Contractor
Most paint stores carry a double width roller, we use an old cooler for a tray. These rollers are about 18" wide and you can cover a lot of board in a hurry.
Darren@Partners is offline
Old 03-17-2009, 03:28 PM   #5
d's's Avatar
Trade: Drywall
I use 90minute setting or taping for the 1st coat to ensure a good bond and a finishing/topping mud for the second so it can be easily sanded out. Mix the mud looser so it just hangs onto the roller - makes it easier to trowel out. Roll with just enough pressure to get it to roll when it's fully loaded in a big W then put some pressure on it to even it out. You should get close to a square meter per roller load.
Great idea on the double wide roller and cooler. I'll give that a try on the next big skim job. If you're just doing a room or two a regular roller and 5gal pail is adequate.
D's
d's is offline
The Following User Says Thank You to d's For This Useful Post:
Tonyeo (03-17-2009)
off topic --Roller coasters-afraid of heights davinci Off Topic (Non Trade) 16 10-27-2008 07:42 PM
One more airless power roller question steve-in-kville Painting & Finish Work 5 09-19-2008 11:09 PM
18" roller set up salmangeri Painting & Finish Work 3 09-13-2008 09:27 PM
Trouble with roller lines using 18" wooster KJLinden2002 Painting & Finish Work 16 01-01-2008 09:55 AM
Titan power roller... My first impressions steve-in-kville Painting & Finish Work 0 06-17-2007 11:22 AM
