Trade: renovator
Alternative To Drywall For Skylight Tunnel?
Gentlemen,
I'm going to be installing a skylight in a bathroom this week. Insulate it as much as you can, these things always have condensation up around the skylight. (Cold climate area) So I was thinking about an alternative to greenboard for drywalling the tunnel. Something impervious. Like concrete board, but not concrete board because of the weight. Like Hardibacker, but not Hardibacker because of the pattern on the face. Anyone used something that worked well? Thanks. |
#2 | |
Professional Instigator
Re: Alternative To Drywall For Skylight Tunnel?Quote:
Trade: renovator
Re: Alternative To Drywall For Skylight Tunnel? |
LET ME SHOW YA SOMETHIN!!
Trade: I do that too!
Prime the hardi....caulk it..... paint it..... done!
DO IT!! DO IT!! DO IT!! |
Edai plywood. It has a smooth surface and is moisture resistant. Home depot and Lowe's sell it.
Doing what I do.
what about the acrylic or fiberglass sheets that are used in the el-cheapo tub wall kits? glue them up, caulk the corners and call it done...
Around The House Remodeling and painting. |
Trade: renovator
#8 | |
Nope good paint and it will look like drywall/plaster when painted. A little skimming helps if you use cheap paint or you can't paint |
azek------4x8 sheets------
How high are the ceilings? The hardi has a bit of texture to it but a couple coats of paint should smooth it out enough to where you could not see it from the floor.
Trade: renovator
Trade: renovator
Nine foot ceiling; 5/12 roof; top of the tunnel will be ~13 ft high. West facing opening so soft evening light, and broadly tapered tunnel, so glancing sunlight on the surface - hopefully everything in my favour to make up for my painting ability.
Construction Manager
Trade: engineering
I don't know if you get this in the U.S. here in Germany you could buy a silicia-based board from the LEX Lindner Group. Easy to go almost like gypsum boards, but it's water proof.
Best regards Matthias Georg |
| Drywall Scratches - Level 5 Smoothwall | HUNG BY FOOT | Drywall | 15 | 03-10-2009 06:19 AM |
| drywall romaina-europe | crystal | Drywall | 20 | 02-08-2009 05:28 PM |
| Paperless Drywall | RKRHOMES.com | Drywall | 3 | 09-22-2008 01:30 AM |
| How much advantage is 5/8 drywall over 1/2"? | Jim S. | Drywall | 2 | 08-26-2008 11:52 AM |
| Drywall alternative | Teetorbilt | Remodeling | 21 | 11-19-2005 11:36 AM |
