Anyone Do A 2 Coat Bevel Joint?
Old 11-18-2009, 09:44 AM   #1
Profit is not dirty.
AARC Drywall's Avatar
Trade: Residential Drywall and Taping
Morning Gents/Gals
One of my tapers and i are having a discussion on how many coats to do with the box's.
Currently he is using the auto taper, then 10" on 2 setting, and final with a 12" on 3or 4 setting.
I am in the mindset that we should be running the 7" to fill the bevels, then 10 on 3 and 12 on 5
I am curious as to what everyone else runs...
J
Profit is NOT a dirty word....Cheap is....
AARC Drywall is offline
Old 11-18-2009, 01:27 PM   #2
Butt Expert
Brocktologist's Avatar
Trade: Drywall
Re: Anyone Do A 2 Coat Bevel Joint?
Why? Are you having a problem?
BTW, as you already know numbers change from one box to another and can change as the blade runs down.Don't forget to check with a new 12 or 14" knife every so often.
Brocktologist is offline
The Following User Says Thank You to Brocktologist For This Useful Post:
Capt-Sheetrock (11-18-2009)
Old 11-18-2009, 06:51 PM   #3
kcremodeling's Avatar
Trade: Licensed Contractor
We run it the same way you do. Banjo, 10 inch box wide open, 12 inch box on 2 or 3. We run the butt joints a little different to cover a 24 inch span. We have become far more efficient using these tools. I have a set of goldblatt tools. They have actually ran pretty good. It's rare we do entire houses but we have dont quite a few basements. I would never consider finishing more than a small room without tools.
http://www.kcbasementfinishing.com
kcremodeling is offline
Old 11-18-2009, 08:13 PM   #4
Capt-Sheetrock's Avatar
Trade: Drywall
Originally Posted by AARC Drywall View Post
Morning Gents/Gals
J
I tape with a bazooka (banjo if its a small one) then bed with an 8 (box) and skim with a 10 (box). In NC the bevels are only 5 1/2" wide, I don't try to cover half the borad on a flat.
Like Brock said,,, just put a knife on the wall,, if its flat, its flat (ever wonder why they call em flats??),, if it ain't, run it again,,,, it really is that simple, ya know, we ain't rocket surgeons !!!!
Capt-Sheetrock is offline
Old 11-19-2009, 07:36 AM   #5
Muddauber's Avatar
Trade: drywall
I run 8"-10"-12". The 12" I'm using now does the best finish on #3.
Muddauber is offline
Old 11-19-2009, 07:39 PM   #6
Trade: Drywall
With all due respect, Why in the hel& are you running three coats on a flat???
Old 11-19-2009, 11:11 PM   #7
Butt Expert
Trade: Drywall
Rush rush rush, who has the time for the third coat regardless if it is necessary or not?
Now if you had something like a 20" box I maybe able to justify it in well lit areas and cathedrals. But an 8" 10" and 12" for flats seems a bit anal.
Old 11-21-2009, 01:14 AM   #8
Thanks all, It just sets my point, I suspect that the blades need replacing, but will check next week. I would rather run two coats, it makes more sense, and cuts out unnessasary steps. We have only had one problem as minor as it was, the contractor said the joint was a bit transparent, we ran a 12" again and all was good.
We do check with the 12 or 14 and all is good, but this gent is use to putting the mud on and sanding later.....mmm its hard to get him to the new ways of box's. Some of our other tapers swear by 2 coats...it makes for interesting lunch topics
J
Old 11-21-2009, 02:52 AM   #9
Hawaii Handyman Remoleing
Aaron111's Avatar
Trade: Honolulu, Hi Handyman Remodeler 510-868-8807
Send a message via MSN to Aaron111 Send a message via Yahoo to Aaron111
Morning Gents/Gals
J
put some pics for us to see ... then I can help you better .... Aloha fro Oahu
Aaron111 is offline
Old 11-21-2009, 05:27 PM   #10
Trade: Drywall
J
that happens alot, IF the GC is used to seeing flats run with a 12, he will assume you don't have enough mud on the wall if you run it with a 10,,,, never thinking to put a straight wdge up to it, to REALLY see. Its hard to argue with ignorance, or "the way its always been done"
Old 11-30-2009, 08:33 PM   #11
Damonceles's Avatar
Trade: Drywall Sub
we 7 box quickset and drag a knife behind the boxer to remove airbubbles and press the quickset into the fiberglass tape. then run a 12 to finish for heavy textures,or a 10 then a 12 for slick finish
Damonceles is offline
Old 11-30-2009, 10:37 PM   #12
Trade: Drywall
We use a bazooka and then bed with a 8 and finish with a 10 for slick-fill. we use a bazooka and bed with a 8 and finish with a 10 for textured walls.
