Anyone Prefill Anymore?
Old 02-06-2009, 06:39 PM   #1
Matthew Sargent
Msargent's Avatar
Trade: Painting and Drywall
The guy who taught me used to. I was thinking about doing it since im on a tm job and carpenters are hanging with gaps here and there.
Msargent is offline
Old 02-06-2009, 06:41 PM   #2
Tony M's Avatar
Trade: Drylining
Re: Anyone Prefill Anymore?
It would be rude not to!
Tony M is offline
Old 02-06-2009, 08:37 PM   #3
taper71's Avatar
Trade: Drywall Taper
If you do not prefill then your mud on your tape does not have anything to adhere too hence bubbling occurs( it will fall between the gaps or may act as prefill depending on size of gaps). If it does not bubble right away then it may bubble down the road. All this means is that you may save some time at first, but if you warrenty then you will be going back ( only again if someone notices which 90% of the time nobody will except another finisher). Or you dont go back and dont care or blame it on something like wood shrinkage and expansion. The odd time excess mud may prefill for you while wiping , but if you rely on that alone that can makes you look less of a professional as others who do prefill.
taper71 is offline
Old 02-07-2009, 02:42 AM   #4
MeatBallDryWall's Avatar
Trade: Residential & Commercial Hanger/Finisher
If the job pays as it should, I pre-fill. If not, me tape em. The mud on the backside of the tape will harden & the tape make a patch (If wiped properly). Hasn't anyone on here ever patched a hole with a paper sack b4? Same principal
MeatBallDryWall is offline
Old 02-07-2009, 10:12 AM   #5
General Contractor
Willie T's Avatar
Location: St. Petersburg, FL Minds of moderate caliber ordinarily condemn everything which is beyond their range.
My Gawd! How rude, crude and unprofessional. True finishers use newspaper.
"True eloquence consists in saying all that is necessary, and only that which is."
François Duc de La Rochefoucauld
Bill Everett - St. Petersburg, FL
Willie T is online now
Old 02-07-2009, 10:20 AM   #6
Al Taper's Avatar
Trade: Drywall Finishing
Sometime I will use mesh to cover the gap if not to big then, paper tape with green over it. Or if its two big I will hot mud it with a stiff mix..
Al Taper is offline
Do you pull Cat3 anymore? dcapone Low Voltage 22 12-01-2009 08:20 PM
How to advertise to Designers and Architects? CornerstoneGC Marketing & Sales 37 01-22-2009 02:49 AM
Are there any good painters in So.Cal. anymore? JumboJack Painting & Finish Work 5 08-21-2007 04:15 PM
ceiling corners do you prefill the tapers? kgphoto Drywall 3 07-29-2007 07:16 AM
Robotic surveying instruments mikesewell Commercial Construction 7 07-02-2007 09:33 PM
