GC
Anyone Using Graco Sprayer For Skimcoat
Was wondering how many companies are using a Graco sprayer to skim coat walls instead of applying by hand. They are about 5k to buy but from what I have seen save alot of time and labor. They have a new 240 volt one that looks as if you could spray smooth stucco through it.
#2 | |
EMF, PLC specialist
Trade: Professional Pan Handler
Re: Anyone Using Graco Sprayer For SkimcoatQuote:
Butt Expert
Trade: Drywall
I use mine to spray skim coat. Much much faster than doing it by hand.
Trade: Drywall
Re: Anyone Using Graco Sprayer For Skimcoat |
GC
Trade: Painting - Restoration
Dont buy one less you have enough work to support it...
Renting is the best way until you have enough jobs to pay for the equipment over time. |
Trade: drywall contractor
Are you spraying the mud on after you have run your box on flats, butts, beads, screws and sanded? So you tape, fill with a seven inch, skim with a ten inch and skim again with a twelve inch, then sand and spray the mud? Or some other way?
#8 | |
GC
I have checked the rental yards and they do not have a sprayer large enough to spray a level 5 finish. I have 2 new houses coming in the works and the price to skim them is what I would pay for the sprayer. I have alot of tools sitting but they are garaged and I am planning on building for at least 10 more years. I have subbed out to drywall crews that spray skim and ones that do it by hand. The sprayer is alot more efficient. I have searched for a used one but no luck. |
Smart phone? Scan me!
Trade: Painting/Framing/Drywall
seriously get one. I want one BAD!!!
#10 | |
Trade: Drywall
You have to come to a level 4, then sand, then spray level 5 then sand again. |
Sounds good. Thanks for filling in the details. The painter primes and paints as usual, I assume.You are gettig rid of the problem of the mud being smoother than the paper.
Butt Expert
Trade: Drywall
Do you just thin your mud about the same consistency as paint? And do you use regular bucket/box mud or the bag texture mud?
The demo I went to by graco had em putting a gallon of water to a ready mud bucket. stir with a paint augur and away you go.
#15 | |
GC
Same way I have seen. 1 guy with a helper mixing and delivering was able 2 spray both houses (2450 sq ft + 2 car garage each) in 1 day. Each house required 3-4 hours to sand to perfect finish (1 guy 1 day). I paid $2200 extra per house for skim coat over level 4. |
:drool: I so want one!!
Trade: Drywall
Re: Anyone Using Graco Sprayer For Skimcoat![]() GRACO MARK lV SPRAYER W/HOPPER AND NORTHSTAR COMPRESSOR Item condition:Used Time left:1 day 21 hours (Aug 04, 200918:39:24 PDT)[Refresh] Bid history:0 bids Starting bid:US $1,975.00 Your max bid:US $Place bidPlace bid (Enter US $1,975.00 or more) Now watching in My eBay (10 items) Shipping:Local pick-up offered.See more services Returns:No Returns Accepted Coverage:Pay with and your full purchase price is covered | See terms
#18 |
Trade: drywall
Brocktologist or Capt-Sheetrock,
Lets say you have a house with 20,000' of drywall. How many man hours to mask off, spray, then sand, ceilings and walls? How much material is used? |
#19 |
#20 |
GC
The 2 houses I had done were 220 4x12 sheets each which breaks down to around 20,000 after scrap. 1 prep guy and 1 spray guy taped masked and sprayed both houses in one day. The taper came back and sanded both in one day. They used around 25 5 gallon buckets for both.
| The Following User Says Thank You to NICKPAUS For This Useful Post: | Muddauber (08-03-2009) |
| Graco XR-7 Airless Sprayer | Panzer5 | Tools & Equipment | 2 | 03-24-2009 10:29 PM |
| staining / varnishing with graco sprayer | meets1 | Painting & Finish Work | 8 | 03-17-2009 01:02 PM |
| problem with magnum graco sprayer | mattsak | Painting & Finish Work | 2 | 10-05-2008 03:22 AM |
| Graco 395 sprayer trouble | Mike Heritage | Painting & Finish Work | 1 | 12-05-2007 08:57 PM |
| Graco / Magnum XR7 Airless Paint Sprayer $285 | ATLT | Contractor Swap | 0 | 11-27-2007 10:03 AM |