Old 12-01-2009, 09:04 PM   #13
drover_brad's Avatar
Trade: interior systems
when i put on my tapes i fill the bevels then I coat using my 10 inch box on three and, 12 inch on three as well but then do a polish over everything, witch is just thin mud putting it on the taking it off
drover_brad is offline
Old 12-01-2009, 09:22 PM   #14
Trade: Drywall
Are you saying that after you tape,, you "back-skim" the bevels, before you tape and skim? what I'm asking is isin't this a 3 coat fill also? I opligize ahead of time if i read this wroong.
Old 12-01-2009, 11:11 PM   #15
d's's Avatar
Trade: Drywall
I have done a 2 coat bevel and everything else at the request of unfussy renovators trying to save a buck. I'll hang, tape corners with taping mud but wipe clean, mesh the bevels, coat everything with 90min.(using 10" trowels |&( on joints, 2.5 in corner), have a late lunch, quick scrape, coat with finishing mud (10"& 16" flat trowels, 3.5 in corners), let dry 48 hours, sand out, do some pinkies and leave them an old sponge for sanding. Good enough for some - but wouldn't recommend it as your "best finish". My usual is 1st coat with 8" box, 2nd with 10", then roll skim and wipe with 14" offset knife. That being said you could probably get away with it if your boxes were well tuned & you didn't mind some extra sanding and touching up.
Now that I think of it, it probably would save time in rooms with no butt joints - I'll have to try it and see!
D'S
d's is offline
Old 12-02-2009, 09:44 PM   #16
Trade: Drywall
D'S
huh? can you say that in English?
Old 12-03-2009, 01:20 AM   #17
d's's Avatar
Trade: Drywall
Let me paraphrase myself "blah, blah, blah, blah"
d's is offline
Old 12-03-2009, 10:20 PM   #18
oldrivers's Avatar
Trade: drywall applications
as said above each box is different so you cant go by numbers, also how lose you run the mud will change the requirements. 10 inch box then wipe with a blade , then finish with the 12 ,, no 7 " here those are for sissies hahaha just kidding.
oldrivers is offline
Old 12-04-2009, 11:05 AM   #19
Preacher17's Avatar
Trade: Taper
I just let the wall dictate how many coats I put on....
Preacher17 is offline
Old 12-04-2009, 06:13 PM   #20
jmr's Avatar
Trade: drywall contractor
im under the assumption the wider the feather the better. i use a 10" fill coat box and 12" finish coat both are northstars.. JUST 2 COATS on top of tape bed otherwise your over working (unless your getting paid for the additional work). i swear by this method though..
as far as settings go all boxes are different and good sheet rock job pending. north star boxes come pre crowned.. my settings are as follows: fill coat is set at 3 for flat work and 1 for butt joints both walls and cielings, i'll run 3/4 on tape and run another about an 1" next to tape for butts to leave a fill area and come and hand fill the center.... then i'll do 3 on everything.. unless lid is knock down then i'll do 4 for finish..
depending on your box, setting 2 may be too much fill resulting in humped flat work..
just my 2 cents.
jmr is offline
Back Rolling first coat only? joebart Painting & Finish Work 3 09-07-2009 12:26 AM
joint compound under carpet for gaps. mechanix General Discussion 3 12-10-2008 03:49 PM
Hamilton prep coat... Halo Drywall 5 11-29-2008 12:51 PM
Butt Joint problems AARC Drywall Drywall 10 09-14-2008 03:40 PM
Spraying Mud, Skim Coat , Etc... plazaman Drywall 11 11-11-2007 02:51 PM
