Air Bubbles In My Mud
Old 12-17-2009, 07:12 AM   #1
rjconstructs's Avatar
Trade: Residential remodel
Rewards Points: 168
This question may have already been addressed in here, but I thought I would ask it anyway. What causes those pesky little air bubbles to come to the surface of my mud? This happens after I smooth the surface out. I get it like I want it then after a few minutes, here they come. If I lightly knock them down again this usually takes care of it.
I'm curious about what causes this and how I can prevent it.
Any thoughts?
rj
rjconstructs is offline
Old 12-17-2009, 07:44 AM   #2
Lack Of All Trades
Darwin's Avatar
Trade: Construction & Home Improvement Services
Re: Air Bubbles In My Mud
Try to apply it in thinner coats and layers; I believe you are using too much mud for each coat of compound.
Darwin is offline
Old 12-17-2009, 03:33 PM   #3
jmr's Avatar
Trade: drywall contractor
Rewards Points: 25
add a little water and mix your mud very well.. for at least 30 seconds..
jmr is offline
Old 12-17-2009, 09:42 PM   #4
Capt-Sheetrock's Avatar
Trade: Drywall
Rewards Points: 250
Any thoughts?
rj
Those pesky little air bubbles are from "effervasiant" (okay I can't spell) bubbles from the grease and JUNK on the old walls,,, The only way to avoid them is to prime the OLD WALLS ahead of finishing,,, or just deal with em (thats what we do) cause its easier and cheaper than priming everything ahead of time.
Really, its just one of them things that ya have to deal with on re-models. wish I had a magic bullet for ya,, but there ain"t one
Capt-Sheetrock is offline
Old 12-21-2009, 03:41 AM   #5
30 yrs carpentry/drywall
Carpenter Wayne's Avatar
Trade: Interiors/finishes
Rewards Points: 75
The more water you add to the mud - the more "bubbles" you get when applying it (especially when applying thicker coats).
There's a trade off - add more water to run the mud faster with less stress/wear on your arm but deal with more bubbles and having to swipe over the joint/area 1 or 2 extra times to get them to go away
or
add less water to reduce bubbling but put more stress on your arm using thicker mud which causes fatigue faster.
I opt for the thinner mud!
I forgot to mention - there's also another issue to deal with when adding water to your mud. The more you add - the more the mud shrinks as it dries and that causes it to crack. The trick is to not thin it too much when using it for 1st and/or 2nd coats.
Carpenter Wayne is offline
Old 12-21-2009, 06:55 AM   #6
Rewards Points: 168
Thanks for the feedback. I was hoping there was something I was doing that prevented or reduced the bubbles. Thinning my mud is a must for me. It sounds like I'll just have continue to live with air bubbles coming to the surface.
I've heard of old-timers putting a shot of dish soap in their mud bucket but I didn't know what that did or what problems that might cause.
rj
Old 12-21-2009, 07:30 AM   #7
Frankawitz's Avatar
Rewards Points: 1,196
The air bubbles are there cause when mixing the mud air gets trapped in the mud, the more you mix it the more air that gets trapped, try not to mix the mud use it right out of the bucket, unless you have water sitting on top of the mud, then I would give it a slow mix just to get the water mixed in. The brown bag is best used for your bed coat when taping with papere tape or mesh. then if you want to use the white to coat that, but I would use topping compound cause it sands out a lot easier.
Frankawitz is offline
Old 12-21-2009, 07:14 PM   #8
Trade: Drywall
Rewards Points: 250
Frank, he ain't talking about "air bubbles in the mud" (pock marks, or pinholes)he's talking about the little bubbles that come up in a remodel, after you run your mud,,, ya know coming from the junk on the wall, due to the reaction from new mud on old walls
Old 12-24-2009, 05:06 AM   #9
jonny rocket's Avatar
Trade: the rocket.glass finish.learned from the best
we call them pocks or pimples lol.when i coat i dont like adding to much water to my mud cause it can cause the mud to shrinks to much.then you can get humps in your cross seams or the the flats could cup.
try useing light weight usg.the blue lid(for coat only).no water just a little hand soap and mix.
