grizl
Trade: carpenter
Basement Rock
hello rockers, any advise for finishing my basement. It gets a little moist in the summer.
slight moist walls. should I, plastic, then rock, with water resistant rock. any suggestions? |
Profit is not dirty.
Trade: Residential Drywall and Taping
Re: Basement Rock
Sounds like you have other problems...find the root cause of the moisture...install a couple of fans to get air moving...
only then once the moisture problem is gone, then use treated wood on your bottom plates, and drywall like normal...u could use the mould resistant drywall...that should help prevent mounld to some degree...but you have to get the air moving .... J
Profit is NOT a dirty word....Cheap is.... |
DavidC
Re: Basement Rock
Strongly urge that you check out www.buildingscience.com before you decide what to do. They have a lot of info on trusted methods as well as common methods that shouldn't be used.
Good Luck Dave
www.CookContractingLLC.com |
Butt Expert
Trade: Drywall
Re: Basement Rock |
Re: Basement Rock
I would wash the walls down with bleach then seal with Drylock paint give it two good coats, then put up furing strips then use foam board 1/2" then sheetrock with densmor sheetrock, if your putting 2x4 framing so you can add electrical, yeah make sure bottom plate is wolminized 2x4. good luck
www.frankawitz |
Trade: We perform landscape design and construction
Re: Basement Rock
We perform basement remodels and installations in the winter months.
We use steel studs off the walls 4'' and green board to help with the mold issues. We also state that we are not responsible for mold conditions with our clauses of advice to prevent it. Number one is to have air moving and a humidifier if it is bad connected to a waste line or to pump it out to a sink or something else. |
General Contractor
Trade: Construction Management
Re: Basement Rock
Sound like an exterior grade problem to me.
DECOSnowRemoval&IceControl Serving Delaware County & Philadelphia Pa 610 457-9721 |
| Basement Waterproofing Help | eagleandbaby | General Discussion | 1 | 10-04-2008 03:41 PM |
| Return Grill in the Basement | orson | HVAC | 7 | 10-03-2008 12:01 AM |
| Floating Basement Walls | McMasters | Framing | 15 | 08-26-2008 11:43 PM |
| Rippable Rock... | ElIngeniero | Excavation & Site Work | 6 | 02-08-2008 08:04 AM |
| HELP! Basement floor disaster | Profiter | Construction | 5 | 07-11-2006 09:01 PM |