jonny rocket is offline
Old 01-03-2010, 05:46 PM   #10
flippinfool's Avatar
Trade: Home Improvement contractor
Rewards Points: 113
The only time I've had that happen is when blending new and old sheet rock. Spoke to a USG rep and he said, as it dries the mosture can't soak into the old sealed area of drywall. So it comes out the other way "To the surface". If you are getting that with brand new work your not mixing or applying to thick of a coat.
flippinfool is offline
Old 01-03-2010, 05:53 PM   #11
Tim0282's Avatar
If USG and the other major mud manufacturers wouldn't add so much air to the mud to gain volume to fill the bucket, we wouldn't have nearly the problem with the bubbles. Lite mud is the worst for this problem. Plus 3...
I noticed in using some of the "lesser" brands, the problem is not as bad. And mostly not there at all.
Tim0282 is offline
Old 01-03-2010, 06:00 PM   #12
ARealplumber's Avatar
Trade: plumbing
Rewards Points: 75
Have you ever weighed the same size containers of mud from different manufacturers?
ARealplumber is offline
Old 01-03-2010, 06:22 PM   #13
Tim0282's Avatar
Sure have.... That is why I don't buy USG Plus 3.... I can add my own air if I want any added.
Tim0282 is offline
The Following User Says Thank You to Tim0282 For This Useful Post:
ARealplumber (01-03-2010)
Old 01-04-2010, 01:10 AM   #14
Ben of Hyde's Avatar
Rewards Points: 150
They dont bother none they just make the next coat grab better.
Ben of Hyde is offline
Old 01-04-2010, 04:14 PM   #15
Tim0282's Avatar
Oh yea, right....
Tim0282 is offline
Old 01-04-2010, 08:30 PM   #16
Rewards Points: 150
just make sure to mix the soft top well and apply a thinner coat, their usually gone by the time I have to sand.
They are just air that develop from mixing as someone pointed out, as long as it's just air in the bubble and not unmixed powder.
I rarely get them when i mix by hand, mostly when I use the electric mixer.
Old 01-04-2010, 09:57 PM   #17
Butt Expert
Brocktologist's Avatar
Trade: Drywall
Rewards Points: 250
This place is a wealth of knowledge...
Brocktologist is offline
Old 01-05-2010, 09:28 AM   #18
KING OF ROCK's Avatar
Trade: PROFESSIONAL CONTRACTOR
Hi rj,
sometimes i'll get air bubbles if i try to apply a second coat before my first coat is fully cured....like some of the responces said....you can wait till it's fully dried and you knock the heads off with a broad knife/6" knife, give a lite sand with 100 grit sand paper and touch up with some redi-mix and you'll be good to go! Good luck my friend.
Blaise
KING OF ROCK is offline
Old 01-05-2010, 12:53 PM   #19
Drywall & Painting Pro
Sir Mixalot's Avatar
Rewards Points: 18,115
Add a little
Sir Mixalot is offline
Old 01-05-2010, 03:21 PM   #20
Grand Rapids Remodeling
Paulie's Avatar
Rewards Points: 2,052
The Capt. got it right. Going over dirty old paint will always produce air bubbles. Kinda like bubbles in a glass of beer, the more bubbles the more left over soap and dirt are in the glass. Not that I would know anything about drinking beer.
I also use the dawn but the jury's still out on how effective it is. It's does make the mud smell nice though.
Paulie is offline
The Following 2 Users Say Thank You to Paulie For This Useful Post:
Capt-Sheetrock (01-05-2010), Scottula (12-10-2010)
Drywall bubbles AlSmith Drywall 5 06-08-2009 09:48 AM
Air Bubbles under laminate flooring Ugo Flooring 13 04-07-2009 09:12 PM
paint bubbles on door jambs moe2424 Painting & Finish Work 10 10-13-2008 09:05 PM
Bubbles when taping over paint raven2006 Drywall 30 12-23-2007 03:39 PM
Air Bubbles in Laminate Flooring Bigman Flooring 19 09-05-2007 09:07 PM
